Retrofit DAB radio UK 458 spider | FerrariChat
Discussion in '458 Italia/488/F8' started by Omegaelite, Sep 18, 2016.
  1. Omegaelite
    Omegaelite Karting
    Sep 11, 2016
    143
    Jesse Harfield
    #1 Omegaelite, Sep 18, 2016
    Ive searched the forum and the internet and couldn't find an answer to this....
    Is it possible to get DAB radio retrofitted to a December 2012 build 458 spider?
    The FM is awful, drops in and out all the time so looking for a better radio solution for long drives......
    COuple of other random questions -
    How much should the breaks squeak at low speed? mine squeal loads
    Dash rattles - Is it normal for the carbon vents both sides to rattle ?
    Help!
  2. RipVega
    RipVega Karting
    Jan 12, 2014
    191
    Berkshire
    I'd like to know this too. I'd have thought the aerial might be an issue. Cost is likely to be high. My F12 has DAB but the reception is patchy compared to my 911 which maintains signal over the same drive so don't expect too much from the Ferrari DAB.
  3. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,618
    South East
    Jimmie
  4. cuse92
    cuse92 Karting
    52
    Kent, UK
    Ben
    on the DAB I don't think you can retrofit to the standard stereo (it is bizarre because satellite radio - same as DAB - was standard in the US) as it wasn't even an option and there's no receiver.
    On the brakes, most carbon ceramic brakes squeal at low speeds, particularly when there is no heat in them (and it can be tricky to get enough heat into them legally on a road!). Mine squeal a fair bit.
    I don't have the carbon vents, but have heard of the same issue from others who have it. The standard aluminium ones don't seem to rattle, but there is some creaking in the roof on a bumpy road - the chassis is a bit "flexy"...
    If you put a Capristo on and keep the rear window down you won't hear the rattling :)
    Enjoy, nice looking car.
  5. Randyslovis
    Randyslovis Formula Junior
    Jul 7, 2011
    897
    Atlanta, GA
    Randall J Slovis
    I cannot help with the radio issue.
    The roof is much easier to sort out.
    As you are in England (I assume with drive on right) I do not know if you have access to the same products as we do. I use Griot's Garage Vinyl and Rubber dressing on my roof's "rubber". I do it frequently. If you put roof in vertical position, you can access all the rubber seams well. I apply it liberally to these areas. It eliminates the squeaks I occasionally used to get. My ubermechanic says the middle roof seam has the most pressure on it. Apparently it is "pinched" in the opening process. I try to get this one especially to keep the seam "plump" and water tight. Even without the roof being open, I put this dressing along the seams and rear window rubber area as well. Don't forget to do the front header when the roof is open which has rubber running the whole length of the windshield. That area is most exposed to the sun when roof open so most drying occurs here in my opinion. The first application helped resolve squeaks and rattles that started to occur and now are no where to be found.
    If you are unsure of what to use, our roof is made by Webasto, a German firm. BMW uses the same mechanism/parts according to my tech. So, BMW can certainly help you with a suitable convertible roof product.
    Lastly, there are mechanism lubricating points that the dealer can address. It is a little messy, but it also helps with the smooth functioning of the roof. Every year at my service I ask them to do this.
    BMW has an old product called "gummiplege". I used to pay $9 US for it. Now it is $80 US! It is a rubber treatment that looks like petroleum jelly. Unfortunately, silicone based products and rubber can be an ultimate no no. Yes, the new rubber is not true rubber, but it still is petroleum based. So, the risk of the fantastic gummiplege effects may be mitigated by it ultimately being harmful to our seals. Net, if the simple products do not work, you may want to try this as last ditch effort.
    Beautiful car by the way.
    Best.
