Resting hand on gear shift | FerrariChat
Discussion in 'Technical Q&A' started by kdf398, Oct 15, 2009.
  1. kdf398
    kdf398 Formula Junior
    490
    Pasadena
    Keith
    Does resting one's hand on the gear shift while driving damage anything or cause any undue wear to anything? I had heard that it is not recommended in the Mondial w/Valeo and was curious about other Ferraris.
  2. FF8929
    FF8929 Formula Junior
    Apr 12, 2008
    799
    Livonia, Michigan
    Fred Flynn
    #2 FF8929, Oct 15, 2009
    I don't do it. While direct downward pressure won't hurt, there is always a tendency to put forward or rearward pressure on the lever, and this will cause the shifter fork to rub on the syncro ring. This should only be the case, while shifting.
  3. stephenofkanza
    stephenofkanza Formula Junior
    Mar 5, 2005
    542
    Kansas
    Stephen LeRoy Sherma
    There are different views (pros & nays).
    The pros say that since the shift lever runs through linkage (3x8's) wear is not taking place.
    The nays (the group I am in - although for different a reason) point out that it be next to impossible to just apply vertical pressure (the point of the pros).
    I used to be a private pilot and any pressure on the yoke/stick once the aircraft was trimed
    for level flight would result in change wheither it air speed or altitude. So I figure considering driving on the road with all the changes in the surface I can not be sure I would not transfer laterial pressure.
    Just my 2 cents.
    Stephen
  4. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,634
    While having one hand on the gear shift knob does not particular harm;
    How are you going to react in an emergency with only one hand on the steering wheel?
  5. Jedi
    Jedi Moderator
    Moderator Lifetime Rossa Owner
    Mar 18, 2008
    32,153
    Seattle Area
    Dave
    Funny this just came up - just last week I asked my F-wrench Carlo (servicing
    Ferraris for 40 years) and he also says "don't do it" just to help avoid forward
    pressure and causing fork wear. I'm finding it a hard habit to break, but as another
    poster said, nothing wrong with keeping both hands on the wheel. :)
    Jedi
  6. kdf398
    490
    Pasadena
    Keith
    Thanks for the replies. I usually find myself resting my hand on the gear lever when the car is in first, third and fifth (on a 308). it just seems to be in a natural position for resting my hand at those points. I too will try to break myself of this habit.
  7. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    If you ever saw a shift fork worn down paper thin, or blue from overheating against the slider, then watched the owner drive with his hand on the lever, you wouldn't ever ask this question again. Any extra force is extra load. Extra load is extra wear. Its like riding a motorcycle dragging your shoes on the ground and wondering why your soles are worn off.
  8. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    I put my hand on my 3.2 Mondial shifter recently. Gave it the slightest forward and backword force and felt my transmission spinning through the shifter, cool, stopped doing it immediately.
  9. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Driving a Testarossa w/ no power steering I find that I always have two hands on the wheel.. Just keep your hands on the wheel and you'll be fine.. :)
    R
  10. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    Well, there we have it. My New Year's resolution this year was to keep my mit off the lever.
    Though, with gum on my boots I do try to burn it off by dragging them on the ground riding my Harley :):).
  11. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    I would think the ball detent on the shift fork would keep small amounts of pressure on the shifter from doing anything negative to the trans.
  12. Mike Florio
    Mike Florio Formula Junior
    Jun 19, 2003
    599
    NW Rural Nevada
    Mike Florio
    Resting your hand on the shift lever is no different than resting your foot on the clutch pedal.
  13. bundas
    bundas F1 Veteran
    Dec 31, 2005
    7,090
    lexington ky usa
    mitchell barnes
    i see much damage from resting a hand on shift lever. Just do not do it.
  14. jsa330
    jsa330 F1 World Champ
    10,026
    75225
    Scott
    I haven't give this much thought.
    For some reason, I don't cruise with my hand on the knob in the 308, but did with the 330 and other manual trans cars I've owned, have been told it's not a good habit.
    I guess the particular seat adjustment & angle I need make it uncomfortable.
    Lesson learned: Keep your hand off your knob while driving.
  15. SonomaRik
    SonomaRik F1 Veteran
    Guessing good advice with any tiptronic or Valeo style.
  16. Sareve
    Sareve F1 Rookie
    Oct 23, 2007
    2,968
    Singapore/Melbourne
    Daniel
    Aside from mechnical damage, it's also not very good to drive with just 1 hand. If you watch the pros drive on youtube, you'll see that they only rest their hands on the shift lever to pre-empt their shifts and quickly place that hand back on the steering wheel immediately after the shift.
  17. James_Woods
    James_Woods F1 World Champ
    May 17, 2006
    12,755
    Dallas, Tx.
    James K. Woods
    +++. Same here. If you need to dodge a squirrel or a 2x4 off the back of a truck, you WILL need two hands. On the other hand, I think it would take a lot of pressure on that gated shifter to make anything happen in the gearbox - just resting your hand there for a moment prior to a shift is probably IMHO not that big a deal.
  18. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Isn't tiptronic an electrically controlled system, not mechanical? If so, then resting your hand on the shifter should make no difference at all, as long as you don't press hard enough to trigger a gear shift. Same with paddle shifters... resting fingers on them does nothing until you press hard enough to cause a shift.
    But I do agree with not resting your hand on the mechanical manual transmission shifter or foot on the clutch pedal. "Riding the clutch" can burn it out really fast. And, while we are at it, when you are stopped, don't hold down the clutch pedal. Put it in neutral and let off on the clutch, otherwise you'll cause premature wear on the throwout bearing (or so several mechanics have told me).
  19. AceMaster
    Feb 6, 2009
    34,749
    Ontario, Canada
    thanks for this.
  20. finnerty
    finnerty F1 World Champ
    May 18, 2004
    10,406
    DON'T DO IT.
  21. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    how long is your arm? i rest my hand on the handbrake grip. i have to reach out for the gear lever.
  22. Skidkid
    Skidkid F1 Veteran
    9,482
    Campbell, CA
    John Zornes
    More than long enough. In my M I have trained myself to rest it by the base of the stick. That way it is close at hand and I can shift without thinking but I don't have my hand on the stick.
