Replacing cat with straight pipe in 328?
Discussion in '308/328' started by Steve672, Jul 10, 2009.
  1. Steve672
    Steve672 Karting
    Feb 15, 2008
    51
    ON, Canada
    Steve S
    I am thinking of replacing my catalytic converter with a straight pipe one my Euro 328. I noticed there are several sensors going into the cat including the one that indicates temperature overheating in the cat. What have other people done with these sensors? or rather what should be done with them? Any tips would be appreciated.
    Oh, one more thing, if anyone has ever done this is the sound much louder that with the cat in place?
    Steve
  2. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    32,537
    E ' ' '/ F
    Merritt Tockkrazy
    A properly designed test pipe will have provisions for those sensors (hint: avoid Stebro). The sound will be louder. You may want to look at a modern cat replacement like Hyperflow instead.
  3. Steve Magnusson
    26,537
    #3 Steve Magnusson, Jul 10, 2009
    The O2 sensor needs to be present in the exhaust stream when using either the cat or the testpipe. The thermocouple needs to be present when using the cat, but, for the testpipe, it doesn't matter -- if the testpipe has a fitting for the thermocouple, use the thermocouple to "plug" the hole; if the testpipe doesn't have a fitting for the thermocouple, just neatly zip-tie the thermocouple and its wiring to the chassis (without a cat, it is impossible for the exhaust stream to overheat so, even if the testpipe has a fitting for the thermocouple, it really isn't doing anything functionally).
  4. Steve672
    Steve672 Karting
    Feb 15, 2008
    51
    ON, Canada
    Steve S
    Thanks for the quick reply Tillman.
    Why the Hyperflow instead of the straight pipe? Better sound, better performance, better ......? just curious.
    p.s. thanks for the Stebro tip
  5. BigTex
    79,321
    Houston, Texas
    Bubba
    Legality...it's a Federal violation to tamper/remove emissions equipment...
  6. BigTex
    79,321
    Houston, Texas
    Bubba
    I see you are in Canada, so disregard my statement...
    But the modern high flow cats certainly pose no penalty on performance....it'd be a good idea to update an older expired one anyway they don't last to infinity....it's a chemical process after all...
  7. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Precisely....
  8. Steve672
    Steve672 Karting
    Feb 15, 2008
    51
    ON, Canada
    Steve S
    Has anybody had any experience with this catalytic converter, sells for $725:
    - Maxflo sports racing replacement catalytic converter for the 328 GTS model.
    - Fabspeed’s Maxflo 200 cell tri-metallic catalytic converter replaces the restrictive factory catalytic converter.
    - T304 stainless steel mirror polished with high performance 200 cell German imported sports racing catalytic converter.
    Also, the Ferrari 328 Sports Racing Catbypass Pipe is $350 at Fabspeed.
    I though if I was going to "help" the sound and performance then the straight pipe would be a better bang for the buck if the emission testing is not an issue.
    Any thoughts?
  9. mike996
    mike996 F1 Veteran
    Jun 14, 2008
    6,828
    Mike 996
    The straight pipe will do nothing at all performance wise. It will eliminate the potential for a fire caused by an overheating CAT (caused by a faulty ignition/fuel deliver system). The cat will eliminate the "fuel" smell from the exhaust.
    Assuming you are not legally required to have the Cat, take your choice.
  10. CliffBeer
    CliffBeer Formula 3
    Apr 3, 2005
    2,198
    Seattle, Washington
    Cliff
    What Mike says above is true, unless you have a partially blocked cat, in which case you'll have a much better running car with a straight pipe. I've seen several partially plugged 3X8/mondial cats.
    There is a bit more noise with a straight pipe.
    When you're looking at which straight/test pipe to buy, make sure the one you do end up buying has bolting flange mounted such that the pipe actually extends past the flange by a half inch or so. Why? Because the tapered compression gaskets need some internal support otherwise they just collapse in on themselves. The stebro straight/test pipe doesn't have the extra half inch and it's a problem.
  11. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,763
    Cerritos, CA.
    #11 miketuason, Jul 11, 2009
    This is exactly what I did Steve, thermocouple on the test pipe is not needed.
    If test pipe doesn't provide fitting for the thermocouple it's ok to leave it out.
  12. Steve Magnusson
    26,537
    Nothing wrong with what you've done, but you are really just "storing" the thermocouple by attaching it to the testpipe outer surface -- regardless of how much unburned fuel is present in your exhaust stream, it won't ignite, so the temperature of the testpipe will never reach the temperatures that the thermocouple is designed to detect. You can just as easily use some zip ties to attach it to a chassis member and "store" it there.
  13. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    #13 eulk328, Jul 11, 2009
    Are you sure there is more than one sensor on your cat.? Like you, I have a Swiss Market 328 and there is no O2 sensor because there is no frequency valve to vary fuel mixture. I only had a thermocouple. I replaced my cat. with an Ansa straight pipe and simply tied the thermocouple down in a convenient location. Incidentally, the Ansa straight pipe does have bungs for thermocouple and O2 sensor if you desire to use them (exhaust temp. guage, A/F mixture guage).
    It has been quite a while but I do not recall the exhaust being much louder at all with the straight pipe. I'm sure you will NOT notice any performance increase by eliminating the cat. unless yours is really plugged up from age/damage. Adding a Tubi, which I also did, will certainly make it louder.
    Having said all that.... mine is 1988 Swiss Market and yours is a 1989. Maybe they added an O2 sensor and frequency valve to the final version. Or maybe I'm not reading your profile correctly. You have written "1989 Euro 328 GTS Swiss with cat conv." It really should be classified as a "Euro" or a "Swiss." Not both. They are not the same (except from the geographical standpoint of Switzerland being in Europe :)
    PS. my car is in storage in Europe while I'm currently in California so emissions laws/tests over here do not come into play.
  14. doug328
    doug328 Formula 3
    Mar 11, 2004
    1,599
    The Space Coast, FL
    Doug B
    The hyperflow that I have has the fittings for both the thermocouple and O2 sensor so I hooked them both up. The cat I had was shot and the "test pipe" was half the price of a new cat. Since there are no car inspections here in Florida, what the hell. Little louder and I get more of an exhaust smell when stopped in traffice, ect. other than that not much difference than when the cat was on the car.
  15. Steve672
    Steve672 Karting
    Feb 15, 2008
    51
    ON, Canada
    Steve S
    Good point CliffBeer. Never thought of that one.
    lol
