348 - Repairing NLA tail light lenses? | FerrariChat
348 Repairing NLA tail light lenses?
Discussion in '348/355' started by Wade, Jan 18, 2020.
  1. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Can something like this be repaired or maybe salvaged for "parts"? Considering that 348's tail light assemblies are no longer available as new, at some point maybe an enterprising individual can make something of this?
    This one suffered heat damage some time ago. The red lens is okay except for a small area of deformation. No problems white the white and yellow sections. The back shell is in bad shape on the inboard end.
  2. steved033
    steved033 F1 Veteran
    Apr 12, 2017
    7,710
    Atlanta, GA
    Steve D.
    Man, I wish there was, mine's melted on the yellow side.
    sjd
  3. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    those are from heat internally? Coming from the engine bay?
  4. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Hard to say but mine was most likely due to a missing heat shield on an early car with the twin can exhaust. Initially I suspected that the wrong bulbs were used (brighter but too hot?).
    I replaced the light with a good used one before selling the car.
    Pangea likes this.
  5. wbt
    wbt Karting
    Nov 28, 2014
    231
    New Zealand
    Wayne
    Wrong bulbs, and sitting on the brake pedal for ages and building up heat inside the plastic. Change to LED!!
  6. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    At first I could see that, but in the one pic thats the back up light. One would have to be in reverse or sitting in gear in reverse for a long time. The back up light appears to be more melted than brake light next to it. That has to be heat from the exhaust.
  7. bjwhite
    bjwhite F1 Rookie
    Mar 17, 2006
    4,685
    Seattle, WA
    Brian White
    No LEDs, yuk.
  8. Ferrarium
    Ferrarium F1 Veteran
    5,631
    Central NJ
    Eric
    It is exactly what it is. You can separate the lenses and reuse them, but it appears the lens has some damage as well :(
  9. Pangea
    Pangea Formula Junior
    Mar 27, 2011
    442
    Nick
    As Wade mentioned that damage would be from a missing heat shield which wasn't fitted to early cars. Its shown as part 20 on the later diagram below but not in the early parts manual drawing. Its far more damage than just hot bulbs.
    front-and-rear-lights-41240
  10. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    That's interesting. Here's a close-up of part # 20.
  11. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
  12. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
  13. Pangea
    Mar 27, 2011
    442
    Nick
    Here is the early parts diagram. Part not shown.. The shield must have been a later addition I presume due to lights melting on cars already in circulation. Probably a recall at some point.
  14. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Thanks for the clarification.
    Ferrari going to the single can exhaust was a significant improvement as well.
    Pangea likes this.
  15. Pangea
    Mar 27, 2011
    442
    Nick
    You can see the heat shields in this pic. Silver, underneath the inner part of the light units. Also goes up the inner sides of the clear reverse lamps. Made of the same materiel as the main heat shields. Protects lamps from heat coming out of the centre vent you can see.
    Wade likes this.
  16. Culprit
    Culprit Formula Junior
    480
    Santa Ana, CA
    Ian
    Are the different colors molded as one or are they separate pieces?
    I'm working on remanufacturing the F355 front turn signals now. This could be a next project if there is some demand. Ideally I'd need a set of new/mint condition lights to start with.
    Sent from my SM-G960U using FerrariChat.com mobile app
  17. m.stojanovic
    m.stojanovic F1 Rookie
    2,753
    Malaysia - KL
    Miroljub Stojanovic
    I have a complete RHS good lens that I have carefully cut off a tail lamp, the housing (the back part) of which was damaged by exhaust heat. My RHS tail lamp is very good except that the brake light portion of the lens is somewhat "swolen" in the middle (the PO put a higher wattage bulb) so I am going to do a transplant of the good lens.
    The lens has the following parts:
    The clear part - it is a separate piece; once the lens is detached (cut-off) from the housing, the clear part just comes off the rest.
    The Red part - one piece but the "cat's eye" segment is "inlayed"; this segment was cast separately and then glued (very strongly) into a recess of the main red part.
    The Amber part - cast separately and also strongly glued/fused to the main red part.
  18. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    If we were local to each other I could help you with that. But I can't risk sending them across country.
    P.S. Not for sale at any price while I still own a 348. :)
  19. Ferrarium
    5,631
    Central NJ
    Eric
  20. Wade
    Mar 31, 2006
    32,793
    East Central, FL
    Wade O.
    Thanks.
    Tenacity and/or lots of luck (and timing). Sometimes you win, and sometimes you don't. ;)
