Road Rash & Chips in Paint | FerrariChat
Discussion in 'Detailing & Showroom' started by SoFLFerrari, Jul 18, 2016.
  1. SoFLFerrari
    SoFLFerrari Karting
    Apr 23, 2015
    202
    South FL
    I drive my 2010 Cali a lot and have started to notice chips on the paint of the hood. No more than half a dozen right now and they are tiny, but they go through the clear coat and paint to the metal. The car does not have a clear bra (I'm not sure I want to go down that route). What's the best way of addressing these chips?
    Will a good detailer be able to get them out? How much should I expect to pay for detailing? Thanks in advance!
  2. SizzleChest
    SizzleChest Formula Junior
    Dec 15, 2014
    255
    Naples, FL
    Scott
    You can look into the Dr. Colorchip line of repair kits and attempt it yourself. I have had some very good results using their system.
    If you are not happy with the results, the only other option, in my opinion, is to have the affected panel(s) re-painted.
    Hope this helps!
  3. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,316
    Palos Verdes
    Vince V
    Depending on your skill and patience, there are touch up kits which are the next step above a Dr. Colorchip kit. I use the Dr. Colorchip and find it satisfactory for the 10 foot effect. The chip is still there though you can fill it in over time with their material. Still, the paint chip repair kits are more involved but yield a result that it almost as good as repainting. Nothing replaces a respray, however.
  4. SoFLFerrari
    SoFLFerrari Karting
    Apr 23, 2015
    202
    South FL
    VVvassallo & SizzleChest - Many thanks. I've used Dr. Colorchip on my Cali and agree that it passes the "10 foot" test. Within 10 feet though I can see abrasive swirls in the clearcoat despite using the finest grit polishing pad. I'm tempted to use an electric polisher to buff out those abrasive swirls, which I did successfully on my E550, but I am worried about turning a quarter-size blemish into a pancake-sized one. I was OK experimenting on the E550, but don't want to make a fatal mistake on my Corsa Rosso California.
  5. SizzleChest
    Dec 15, 2014
    255
    Naples, FL
    Scott
    Wavey, most welcome!
    I have successfully polished over chips, both repaired and not. I feel that you would be good to go with a machine polishing on your F car, however, if you are not comfortable in doing so, seek out a professional in your area to have a look.
    This way you can rid your finish of those pesky swirl marks!
    If I were closer I would love to lend a hand!
    Regards,
    Scott aka Sizzle
  6. JaguarXJ6
    JaguarXJ6 F1 Veteran
    Feb 12, 2003
    5,533
    Black Hawk, CO
    Sunny
    For tiny chips, aka rash, patience, a toothpick, and a touch-up bottle of paint and clear coat makes them near invisible. (Note: you need to scuff the tip of the toothpick to get it to hold paint)
    For bigger chips, the chip will not be "level" unless you use excess paint and buff it level. Leave this for the pros.
  7. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,721
    Just East of Weird
    Bob
    Check with a local paint shop to see if they will tackle the touch-ups for you? Solid colors are easier to fix than metallics.
  8. GG-33
    GG-33 Karting
    Apr 28, 2014
    76
    Farnham, UK
    Greg
    try 'chip-x'
  9. DonJuan348
    DonJuan348 F1 Rookie
    Aug 5, 2008
    4,442
    Taxing Jersey
    What kit is steps above Dr Chip?
  10. blackbolt22
    blackbolt22 F1 Veteran
    5,792
    Boca Raton, FL
    Mr. Anderson
    I've got so many I'm going to do a respray.
  11. Ferrarimondial348
    Ferrarimondial348 Formula Junior
    Nov 29, 2012
    530
    Scottsdale, AZ
    Stephen
    Sunny,
    I purchased a small bottle of the origional Nero FER 1240 base coat paint to have my detailer touch up some tiny chips on my 348 Spider. The base coat is the color but I noticed you wrote to use clear coat also. Is this step necessary for tiny pin size chips. Bare in mind my car is black. Thanks for any feedback.
  12. ECHO CHARLIE
    ECHO CHARLIE Karting
    Jul 8, 2009
    110
    You should use clear coat , the base/color does not have any/much durability. You can probably pass the 10 foot test . When we sold paint everyone wanted a small can of touch-up ,but once base coat / clear coat became standard it made t/u more difficult.
    Edward
  13. Ferrarimondial348
    Nov 29, 2012
    530
    Scottsdale, AZ
    Stephen
    Thanks Edward. I will purchase the clear coat also.
  14. ncjetskier
    ncjetskier Formula 3
    Jul 7, 2012
    1,416
    Eastern NC
    Chris
    IF you want it done right, bring it to a professional. They can tell you whether it can be buffed out (doubtful) and the correct way to fix it. I have never seen a "kit" work well enough that you could not tell from 3 ft away. Personally, I just get the car repainted when my 360 starts to show the rock chips.
  15. JoshVette
    JoshVette Formula Junior
    Aug 12, 2007
    708
    Grand Prairie/Dallas
    Josh
    I am a professional detailer of more then 10 years now and will tell you that no touch up kit will make it look like a new paint job, you will always see the small pin head dot weather it's the color of the car or white primer.... whenever I have to do touch up work I make it known before hand that the goal is to only remove the white color so it's less noticeable as it will never be perfectly level with the original paint.
    My suggestion if you want it to look perfect again is to respray it then wait a month and get a clear film installed on it. The films are really good now and look like the paint, you can't tell the difference. Just make sure the installer is using either expel or suntek film and do your homework, a good installer can do it with no stretch lines and tuck it under everything so you don't see it and don't go for the half way up the hood nonsense wrap it full on each panel. ;)
  16. LBBP
    LBBP Formula Junior
    The process of properly fixing paint chips is very tedious and time consuming. If you have just a handful the link I've attached explains the process and techniques for fixing chips. If you have numerous chips, a complete respray is indeed your best option as JoshVette stated.
    https://www.youtube.com/watch?v=6xi3xmeO6C4
  17. Ferrarimondial348
    Nov 29, 2012
    530
    Scottsdale, AZ
    Stephen
    Thanks guys, I really appreciate the advice...
    I have two tiny needle pin size chips next to the Cavalini badge on the bonnet and one on the drivers wing mirror. At this point I will have my detailer fill these with the touch-up paint as I believe he will do a good job. I have had the front spoiler resprayed once and you are all correct in that it was the best way to go. I had the shop match the paint thickness to the car and it looks perfect even after 12 months of driving.
    Cheers,
    Stephen.
