Repair Brushed Aluminum Scratch? | FerrariChat
Discussion in 'Technical Q&A' started by bwiele, Aug 24, 2007.
  1. bwiele
    bwiele Formula Junior
    Mar 21, 2007
    256
    West Harrison, NY
    Brian
    I have a 2002 360 which I bought in March. The car had 700 miles on it and is pretty much mint (I've done all the service to get everything up to date). The interior is flawless, apart from a 1" vertical scratch in the middle of the brushed aluminum door pocket panel on the driver's side door. It's not deep and is pretty thin (probably 1/32"), but I notice it every time I get in and out of the car. Is there anything that I can do to repair or improve the appearance of literally this one interior flaw?
  2. Ricambi America
    Sponsor Owner
    Brian -
    I only offer this with EXTREME caution... some of our kitchen trim is brushed aluminum, and it scratches far too often. I have found that using "Bar Keepers Friend" (looks like Comet, but very gentle) works wonders.
    If you try this on your car, PLEASE test in a very very inconspicuous area, because I have no idea what type of finish/clear Ferrari might have used on the surface of those parts.
    http://yhst-55367440605114.stores.yahoo.net/barkefrpo.html
  3. bwiele
    Mar 21, 2007
    256
    West Harrison, NY
    Brian
    Thanks Daniel. I don't think I'll even try that because the scratch is too deep to think about bringing the material down on either side of it. I really need to fill in the scratch to raise the level. Even some silver metallic paint might do the trick to improve it by 75% if I can get a similar color....
  4. BigTex
    79,321
    Houston, Texas
    Bubba
    Can't you replace just that part?
  5. Argento839
    Argento839 F1 Veteran
    Oct 21, 2005
    9,103
    +1
  6. Ricambi America
    Sponsor Owner
    Depending on the assembly number of his car, he's either at $1K -- or much above $1k. Either way, it's pretty expensive.
    If originality isn't a huge concern, I'd suggest carbon fiber might be a reasonable alternative from one of the Fchat sponsors
  7. dkny
    dkny Formula Junior
    Jun 8, 2005
    575
    Kingston, NY
    dave
    Do you have a picture of the part/scratch. A good machine shop could refinish the piece. most aluminum interior pieces are usually anodized, so it would have to be replated, but at a cost of $1k to replace, it might be a resonable alternative
  8. Mark 328
    Mark 328 Formula Junior
    Nov 6, 2003
    510
    Orange, Ca
    Mark Foley
    Just a thought...
    Alsa Corp. has a lot of stick-on foils including brushed Alum.
    Perhaps they would have something you could apply over the panel?
    A lot of those films can be applied with soapy water and a squeege using a heat gun to form it.
    http://www.alsacorp.com/products/sheetingfx/brushed.aluminum.htm
    They are pretty good about sending-out samples.
    Mark
  9. SoftwareDrone
    SoftwareDrone F1 Veteran
    Sponsor Owner Rossa Subscribed
    Jan 19, 2004
    7,781
    San Jose, California
    The piece you are referring to might look "brushed", but it is indeed painted. Depending on the assembly number, it could either be the earlier, lighter colored, "rough" finish, or it could be the slightly darker, later, smoother finish. My 2000 has the more rough finish. I had a huge gouge in the center console. After some research, I took it off of the car and sent it to Premier in L.A. I sent it to them on Monday, and my Friday afternoon it was on my doorstep with the gouge filled in and it was repainted the exact same shade and texture (roughness). It was perfect, and the price was unbelievably cheap. They said that people send in their center console and door panels (which are a matched set) to be repainted, all the time.
    Hope this helps.
  10. KENCO
    KENCO Formula 3
    Nov 1, 2006
    2,396
    FL
    KJG
    Just try it on your fridge first!
  11. f355spider
    f355spider F1 World Champ
    18,026
    Another product worth experimenting with is various grades of "sanding" type Scotchbrite pads...that is what I saw a sheetmetal guy use to finish ss with.
  12. Ricambi America
    Sponsor Owner
    I have used it on the fridge, dishwasher, and stove. Works like a champ.
  13. Valence
    Valence Formula Junior
    Jan 20, 2004
    883
    Charlottesville, VA
    Chris& Brian Coffing
    Yeah, this is a funny thread - these are indeed painted! No rubbing, sanding, anodizing, or anything like that will help. If you're skilled at paint touch-ups, you might be able to fix it yourself, otherwise send it to Premier like Softwaredrone says.
  14. ZINGARA 250GTL
    ZINGARA 250GTL F1 World Champ
    Jun 21, 2002
    17,499
    PA
    Ken
    Good product. You could use it with extremely fine steel wool running with the direction of the brush pattern. We keep our stainless kitchen sink looking new this way.
  15. jdd
    jdd Rookie
    Apr 7, 2007
    19
    Does anyone know how I can contact Premier, i.e. email, website, phone number? Thank you for your help.
  16. Valence
    Jan 20, 2004
    883
    Charlottesville, VA
    I think they advertise in Forza, otherwise post in California section.
  17. bwiele
    Mar 21, 2007
    256
    West Harrison, NY
    Brian
    Thanks for all the responses to this - I've been off-line for the weekend so I haven't responded. The scratch is not bad enough to warrant replacing the panel, and certainly not bad enough to refit the car in carbon fiber. I'll try to get a picture with a macro lens so you can see the scope of the "problem." It's pretty minor. I will look at it again with the knowledge that it is a painted surface. Perhaps I could get some touch-up paint from Premier (or maybe even my local dealership), mask off around it and touch it up with the aid of some Langka. It is definitely small enough that that might just do the trick. Pictures to follow within a couple of days. If I think I can make it work, I'll take pictures and do a write-up if anybody cares. -Brian
