Replacement Solenoid for Bosch starter? | FerrariChat
Discussion in 'Technical Q&A' started by DavidDriver, Aug 14, 2006.
  1. DavidDriver
    DavidDriver F1 Rookie
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    #1 DavidDriver, Aug 14, 2006
    Search Index: ( starter solenoid replacement 0 331 302 082 )
    The ceramic cap on the end of my solenoid crumbled (see pic) when I removed the wires from my starter.
    I'm not sure if it can be repaired. Does anyone know?
    I found a replacement for it at a company called Wagner in Chino Hills.
    Does anybody have any experience with this company?
    The caption on their part number (bottom of Pg 3 in the url link to their PDF catalog) is: #W450-23.
    Description:
    Fits: FERRARI
    Replaces: BOSCH 0-331-302-082 (which is the # on mine)
    Lester #: 16709
    OEM Unit #: 0-001-314-006
    Note: 12 VOLT, SOLENOID CAP W460-03
    Wondering why the OEM number is different than the "Replaces" number too.
    Also, if they sell caps. And if this is an exact copy.. Maybe I can just get the cap.
    But the description for the cap says:
    Replaces: BOSCH 1-330-516-001
    Which doesn't fit any of the above referenced numbers.
    I'm a little confused, so I wrote them an eMail. But if anyone can point me in a well beaten path, I'd rather not take any chances.
    Thanks a bunch!
  2. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,611
    The Brickyard
    The Bad Guy
    Yeow! Man that thing was mangles. What caused that?
  3. PAP 348
    Dec 10, 2005
    100,199
    Mount Isa, Australia
    Pap
    The plastic becomes brittle with age and can break away like that. Especially when removing the wires from it. Or.........if there was a short in the solenoid. :)
    Why was he removing the wires in the 1st place? DavidDriver?
  4. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,332
    maurice T
    Pap thats a classic case of driving without the starter heat shield..ask me how I know
  5. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,332
    maurice T
    David did you get the cap off.I asked a guy and he said it has to be soldered off
  6. PAP 348
    Dec 10, 2005
    100,199
    Pap
    Ah, thanks mate. I had a feeling it was something like that. :) Have seen that happen to alot of cars also btw, not only Ferrari. :)
  7. maurice70
    maurice70 F1 Rookie
    Jan 25, 2004
    4,332
    maurice T
    Yeah he wanted to replace it and in removing the nut it came apart in his hands.I went through the same ordeal when I had my engine out during the rebuild and I gave the starter to a auto electrician to replace the cap.He said no prob about $150.The cond of my cap was no where as bad as Davids it was only a bit charred but it started ok and I only replaced it while I was there.He gave the starter back to me and the solenoid was stuffed.It wouldn't disengage.He was tryying to say that the ring gear must be damaged or something like that.I got him to replace the solenoid and then he wanted to charge me for it.I told him it was in perfectly good working order when I gave it to you and you quoted me $150 and thats what i paid.He wasn't to happy with me but he didn't get any more out of me.I then find out that he always goes back to fix his stuff ups all the time
  8. PAP 348
    Dec 10, 2005
    100,199
    Pap
    Shoddy workmanship........:(
  9. Donie
    Donie Formula Junior
    Jan 14, 2006
    346
    Spain/Ireland
    David,
    That's not a totally unusual occurence in cars with a bit of mileage on them. The two threaded studs that protrude through the end cap carry a lot of amps( from the battery on one side, and on to the field coils in the starter on the other side) when the solenoid engages as you start the car, and subsequently there is heat build-up, and arcing on the inside while the starter is engaged.
    BTW it's not ceramic, it's bakelite, and over many years gets scorched in the area around one of the studs.
    It's a de-solder/re-solder job to the push on connector at the side, and you could do it yourself, but if you haven't got a solenoid end cap then any autoelectrical shop will have it, and it shouldn't cost an arm and a leg.
  10. rjnavion
    rjnavion Karting
    Nov 1, 2003
    128
    Gate, OK (western O
    Ron Judy
    Try www.wai-wetherill.com
    They bought ACE Electric whom made solenoids for lots of Bosch starters.
    A local starter shop got a solenoid from them for my 512TR. Very inexpensive.
    Ron
  11. luckydynes
    luckydynes F1 Rookie
    Jan 25, 2004
    3,931
    CA and OR
    pit bull
    I got a complete replacement solenoid from Kragen for
    $40 . . . as other chatters had suggested, VW bus was a direct replacement . . . had the identical problem you have!!!
    I still need to track down why she occasionally just clicks.
    Anyway, I can get you the p/n if you need.
    Sean
  12. Steve Magnusson
    26,509
    Just want to 2nd the WAI recommendation, and mention that their website also shows that some of their solenoids are replacements for more than one particular Bosch PN. It's another data set that might help you (or confuse you more ;))
    I'd also say that replacing just the cap yourself is the hard way that trades time and risk for not much $ (but I confess that I've grown even more lazy).
  13. DavidDriver
    May 9, 2006
    4,424
    Grass Valley, CA
    David Driver
    Thank you all for your help and suggestions.
    Maurice is right. But he already knew why. I have no heat shield. Also a good reason to opt for the ceramic coating by Jet-Hot!
    I got a response back from Wagner, and I'm pretty impressed with the help they were willing to offer. They also sell the little parts, like the cap that I'll need. And a new striker plate should I need that also.
    They also told me how to perform the repair!
    I asked and he graciously agreed to let me post (sans the prices) our correspondence for your review:
    Sent: Monday, August 14, 2006 7:29 PM
    To: Sales at Wagner
    Subject: Solenoid
    I have a Bosch 0 331 302 082 Starter solenoid that has a broken ceramic end. I see you have a replacement part: #W450-23. Can mine be reapired? Or do I need to purchase a new one? How much is it? How soon can you send it to me? I live in Studio City. Would it be easier for me to come pick one up? Thank you!
    To: DavidDriver
    Sent: Tue, 15 Aug 2006 9:36 AM
    Subject: RE: Solenoid
    Hello Mr. Driver,
    Thank you for your inquiry.
    0-331-302-082 is replaced by our W450-23 which takes a W460-03 Solenoid Cap. You only need to unscrew the cap to replace it.
    W450-23 Solenoid (deleted)
    W460-03 Cap (deleted)
    We could ship them out to you by UPS or you can will call it. We are located in Chino, near Ontario.
    Best regards,
    Robert Wagner
    President
    Wagner Alternators & Supplies, Inc.
    Tel: 909-465-1950
    Fax: 909-465-5032
    www.wagneralt.com
    Sent: Tuesday, August 15, 2006 1:23 PM
    To: [email protected]
    Subject: Re: Solenoid
    Thank you Robert,
    If you don't mind, I'd like to post your reply on FerrariChat.com, as I'm certain other owners of the various Ferrari 308 models, will find this information useful.
    I'll call you with an order for the cap, once I see if mine actually unscrews. Someone told me they were soldered. But I can check it out, easily enough. Attached is a picture of mine.
    Let me know if okay.
    Thanks,
    David.
    Sent: Tue, 15 Aug 2006 1:26 PM
    Hello David,
    Correct, you will have to unsolder your terminals at the top of the solenoid cap, then you break out the epoxy or glue that is covering the screws holding on the cap. After that, it will lift off for installation of the cap. One thing that you should also carefully look at is the mobile contact plate. It could be worn and might also need replacing. W480-07 is our striker plate, but this requires you to remove a c-clip to replace it. Sometimes you can get away with turning it over and using the other side. This is your call. Price for the striker plate is (deleted)
    Best regards,
    Bob
  14. KJB355
    KJB355 Karting
    Apr 4, 2006
    152
    Chicago
    Kenneth Brom
    For what it's worth...
    the ...082 was superseded by 0 331 302 070 which is a good part number and available according to Bosch.
    www.rockauto.com came up using google, and lists it for $77.
  15. marankie
    marankie Formula Junior
    Aug 30, 2004
    252
    Agoura Hills, Calif
    Martin
    A&A alternator and starter repair on 1646 Morse in Ventura (805-642-1189) did a nice job of rebuilding my GT4 starter. Included a new solenoid, armature and gear for about $230.
  16. nathandarby67
    nathandarby67 F1 Veteran
    Feb 1, 2005
    8,349
    Mississippi
    Nathan
    Does anyone know if the solenoid part number discussed in this thread would be the same for a 1981 Mondial 8? Thanks!
