Replacing 599 Ash Tray | FerrariChat
Discussion in '612/599' started by gsholz, Dec 14, 2019.
  1. gsholz
    gsholz Formula Junior
    320
    Oregon
    Jerry
    #1 gsholz, Dec 14, 2019
    Probably one of the simplest repairs on the 599 is replacing the ash tray (069717400). Remove the little tray inside to find the single screw holding the unit. Pop it out, disconnect wiring harness. The only fiddly part is to remove the actual lighter from the tray so you can move it to the new unit. You have to disconnect the plastic surround from the metal lighter part. There are two catches holding it in. That's it. Overall the tray is pretty delicate plastic. Easy to break if you bump it in the open position.
  2. Skidkid
    Skidkid F1 Veteran
    8,682
    Campbell, CA
    John Zornes
    About how much was the part?
  3. gsholz
    320
    Oregon
    Jerry
    $170 incl shipping
  4. Skidkid
    Skidkid F1 Veteran
    8,682
    Campbell, CA
    John Zornes
    Mine is not broken but the top bar is warped
  5. Motob
    Motob Formula 3
    Nov 11, 2003
    2,238
    Frederick, Maryland
    Brian Brown
    You can remove your ashtray and gently heat the top bar with a heat gun. Then straighten the warp (with gloved hands) until it cools. Be careful as too much heat will melt the plastic.
    Brian Brown
    San Francisco Motorsports
  6. Skidkid
    Skidkid F1 Veteran
    8,682
    Campbell, CA
    John Zornes
    Thank you Brian. I will do that over the holiday break.
