Replacement 355 Pistons | FerrariChat
Discussion in '348/355' started by lusso64, Oct 18, 2007.
  1. lusso64
    lusso64 Formula 3
    Apr 12, 2004
    1,535
    Simi Valley
    David
    #1 lusso64, Oct 18, 2007
    In light of the ever increasing numbers of 355 owners finding themselves doing full engine rebuilds due to leak-down and low compression problems, Ricambi is pleased to announce the availability of complete piston/ring/pin/liner sets.
    The piston/pin combo weighs 359 grams - the same as early 355s and significantly less than the 376 grams of the later cars and those currently available from Ferrari. Each piston set is balanced and the pistons have ceramic coated crowns and teflon coated skirts. They are matched to new Nikasil coated liners.
    As each set of pistons is matched not only by weight but also to the liner set, these items are only available as a complete set.
    Pricing will be finalized in the next few days, but it will be considerably cheaper than OEM.
    http://www.ricambiamerica.com/product_info.php?products_id=263945
    Please contact us for further information.
  2. Quadcammer
    Quadcammer Formula Junior
    Jun 29, 2005
    500
    Clifton, NJ
    Oliver
    Is it a mahle piston?
    2618, 4032, or Hyper piston?
  3. bpu699
    bpu699 F1 World Champ
    Dec 9, 2003
    17,427
    wisconsin/chicago
    bo
    Cool! If folks keep coming up with replacement parts, these cars will become more and more affordable...
  4. lusso64
    lusso64 Formula 3
    Apr 12, 2004
    1,535
    Simi Valley
    David
    They are in fact a custom make. Definitely not mahle :)
    The design criteria were pretty simple - must be the same size and shape as OEM, same weight as the early pistons, and better quality.
  5. Andi355
    Andi355 Formula Junior
    381
    What is the price for the whole set ?
  6. lusso64
    lusso64 Formula 3
    Apr 12, 2004
    1,535
    Simi Valley
    David
    In my original post I wrote that the weight is 359, not 376.
    The correct weight is actually 376 and not 380+ (In developing these pistons, we examined numerous new pistons from Ferrari and found a variation of more than 10 grams).
    My apologies for this mixup. The 359 number came from my complete inability to perform simple addition :(
    Also, pricing should be finalized today or tomorrow - I'll advise as soon as I have this info.
  7. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Are these forged, cast or pressure cast?? What grade of aluminum are they?
  8. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,424
    CT
    Jay
    Very important question. Either way thanks Ricambi for making these available!
  9. lusso64
    lusso64 Formula 3
    Apr 12, 2004
    1,535
    Simi Valley
    David
    They are forged and the aluminum is a proprietary grade - I'll ask on Monday for more details, but I doubt that the manufacturer will divulge this. Same as Mahle (OEM) - I doubt they'd release that info either. Still, no harm asking...
  10. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    ....forged is good :D...... usually original equipment keeps the alloy formula a secret..... and aftermarket toots about how great their stuff is to get sales moving.... :eek: ....... where are they made?
  11. lusso64
    lusso64 Formula 3
    Apr 12, 2004
    1,535
    Simi Valley
    David
  12. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,743
    Atlanta
    John!
    Looks like a JE coating to me. If so, JE uses a very high grade aluminum and the piston to wall clearances should be able to be a little tighter than OEM with JE, if that is indeed what they are.
  13. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    Tighter does not automatically mean better..... :eek:
    When pistons are forged, the compostion is tighter/stronger. That is why they use a larger clearance during assembly. Which is one of the reasons to warm our cars up before getting "on them"... to allow the forged piston among other things to "expand into" their tighter/operating clearance.
    Cast pistons use a tighter tolerance during assembly (when cold) because they will not expand as much as forged pistons do from cold.
    Either way piston designers come up with their "cold" clearances based on how the piston material expands when it gets to operating temps. :)
  14. Ferraripilot
    May 10, 2006
    17,743
    Atlanta
    John!
    The thermal expansion coefficiency of cast aluminum is undoubtedly greater than that of forged aluminum (2618 forged aluminum with .25% silicon). For instance, a 4.xxx" diameter forged piston could have a piston to wall clearance of .0035-.0004. Cast is considerably higher at .0007-.0009. If we were talking about 4032 aluminum with 11-13.5% silicon, then the expansion rate would be similar to that of cast, but for our applications we would use 2618 or something nearly as hard and that expands very little.
  15. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    above is quoted from this site:
    http://www.babcox.com/editorial/ar/ar129832.htm
  16. lusso64
    lusso64 Formula 3
    Apr 12, 2004
    1,535
    Simi Valley
    David
    #16 lusso64, Oct 22, 2007
  17. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    So which are lighter? you mentioned 376 and not 380.....?
    I am guessing....
    Factory is 380 grams?
    New are 376 grams?
  18. lusso64
    lusso64 Formula 3
    Apr 12, 2004
    1,535
    Simi Valley
    David
    OEM - as removed from several engines, are around 376. New OEM are 380 + (Some very +).
    New from Ricambi - 376, but stronger. The developer has a set that have been reduced by 20 grams each piston. These will be tested over the coming months, and if they don't break, will be an option.
    New headers are next in the pipeline, followed by stainless steel valve sets. The headers are based on the OEM design but not made out of swiss cheese :) There should be stainless headers, and <gasp!> inconel headers. Don't ask about heat shielding at this stage - it hasn't been determined. It will be done right though.
    That's all for now - more info on these once they are out of the testing phase, assuming all goes to plan.
  19. Ferraripilot
    May 10, 2006
    17,743
    Atlanta
    John!
    It all depends on the silicon content in the forged piston. If it has a lower silicon content, it will NOT expand as much as a cast piston. Study on the effects silicon has with ferrous and non-ferrous metals and its thermal expansion coefficiencies and you will understand.
  20. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    :rolleyes:
    Actually you have it backwards, lower silicon content in a forged piston will lend itself to expand more. So in turn more silicon, when uniformly added to an aluminum alloy, hardens the aluminum alloy further and the piston will expand less when heated.
  21. Ferraripilot
    May 10, 2006
    17,743
    Atlanta
    John!
    Silicon does not harden aluminum. You have it backwards. 2618 forged aluminum has .25% silicon and is the hardest stuff JE/Ross uses. SRP pistons (JE's cheaper line) use 4032 which is 11-13.5% silicon and in-turn expands more.
  22. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    :eek: :eek: ............you are confused.... :(
    ...read this from this site: http://www.cpperformance.com/products/engine_parts/pistons.htm
    .....tighter clearances means they expand less....
    and this from this site:http://www.horsepowerfreaks.com/sale/JE/Engine/Pistons
    .....same thing again... :eek:
    ...and again here...... :eek:
  23. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,317
    Canada
    Newman
    Can I see a side shot of the OEM and the custom piston to compare skirt lenghts please?
    I prefer to run pistons tighter rather than have them flop around until warm, it nackers the rings over time whereas a pressure cast high silicon piston that fits with a wall clearance of .0015" runs dead quiet, HC stay low, ring life is better and they can take mild boost so a NA engine will last a long time without piston or ring problems.
  24. jetfixr
    jetfixr Formula 3
    Jun 14, 2007
    1,016
    northeast
    Gone
    JEESH....Kinda went off on a tangent here didn't we.......I'm just glad they are available!!!!!!!
  25. gothspeed
    May 26, 2006
    10,244
    U.S.A.
    goth
    ...true............ I apologize for my contribution to the tangent........:(
