Rough idle when cold | FerrariChat
Discussion in 'Mondial' started by gidleigh, Apr 14, 2011.
  1. gidleigh
    gidleigh Karting
    Nov 27, 2010
    141
    Coronado, Ca
    My car has just begun to run very rough and won't rev properly after it is started when cold. It starts fine and after it has warmed up the issue is gone. I assume the problem is in the cold start circuit. Has anybody had similar problems?
  2. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,760
    US of A
    Michael
    This could be one of several things.
    MAF sensor's, ECU's, Ground wires at intake (happened to mine), Spark plug wires, Fuel pressure regulators, 02 sensors... Need to start somewhere - try that short list.
  3. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,381
    Northern VA
    Dave W
    #3 davebdave, Apr 14, 2011
    Do you get a check-engine light even intermittently? We have had some similar issues but we also got a light. I wonder if it could be a bad heater in an o2 sensor?
    Dave
    PS> Does your car have the Motronic 2.7 where you can pull your error codes by pushing a button in the trunk and watching the dash lights?
  4. Valenzo
    Valenzo F1 Veteran
    Dec 4, 2010
    5,069
    IL & NC
    Ted
    As my Mondial is going under the knife very soon, while the engine is out i'm having Bradan install Dave Helms supremo GCK which is supposed to eliminate most of the erroneous CEL, ECU and various electrical gremlins with better performance all around.
    You may want to consider this but while the engine is in, its a 12-14 hour job, engine out - 7-9 hours. There’s a big write up on it in the 348 room.
  5. lightning
    lightning Formula Junior
    Apr 19, 2010
    551
    Stockport
    Martin Oliver
    I just had this same issue on my Mondial t and it turned out that one of the air hoses had come off.
    The idle was erratic and there was no power at low RPM during cold starts. It also shunted under acceleration.
    The hose had come off under the plenum chamber. Check all your air hoses to see if any are loose or have come off. This hose was impossible to see by looking at the engine and unfortunately required removal of the plenum chamber top to refit it.
    The car ran fine once warm (about a mile)
  6. gidleigh
    gidleigh Karting
    Nov 27, 2010
    141
    Coronado, Ca
    I pulled the codes: left side 1211, 1212, 4112. right side 1114, 4114, 4112.
    The 1xxx codes are related to the O2 sensor, MAF or coolant sensor. The 4112 is related to the phase sensor. I am not sure where to start. I am new to tearing apart the Mondial.
  7. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,760
    US of A
    Michael
    Easiest is the MAF.
    When the car is running poorly unplug the quick connector on each MAF (one at a time) and see if it changes the characteristics. If it does then that MAF is probably responding. If it makes no change to the running once unplugged then that MAF would be suspect.
    If they do respond then second on the list of easy is the 02 sensors. Unplug them from the harness (up near the oil filter stand) and un-thread them from the exhaust stream. Replace with new (they are just Bosch sensors) and then report back.
  8. gidleigh
    gidleigh Karting
    Nov 27, 2010
    141
    Coronado, Ca
    Thanks I'll give the MAF test a try tomorrow. By just Bosch sensors. Does that mean the part number would be the same as any other car that uses Bosch parts?
  9. lightning
    Apr 19, 2010
    551
    Stockport
    Martin Oliver
    And check for loose hoses....my comment has been skipped over but I had all these issues, I had the MAF units off and checked them, plus other stuff, and in the end it was just a hose.
    It's probably not that on yours but can be checked in a few minutes.
  10. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,760
    US of A
    Michael
    #10 Michael B, Apr 16, 2011
    No, there are multiples of different Bosch 02 sensors. You will require the one that has the correct connector and values.
    Chances are that it will fit something like a Camry as well though. I am sure the 348 forums will list the exact cheapest cross reference available for the 348 version of the Mondial 3.4 (yep, the Mondial t had this engine before the 348 did). That often times seems to be what they strive for over there.
    Here is a great site that will get you close on a lot of the 3.4 stuff like this. Look up simular issues as yours (TPS, MAF, Phase, loose hose, Codes). http://my348.com/
  11. davebdave
    davebdave Formula 3
    Mar 18, 2007
    2,381
    Northern VA
    Dave W
    The 348 parts sticky shows a walker replacement for the o2. We are runnung two of them with no issues at about $60 each.
    Dave
  12. gidleigh
    gidleigh Karting
    Nov 27, 2010
    141
    Coronado, Ca
    Thanks everybody for the useful tips and help. By the way Michael I unplugged the MAF connectors, same change both sides.
    As a less expensive approach I will give the Walker O2 sensors a try. But I may have a more fundamental problem with my right Cat which has a rattle. Can the cats be rebuilt or do you have to suffer the sticker shock of buying new?
  13. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,760
    US of A
    Michael
    Good for you for taking on the diagnosing. Keep notes, check all easy things 1st and don't worry too much about it - as anything can be fixed.
    If you end up going to new converters please consider the high performance replacements like Hyperflow available through our forum sponsors.
  14. lightning
    Apr 19, 2010
    551
    Stockport
    Martin Oliver
    Have you had any water on the engine recently, say from washing the car or going out in the rain?
  15. gidleigh
    gidleigh Karting
    Nov 27, 2010
    141
    Coronado, Ca
    No water from any source.
  16. Frari
    Frari Formula 3
    Nov 5, 2003
    1,194
    brisbane australia
    tony
    Have you done a reset on the ecu. ...turn off battery for a few hours, turn everything electrical off ie fans aircon etc. let sit for a few hours, turn switch back on start car without doing anything other than turning the key, let it idle for about 10 mins til the fans come on. it will go through some check cycles and this may fix your problem or at least help
  17. Lino
    Lino Formula Junior
    Jul 7, 2010
    923
    Montreal Canada
    Lino
    How can i read ECU codes.
    is it standard OBD?
    thanks,
    lino
  18. gidleigh
    gidleigh Karting
    Nov 27, 2010
    141
    Coronado, Ca
    I am currently in process of changing gear box oil. I will do the reset after. I know a reset can solve a world of problems. At least for a while,
  19. gidleigh
    gidleigh Karting
    Nov 27, 2010
    141
    Coronado, Ca
    Go to www.my348.com. Look under the section on ECU's
  20. gidleigh
    gidleigh Karting
    Nov 27, 2010
    141
    Coronado, Ca
    #20 gidleigh, Apr 24, 2011
    I changed the gear box oil two days ago. In doing so I removed the air filter and a few hoses as well as disconnecting the O2 sensors. Replacing the oil was a breeze after which I did a cold ECU reset. The car runs beautifully and the bonus is the Redline 75/90 synthetic made a huge difference in shifting.
    I went for a nice drive today with a friend who dove his F 575. Life is good.
  21. Michael B
    Michael B F1 Rookie
    Apr 28, 2004
    3,760
    US of A
    Michael
    That's good enuf for me! Happy driving.
