Repairing seat belts | FerrariChat
Discussion in '308/328' started by samba-lee, Oct 28, 2007.
  1. samba-lee
    samba-lee Formula Junior
    Aug 28, 2006
    677
    Manchester, UK
    Lee Griffiths
    Having pulled the rear seat in my GT4 and removed the seat belt because it was partially ripped near the front belt mounting point I figured it was be easy to repait anyway. The rip is close to the sticked over end so if I just cut the bad out, thread it through the mounting buckle and restitch it will be as good as new, albeit about 6" shorter.
    Clearly I'll have to use some substantial thread in the sewing machine and copy the original stitch pattern, but any thoughts on a DIY restitch ?
    Lee
  2. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,618
    South East
    Jimmie
    I'm not sure if you refer to a front belt but it is you may find its an MOT failure item after the repair
    In the UK thread someone has been recommended who does new straps for very little money
    Of course it could be that you do not value you or your passengers lives.......
  3. Protouring442
    Protouring442 F1 Veteran
    Sep 5, 2007
    8,723
    Harriman, TN
    One Stupid SOB
    I don't know about anyplace in the UK, but here in the US there is a place called SnakeOyl that can remanufacture seatbelts. A quick search on the web should turn them up.
    Shiny Side Up!
    Bill
  4. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Don't try a DIY fix on seat belt stitching. It's dangerous. You need a special thread and industrial sewing machine to do it properly, and new seatbelts are not that expensive that it makes any sense to even try repairing a damaged one. If the seatbelt webbing is damaged, buy a new one. There are enough places around that sell replacement belts that you should be able to find one that will work. After all, Ferrari didn't make their own belts, they bought them from a supplier.
  5. bert308
    bert308 Formula 3
    Nov 30, 2002
    1,776
    Roermond Netherlands
    Bert Kanters
    I have front belts from an Alfa 33 in my 308GTS and the rear belts from the 33 in my Lancia Montecarlo.
  6. Protouring442
    Sep 5, 2007
    8,723
    Harriman, TN
    One Stupid SOB
    Here's the link for the Ssnake Oyl site. We had them do custom belts for my dad's '56 Chevy, very nice, legal, and safe!
    http://www.ssnake-oyl.com/
    Shiny Side Up!
    Bill
  7. samba-lee
    Aug 28, 2006
    677
    Manchester, UK
    Lee Griffiths
    Thanks, I was just seeing what the combined wisdom thought - yes of course I was twitchy about the idea of re-stitching.
    The thread in the UK section sounds very expensive for what you get!
    I think just a set of replacement units will suffice. I can get new equivalent for about £20 each from securon.
    Thus taking my rear seat out (which was difficult) was not in vain :)
    thanks
    Lee
    '76 GT4
  8. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    There are a few places on ebay under ferrari parts that sell replacement seatbelts. Give it a look and I bet you will find a set.
  9. Gianluca
    Gianluca Formula Junior
    May 6, 2003
    349
    Centreville, Virgini
    Gianluca Chegai
    I think that although new belts may be inexpensive why not repair the original yourself? The new webbing is readily available and stitching it is not rocket science. A home sewing machine will handle a T-90 nylon thread. Use it with a # 18 regular (NOT leather) needle (this is the largest needle for a home machine). More or less copy the original stitch pattern, lenght etc. Why would this belt be dangerous? Industrial sewing machines are nice indeed for continuos work of this kind but an older home machine will easily sew such belts.
    Again, it may be easier to spend the money and be done with it but a properly remade belt can be made just about as easily.
    Just my thought.
    Gianluca
  10. samba-lee
    Aug 28, 2006
    677
    Manchester, UK
    Lee Griffiths
    My thoughts entirely. I've seen rusty mounting points on old cars which are probably more dangerous than a well done DIY job.
    Now I have the seats out, I may as well put new ones in though as torn belts are only one thing that wears out. I've had cars where the pendulum does not lock out and buckles which don't stay in all the time... Probably best to renew throughout. : )
    Lee
