replacement parts expierences/problems | Page 3 | FerrariChat
Discussion in '206/246' started by GermanDino, Mar 16, 2014.
  1. Rifledriver
    37,315
    I had the faces fall right off on several sets of MM points. The bore for the pivot of the rubbing block was not parallel to the rubbing block.
    Been working on theses for a very long time and their QA fell off a cliff 10 or 15 years ago.
  2. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    I've seen that too. One reason that I have a few sets of "good used" points laying around. Sometimes better than the new ones.
  3. racerboy9
    racerboy9 F1 Rookie
    2,679
    Is there any way to tell the good MM points from the bad MM points? I have some NOS sets but not sure how long ago I got them.
  4. Rifledriver
    37,315
    I wish I knew. By the time I saw a problem all there was out there was the junk.
    Makes me wonder if we should fabricate a kit to put in some American points. I am sure those are all made in China now too.
  5. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    Randle,
    Send them to me and I'll compare them.
    No charge for disposal :wink :)
    Scott
  6. pistone
    pistone Rookie
    Sep 6, 2011
    1
    Hi Freeman,
    Please let me answer your question about the ignition points problem. At the former ignition points the sliding/isolation piece (where the movable contact is fixed) was made out of Pertinax. It´s pressed hard paper which absorbs the lubrication grease and releases it during running. The new aftermarket ignition points use here some kind of plastic which seems to be unsuitable. Even with lubrication grease the sliding zone gets gets hot and wears quickly. After 600 km operating distance there is hardly any opening of the ignition points. Beside of this the two contact surfaces aren´t parallel which results in a very high surface pressing in a very small area which also let the contact wear quickly. This can often solved with careful bending of the movable contact lever but the big problem is the wrong material of the sliding/isolation part.
    Pistone
    synchro likes this.
  7. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,505
    Germany
    Matthias
    Manfred, thanks for the explanation...
  8. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,863
    Southern California
    #58 4CamGT, Jul 20, 2015
    Matthias, Manfred,
    To learn more, what ignition system are you using? What type of coil? Could the points be getting "too" hot? Between the vendors, there seems to be a variety of ignition points available. You've tried all of them? Are all the sliding/isolation pieces constructed out of the same material? How many times has it happened at around 600km? Are there any other Dino owners who have experienced this?
    Freeman
  9. GermanDino
    Aug 14, 2007
    3,505
    Germany
    Matthias
    Freeman, original set up with Magneti Marelli Dinoplex AEC 101 D and coil BZR 205 A
  10. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,863
    Southern California
    I couldn't imagine anything else from you ;-)
    Freeman
  11. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,073
    Anybody know what surface finish the points contacts have when new? I'm thinking my used points which have good springs, and rubbing points, but the contacts have some pitting might be able to be polished back to being serviceable??
  12. dinogts
    dinogts Formula 3
    The distributor/rotor in my 1959 Austin-Healey BROKE in the middle of executing a pass on U.S. 2 heading over to Leavenworth, WA to meet up with my Healey mechanic while Synchro was following, and the engine went instantly dead. Synchro and I were very lucky that I didn't end up crashing into oncoming traffic (thank God there was none at the time) - as not only would I have been taken me out, but it could have taken out the car I was passing, any vehicle that could have been coming the other way, and Synchro following.
    My Healey mechanic (also expert on Jags, old Aston Martins, and Cosworth-Ford F1 engines) said that virtually ALL points and rotor assemblies that he has seen in the last 10 years have had serious problems and he is advising that everyone should convert to complete electronic systems for safety purposes. The rotor metals are flexing and then breaking off completely at lower rpms and much earlier in the estimated lifespans than they used to.
  13. 4CamGT
    4CamGT F1 Rookie
    Jun 23, 2004
    2,863
    Southern California
    This thread on points lubrication and describing the felt wick is good reading: http://www.ferrarichat.com/forum/technical-q-sponsored-algar-ferrari/153950-point-cam-lube-whats-best.html
    Freeman
  14. Pantdino
    Pantdino Formula 3
    Jan 13, 2004
    2,069
    Jim
    I can't imagine why anyone would be using points in their dizzy unless they are afraid the concours judge is going to look inside. Less accurate timing, much higher chance of failure.
    The condensers are also junk today in my experience. In all something to avoid.
  15. GermanDino
    Aug 14, 2007
    3,505
    Germany
    Matthias
    #65 GermanDino, Jul 22, 2015
    the reproduction tank looks almost identical to the original one and seems to be very good quality....
    (reproduction on the left)
    thank you Superformance
    synchro likes this.
  16. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,274
    Norfolk - UK
    Tony
    They are good reproduction tanks Mathias, i see them come into the SF and was amazed at the quality. I am unable to comment if they fit OK but it would be good to give SF feedback.
    If it wasnt for the likes of SF (& others) making repro items and sourcing / remaking obsolete parts, most of us will be sucking our thumbs, so thumbs up to Superformance for doing it.
    They need feedback to get things spot on.
  17. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    They look great!
    Do they have interior baffles like the originals?
  18. GermanDino
    Aug 14, 2007
    3,505
    Germany
    Matthias
    what are interior baffles?
  19. swift53
    swift53 F1 Veteran
    8,572
    E.S.
    Alberto
    #69 swift53, Jul 24, 2015
  20. GermanDino
    Aug 14, 2007
    3,505
    Germany
    Matthias
    all as in the original tank....
    synchro likes this.
  21. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
    #71 synchro, Jul 28, 2015
    When you look down the fuel sender mounting hole you can see the divisions that counter slosh
  22. Daryl
    Daryl Formula 3
    Nov 10, 2003
    1,036
    Barrington Hills, IL
    Daryl Adams
    On July 23rd I ordered a set of replacement rubber roof/window seals for my GTS from Cicognani in Italy via their website. I got a response email almost immediately, and this morning, less than six days later (including a weekend) the DHL truck showed up at my suburban Chicago address with the seals. The seals look great and were nicely packaged. I am very pleased.
    synchro likes this.
  23. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
  24. F40-R
    F40-R Formula 3
    Jun 22, 2014
    1,221
    Sorry, a little off topic but what is the correct paint code or colour for the wheels on a 72 E series 246?
  25. synchro
    synchro F1 Veteran
    Feb 14, 2005
    9,294
    CHNDLR
    Scott
