Removing front brake rotors ('88 3.2) | FerrariChat
Discussion in 'Mondial' started by decampos, Dec 12, 2021.
  1. decampos
    decampos Formula Junior
    460
    Los Angeles
    Ben
    Hello all. I have conflicting information about this so I was wondering if someone absolutely knows for sure what the deal is in removing the front rotors for my model year.
    I need to get the rotors off to resurface them, do they just come off easily and not take the bearings with them? Or are the bearings pressed into them and I have to destroy the ring nut to get it off?
    Gosh I hope it is the former.
  2. fatbillybob
    Aug 10, 2002
    28,557
    socal
    Rotors come off hub. Remove caliper. Remove pointy retaining pins. Bang rotor with BFH and rotor comes off hub.
    decampos likes this.
  3. MvT
    MvT F1 Rookie
    May 25, 2013
    4,260
    The Netherlands - NH
    Tijn
    I have a 3.2 as well. It's very straightforward to take off the caliper.
    What kind of conflicting info if I may ask?
    Have a look at my video from 1min.50sec
  4. jkstevens2
    jkstevens2 Formula Junior
    Aug 25, 2015
    279
    Winter Park, FL
    JK Stevens
    Your springs and control arms look like mine.........they look like something on the bottom of a military hum-V. I cant figure out for the life of me where all this junk and dirt and grime came from. I have blamed the previous Oklahoma owner who drove my 86-3.2 on a farm. They have this grey brown clay in oklahoma and it everywhere on the bottom of my car.
    Please post pictures of your job. I am very interested in the process and this is one of the jobs I am planning in the near future.
    Thank you
  5. decampos
    460
    Los Angeles
    Ben
    Thanks for the replies, all very helpful.
    Just that some people have said that to take the rotor off, I need to unpeen (then replace) that big nut, then (ugh) I have to press out the bearings from the rotor, then when I'm done, reinstall and repack.
    Then others have said easy-peasy it just comes off and you don't have to mess with all that junk.
    I know 308s (at least my one) has the less friendly set up, but there's talk that a '88 Mondial is different.
    Unfortunately that link isn't working for me.
  6. MvT
    MvT F1 Rookie
    May 25, 2013
    4,260
    Tijn
    That's incorrect, you just need to take of the caliper and the mount.
    Try again. it was set to private. I am almost sure I didn't as I have 184 views on it, but YT changes sometimes some settings
  7. decampos
    460
    Los Angeles
    Ben
    It works now, thanks. Good, informative video.
  8. 350HPMondial
    350HPMondial F1 Veteran
    5,282
    Edwardo
    Hint
    Use a piece of wire coat hanger to hang the caliper from the spring,,, so ,, as not to over stress the brake hose.
    Easy job.
    MvT likes this.
  9. 350HPMondial
    5,282
    Edwardo
    And,, while it’s all apart. Replace the pads.
  10. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,384
    San Carlos, CA
    Mitchell Le
    Who are these experts with bad information?
  11. decampos
    460
    Los Angeles
    Ben
    I changed the rotors and am happy to report that it was indeed as simple as we all thought it would be. Thanks for all your help. The only slight complication was needing to use a puller to get the old ones off as they would not move, but it was not a problem. I bought new rotors in the end as the old ones were worse than I thought. Here's some photographs for fun:
    The old screwdriver in a vent trick.
    Side by side of the old with the new.
    With some grease added so they won't be so hard to remove in 33 years.
    New pads and fresh fluid though these pads don't have the wear sensor.
    MvT likes this.
  12. AndruL
    AndruL Karting
    Apr 4, 2018
    234
    AndruL
    Hi, would you mind sharing where you got the rotors from and how much were they? Thanks.
  13. decampos
    460
    Los Angeles
    Ben
    I just checked with the terms and rules and it doesn't look like I'll be contravening anything by revealing that I got them from Euro Spares in the UK. They've never been my go-to for parts but they had a really good 'special offer' deal on them. I also got the pads from them. Shipped really fast too.
  14. AndruL
    AndruL Karting
    Apr 4, 2018
    234
    AndruL
    Thanks!
  15. MvT
    MvT F1 Rookie
    May 25, 2013
    4,260
    Tijn
    New discs and pads are always nice, but what was wrong with the old ones? They were to thin or wobling?
  16. decampos
    460
    Los Angeles
    Ben
    The old rotors had quite a lip on them (more than 1mm I would say) and I got a good deal on the new ones. Plus, it's Christmas! Merry Christmas, car.
    So far brake feel is nice and solid and no ear-piercing squeal (yet).
  17. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,907
    Isle of man- uk
    Best way to go, by the time you have machined them you might as well replace them.
