Replacement cost of front upper and lower ball joint rubber seals | FerrariChat
Discussion in '612/599' started by odf911, Jul 28, 2020.
  1. odf911
    odf911 Formula Junior
    Nov 30, 2013
    520
    London UK (Chelsea)
    Olivier
    Any idea what kind of cost i am looking at? Not sure only the rubber seals can be replaced or the whole part? how many man hours per corner? Thanks for the info ...
  2. Skidkid
    Skidkid F1 Veteran
    8,753
    Campbell, CA
    John Zornes
    You would have to take it pretty far apart, why wouldn't you just replace them? The labor difference can't be much at that point.
  3. GasAdams
    GasAdams Rookie
    Jun 17, 2020
    44
    Gas Adams
    I just had my front lower outer suspension ball joints replaced. It was $1,400.
  4. Rex71
    Rex71 Formula Junior
    Mar 24, 2007
    352
    Jeddah,Saudi Arabia
    Majd B.
    Hill Engineering makes ball joints & seals that are much better in quality than OEM parts and the price is reasonable too.
  5. tazandjan
    38,051
    Affirmative, get OEM and replace them again much too soon. Same for the 360 and F430.
  6. bamaman
    bamaman Formula Junior
    Nov 27, 2015
    650
    Mobile Alabama
    William M (B.J.) Lyon, Jr.
    My rubber covers are split and OEM tie rod ends are $750 each, so I bought two Hill Engineering ends for $450 total from RIcambi. Better quality.
    odf911 likes this.
  7. Inadeje
    Inadeje Karting
    Mine were done by Sam (owner) at Stradale UK. It wasn't very expensive at all. If I recall correctly it was just under 1k pounds. I also changed the tie rods.
    odf911 likes this.
  8. odf911
    Nov 30, 2013
    520
    London UK (Chelsea)
    Olivier
    Thanks I looked into that. In the end only the seals needed replacement. I think it took about 3h so not a big deal this time!
  9. odf911
    Nov 30, 2013
    520
    London UK (Chelsea)
    Olivier
    Thanks, I also had a crack in the undertray and needed an oil change and overall check. All together it was about $1,300 ..
  10. marcmc8867
    marcmc8867 Formula Junior
    Jul 27, 2004
    997
    NC
    Marc M.
    All, were your replies on this post for 599 or 612? I have both cars, just curious. Thanks
  11. Teejay
    Teejay Rookie
    Sep 12, 2017
    39
    Tim Jenner
    Does anyone here have experience of Prekom manufacture ball joints? Made in Slovenia, the company seems to specialise in Porsche and Ferrari replacement suspension components. Certainly cheaper than OEM and Hills but how does quality compare?
  12. brogenville
    brogenville Formula 3
    2,016
    Robin
    So I've just bought a Prekom lower ball joint. They are reported to be equivalent quality to Hills, but a good bit cheaper (£80 for the joint, boots and adhesive sold as a kit).
    They're all stainless in construction (like Hill), and the boots provided appear to be an improvement on OEM and Hill, as the circlip is integrated into the boot itself (the boot is literally cast around the circlip). Logically this should lead to a better seal, as there aren't any holes in the boot for the clip. Will report back any feedback I have on them. To inspect, they seem to be of excellent quality and the ball is very tight in the joint, though the proof is in the long term durability.
    evanmcm likes this.
  13. Teejay
    Teejay Rookie
    Sep 12, 2017
    39
    Tim Jenner
    I can't see why they shouldn't be fit for purpose - will be very interested to hear how they perform. Ideally it should be a long time before you have anything to report!
    brogenville likes this.
  14. QtrItalian
    QtrItalian Karting
    Jan 22, 2021
    172
    When taking the whole control arm assembly off to be able to oven-heat the ball joint glue (although someone here seemed to state the glue would dry in a day anyhow) is the alignment now off? In otherwords the two bolts holding the control arm to the frame: are they fixated precisely so an alignment can be considered unnecessary? I'm asking prematurely as I have not secured a 612 but as I've done this work on other cars I am mentally considering a future weekend experience in the garage.....Thanks!
  15. brogenville
    2,016
    Robin
    On the 612 (and similar vintage ferraris), the lower control arm camber adjustment is done using metal shims. As long as they all go back in, then the camber remains unaffected.
    QtrItalian likes this.
  16. Teejay
    Teejay Rookie
    Sep 12, 2017
    39
    Tim Jenner
    It might just be worth adding that, if you suspect there is ball joint wear, then it's quite likely the track rod ends will need replacing as well. In which case an alignment check would be needed.
  17. brogenville
    2,016
    Robin
    Changed out the ball joint this evening. The Prekom ball join seems of great quality - very tight and perfect fitment. All stainless steel construction too like Hill, though without PMI I can't say what grade.
    The old Ferrari boots are actually more like the Prekom ones than I thought, as the circlip is bonded into them too. The material is slightly different, and the Ferrari boots have holes in them where the circlip pliers go. Not surprising then that there was corrosion inside the boot then.
    Change out was easy - no special tools- just some big sockets and a bench vice.
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  18. bamaman
    Nov 27, 2015
    650
    Mobile Alabama
    Seals from Hill Engineering will NOT fit without a pucker. We worked like hell and wondered what we were doing wrong until an old thread proved us right. Agree that he Hill Engineering ball joints are the best!!!
  19. brogenville
    2,016
    Robin
    The "pucker" is an interesting comment. Both the seals I removed had a pretty bad pucker, but of the two Prekom seals, the first one (shown above) was slightly puckered, but the second one was perfectly smooth.I packed them both with lithium grease though, and being stainless, the seal should be less critical.
  20. Ricambi America
    Sponsor Owner
    The difference between Hill ball joints and other versions is the thickness of the plating. They'll all last "a while"... but when (not if) the boot gives up the ghost and road grit works inside, the Hill will survive the punishment much much longer.
    This will sound like an odd request.... but @brogenville , can you take a picture of your dirty old balls and post them here? I have seen a lot of balls recently, and some look gnarly (and make noise), while others are still mostly smooth (and still make noise). :eek:
    vr4henry likes this.
  21. Skidkid
    Skidkid F1 Veteran
    8,753
    Campbell, CA
    John Zornes
    I haven't see a request for photos of someone's balls recently. Well done!
    Nospinzone and 599_GTO like this.
  22. powersteer
    powersteer Rookie
    Sep 13, 2020
    29
    Will you guys recommend Hill Engineering ball joints or Prekom?
    What does "pucker" means?
  23. bamaman
    Nov 27, 2015
    650
    Mobile Alabama
    The lip does not seal entirely as though the diameter is too large, leaving a slight pucker,
  24. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    5,761
    Indiana
    JIM
