Reproducing Clutch Slave Cylinder Hydraulic Hose 108865 | FerrariChat
Discussion in 'Mondial' started by MaseratiMike, Jan 26, 2018.
  1. MaseratiMike
    MaseratiMike Formula Junior
    Mar 15, 2016
    350
    I have been able to reproduce a replacement high quality stainless steel, slave clutch cylinder hose (Part 108865) for my Mondial QV via a UK racing hose manufacturer. If there is sufficient interest I can get more produced.
    Features:
    1)303/304 Stainless steel Banjo and female connectors
    2)303/304 Stainless steel braided hose with coloured protective PVC outer cover (Black)
    3)PTFE inner hose
    4)Operating temperature range -70°C to 260°C (-158°F to 500°F)
    5) Maximum burst pressure 870 Bar (12618 PSI)
    6) Includes Banjo bolt and 2x copper washers
    7) lightweight & longer life than original rubber hose
    Attached are some pictures.
    Prices are £55 GBP including VAT & postage in the UK. Worldwide postage add £5 GBP
    MvT, Jeka and Pero like this.
  2. moysiuan
    moysiuan F1 Rookie
    3,645
    Canada
    Great job, looks like much better quality for an important hose. For greater certainty on fitment, in the Oem style in your picture, the female end goes through a support bracket, the thicker "nut" part is how far it goes through to, and a U retaining clip goes in the fitting groove to support the hose. Your hose has a swivel type fitting, will the fitting be small enough to go right through the bracket hole? If not it would not protrude long enough to allow the hard pipe fitting to reach. I recall the bracket is welded on. In any event, I haven't been in that area for a couple of years, so I can't remember exactly how it all attaches.
  3. moysiuan
    moysiuan F1 Rookie
    3,645
    Canada
    I think the fitting I am referring to is called a female circlip fitting.
  4. MaseratiMike
    Mar 15, 2016
    350
    Thank you - it has taken 4x different hoses and attempts to get this hose right with the manufacturer plus a few weeks of backwards/forwards. You are correct the original hose was held on by a circlip and fed through the bracket.
    The new hose doesn't need to be held in place as it's very light but strong and simply goes through the original bracket hole. The female end of the hose just screws into the male end of the rigid car clutch pipe, the banjo bolt then goes to the slave cylinder.
    These hoses are lifetime warranted, so should not need to ever change it again. My original rubber hose perished and split at one of the connector ends.... A heck of a lot cheaper than original or pattern hoses too.
    Pero likes this.
  5. porphy
    porphy Formula 3
    1,203
    LouisvilleKY/Switzld
    Randall Gatz
    Nice! What Mondial models will these fit? Also the price is for one?
  6. MaseratiMike
    Mar 15, 2016
    350
    This should fit the following Ferrari Models:
    • 512 Bb
    • 512Bbi
    • Mondial 8
    • Mondial 3.0
    • Mondial 3.2
    Yes price if £55 delivered in the UK or £60 delivered outside of the UK...
  7. porphy
    porphy Formula 3
    1,203
    Randall Gatz
    Too bad. I've got a T.
  8. AndruL
    AndruL Karting
    Apr 4, 2018
    234
    AndruL
    Are these still available.
  9. 350HPMondial
    350HPMondial F1 Veteran
    5,194
    Edwardo
    #9 350HPMondial, Jun 18, 2020
    mr. AndruL
    Hello Mondial Friend,,
    i’m on the hose project.
    my hydraulic guy has the, Golden Grail of New Holland,, aka FIAT,,”
    Italian hydraulic fittings. Thus I,
    Took my factory ,,, Ferrari 1981 euro mondial 8 clutch hose into him today.
    ha ha
    He was Stupified. lol,, All metric fittings need to be modified to work.
    But,, he says it could be done. ❤️
    thus,, I am pursuing (10 extra) and mine hose; All Ferrari spec. Black in color ,, don’t know. price yet.
    ( this just happened today. )
    any of you guys interested ,,,,?
    because,, we need to machine an internal relief grove “U” into the new metric fittings.,,,, this is a 4 step process
    Eduardo
    1981 euro Mondial8
  10. 350HPMondial
    5,194
    Edwardo
  11. stekkefun4
    stekkefun4 Formula 3
    2,232
    Belgium - Europe
    I had a local hydraulics shop make me a copy of the hose for only 12 euro. Works perfectly well.
    350HPMondial likes this.
  12. 350HPMondial
    5,194
    Edwardo
    wow,,, Right from the start,, my 7-8mm barb X 12 mm banjo fitting was $ 8.49...
    I don’t believe I will be able to beat your price. of 12 euro
  13. theunissenguido
    theunissenguido Formula 3
    Jan 21, 2004
    2,372
    Argent/Brasil
    Guido
    Any brake shop in Europe can reproduce a hose like this. Or they can use the original banjos again if still ok, or they put other banjos that are very common. Like Stefan says less then 15 euro.
  14. 350HPMondial
    5,194
    Edwardo
    See,,
    my Clutch hose ensemble.
    at local Ag Hydraulic shop.
    $ 33.75 parts +
    $ 50.00 shop hour , modify 2 fittings.
    shipped to your door
    (lower 48 states. )
    = less then a Ben Franklin... lol
    Eduardo
