Repairing automatic seatbelt: anyone have a ribbon? | FerrariChat
Discussion in 'Boxers/TR/M' started by raysur, Dec 18, 2020.
  1. raysur
    raysur Formula Junior
    565
    So. Cal.
    Jeff
    It broke after a friend bumped his head getting out. The seatbelt was still retracting and it such a fragile design.
    I couldn't take the ribbon spool apart since something inside was jammed. I ended up buying spare motors from a 1988 Alfa Spider. They are indentical to the Ferrari part. I learned how to take the Alfa unit apart since it was $30 for two instead of $2k for one. Now that I have my stock unit apart I see the damage. The end of the ribbon is shredded. I have a replacement spool from the Alfa but need another ribbon.
    Does anyone have a spare?
    Alfa part is the cleaner spool. Image Unavailable, Please Login
  2. sherrillt
    sherrillt Formula 3
    1,077
    Northern Virginia
    Did your car already have the seatbelt recall done? You might be able to get it fixed for free from the dealer.
    the recall replaced all the seatbelt components, oddly many owners never took their cars in from what I was told years ago.
    ozziindaus likes this.
  3. kartboy1234
    kartboy1234 Formula Junior
    Nov 10, 2014
    694
    Palos Verdes, CA
    Michael L
    Ferrari replaced mine about 6 years ago when I bought my car. Didn't cost me anything.
    Sent from my GM1917 using Tapatalk
  4. sherrillt
    sherrillt Formula 3
    1,077
    Northern Virginia
    Exactly - There was a recall that replaced the entire system to include ecu, belts and rails.
  5. raysur
    565
    So. Cal.
    Jeff
    Thanks for the heads up.
    This side was fixed by the dealer in 2003. I would have gone to the dealership if it failed on its own. But since my friend hit it, this one is on me to fix.
    I also don't want to be afraid of this system. I can get this working even if I have to splice a ribbon from another car.
  6. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    Jeff I have a complete unit I bought used from FerrParts just for the motor and haven't got to swapping it out yet. I haven't unspooled the ribbon fully but I did an inch or so to make sure it would wind/unwind and it was smooth. You are welcome to it...PM me with your address and I'll send it to you. I'm in Nor Cal so you'll have it in time for X-Mas!
  7. raysur
    565
    So. Cal.
    Jeff
    Thank you Tim! This is my Christmas gift! :D
  8. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Nice thing to do!
    What goes around... comes around.
    Merry Christmas - Happy Holidays!
    sherrillt and raysur like this.
  9. raysur
    565
    So. Cal.
    Jeff
    Merry Christmas everyone!
    EZORED and sherrillt like this.
  10. mr308gtb
    mr308gtb Formula Junior
    Sep 12, 2004
    613
    MeestahBig
    Raysur, could you do a DIY write-up about the seatbelt fix. I too don't want to be afraid of the system. It does seem quite fragile. Thanks
    raysur likes this.
  11. raysur
    565
    So. Cal.
    Jeff
    No problem. I will do that.
  12. raysur
    565
    So. Cal.
    Jeff
    Got it working! Thank you so much Tim!
    I have this documented. I just need to make a bracket for the b station and I'll do a write up.
  13. Steve Magnusson
    25,123
    Please include some shots of how the various trim pieces are held on/removed if you can (I'm thinking some of the "fasteners" on mine got broken when FoDenver did the recall work, but I'd like to know more about it before I jump in.)
    raysur likes this.
  14. sag2
    sag2 Rookie
    Apr 4, 2013
    2
    Florida
    Daniel Saginario
    What is the Alpha part number for the motor?
  15. ago car nut
    ago car nut F1 Veteran
    5,265
    Madison Ohio
    David A.
    Is it worth converting to manual like European cars?
  16. raysur
    565
    So. Cal.
    Jeff
    Unfortunately I can't pull a number off of them. I did get them off a late '80's Alfa Spider (US Spec). What exactly did you need?
