Rookie Testarossa Questions | Page 2 | FerrariChat
Discussion in 'Boxers/TR/M' started by jaytheferrariguy, Aug 11, 2020.
  1. jaytheferrariguy
    Aug 11, 2020
    8
    Wisconsin
    Jeffrey
    Thanks Rob!! i just bought a set or i would have taken them in a blink! darn!! :)
    thanks!!
    Jay
  2. Clyde Romero
    Clyde Romero Formula Junior
    Sep 6, 2019
    691
    Atlanta Georgia
    Clarence Romero
    I think you can get one from eurospares
  3. Clyde Romero
    Sep 6, 2019
    691
    Atlanta Georgia
    Clarence Romero
    well I own a 512 TR and I have always done my own oil changes and have always jacked the car up from one side and have yet to crack my rear window
  4. desant78
    desant78 Rookie
    Jan 20, 2021
    4
    New Jersey
    As a hopefully soon to be TR rookie, I figured I'd add my questions here:
    I'm more of a DIY mechanic, where is a good place a to find parts for the engine out service? Water pump, timing belt, etc?
    I saw someone mention getting a differential, where is a place to source one?
  5. Grease Donkey
    Grease Donkey Karting
    Jul 5, 2018
    98
    Zurich, Switzerland
  6. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,913
    romano schwabel
    no shortdescription from you
    not filling out your profile
    but asking for help?
    you think that this is matching together well?
  7. desant78
    desant78 Rookie
    Jan 20, 2021
    4
    New Jersey
    Fair point! On other forms I leave that blank, but I just updated my profile for here. Knowing I'm in the USA does help since I'm asking about parts.
    turbo-joe likes this.
  8. Veedub00
    Veedub00 F1 Rookie
    Jun 30, 2006
    4,897
    Troy, Michigan
    James
    Depends on the part! I scour the internet and look for good prices and reputation of the business. Some parts can be ordered from NAPA and Orielly even. Some parts really should be OEM and pay the ferrari tax, some are good to use the repro jobs that are cheaper. Some parts I buy used on eBay. Some parts I made myself.
    desant78 likes this.
  9. turbo-joe
    Apr 6, 2008
    8,913
    romano schwabel
    thank you desant78
    here in europe I have some good parts stores but nearly not did/do business with the US. too expensive and also always freight and custom taxes to be paid
  10. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Here is my take:
    Brake pads are cheaper than clutches:
    Use brakes to slow your car down, not your gear box (unless towing down a grade). Go to neutral as you slow rather than a lower gear.
    Clutches are cheaper than synchros:
    Double clutch to align gears rather than using synchros.
    Synchros are cheaper than gears:
    When hurried, don’t shift faster than a synchro can accommodate.
    V4NG0 likes this.
  11. campbell360
    campbell360 Formula Junior
    321
    Michiana
    Doug
    I order regularly from Eurospares and ship to the US. It's still cheaper for the most part than dealer pricing.
  12. campbell360
    321
    Michiana
    Doug
    For the engine out service I recommend the kit from Daniel at Ricambi. He puts everything you need in one package. He's a good resource as well.
  13. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    The kits are good, but still a starting point. Things like exhaust check valves and hoses etc should be added.
  14. Clyde Romero
    Sep 6, 2019
    691
    Atlanta Georgia
    Clarence Romero
    Ted rutlands sells a great kit for the TR used it many times
    ask for Brian
    they carry everything water pump kit the works one stop shopping
    with regards to the differential
    what year is your car? and how many miles?
    V4NG0 likes this.
  15. V4NG0
    V4NG0 Formula Junior
    694
    Charles Edward Cheese
    +1 for Brian at T. Rutland’s
  16. desant78
    desant78 Rookie
    Jan 20, 2021
    4
    New Jersey
    #41 desant78, Feb 18, 2021
    Wow, thats a lot of great responses in just one day! The rumors about how helpful this forum is seems to be true. That's a great starting point all this info, I read write ups that say "$2k" for parts for an engine out service, but I feel better actually finding the parts on websites and seeing the prices.
    Clyde Romero, I don't own a TR (yet, hopefully this summer I will). I'm just trying to do a bit of homework before I get into one and get burned by the cost it, so I dont have a need for a differential (and hope to never actually need one).
  17. Gary Sandberg
    Gary Sandberg Formula Junior
    Do the homework on recent service. A PPI and test drive are also recommended. There will still be little surprises, so budget accordingly. These cars are 30+ years old!
  18. Zeff
    Zeff Formula Junior
    Oct 8, 2018
    678
    Cupertino, Ca
    Ryan
    When the car is cold don’t shift into 2nd until the gearbox is warmed up just skip to third. You won’t have any problems then. This won’t take long either. Likely just a couple of shifts to third then you will be fine. My mechanic said this is the best method and I agree.
    TJsBeer, MOSS, bernieb and 1 other person like this.
  19. desant78
    desant78 Rookie
    Jan 20, 2021
    4
    New Jersey
    Thanks for all the tips!
    Got another new question: as I am looking at cars, should I be worried about the pre-88 cars that have spline wheels vs. cars with lug nuts? Are the consumables, like wheel bearings, etc easily found for both? All my cars have 5 lug wheels, so I'm wondering if buying a TR with the spline wheels a disadvantage. I understand buying actual wheels should be easier as 5 lug, but I'm mostly worries about the maintenance cost between the two.
  20. Grease Donkey
    Jul 5, 2018
    98
    Zurich, Switzerland
    Early TRs with lug nuts had TRX (metric) tires. The TRX size for the rear is NLA. Replacement imperial wheels can be found (16'').
    Otherwise the early cars don't have significant/costly differences to the later TRs.
    A 512TR however is a different car altogether with over 100 improvements to the initial TR which -in the eyes of some- justifys the hefty price increment.
  21. MOSS
    MOSS Formula 3
    Apr 28, 2004
    1,619
    Good advice. Maybe you can shift to Red Line NS oil for your gear box and it may make things a lot better. Mine goes into second fine now when cold but at any event, don't force it. Follow the 1st to 3rd as outlined. Enjoy!
    Zeff likes this.
  22. Jonny English
    Jonny English Formula Junior
    Jun 14, 2017
    416
    Poole, Dorset
    Jon
    A vote for a nouvalari exhaust from me.
