remove part no. 108332 | FerrariChat
Discussion in 'Boxers/TR/M' started by turbo-joe, Jul 15, 2019.
  1. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,929
    romano schwabel
    just doing a major and also like to get plated several parts. so I wanted to remove the "terminale per sede candela" but had problem to get them out. so after I got advice from paul newman I made a special tool and it was even with this tool not so easy to remove those parts but they came out :)
    Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login Image Unavailable, Please Login
  2. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Plug terminal?
    What is it? I don’t recognize the part.
  3. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,155
    Canada
    Newman
    Spark plug tube.
    Good job. They’re held in with loctite
    vincenzo likes this.
  4. turbo-joe
    Apr 6, 2008
    8,929
    romano schwabel
    have not known that they have been in with loctite, that was the reason I had problem first to get them out and I did not want to damage them.
    today glas blasting and then to new plating with a lot of other parts
  5. turbo-joe
    Apr 6, 2008
    8,929
    romano schwabel
    on those comes the black rubber boot that no water may go inside down to the sparkplug
  6. pshoejberg
    pshoejberg Formula 3
    1,696
    Denmark
    Peter H
    Excellent write up, thanks. That job is up on my do do list this fall, so nice to have some inspiration.
    Best
    Peter
  7. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    Please post pics when you're done with the install so we can see how it all looks!
  8. turbo-joe
    Apr 6, 2008
    8,929
    romano schwabel
    this will take some time, may be 3 weeks?
  9. Ludwig
    Ludwig Formula Junior
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
    turbo-joe likes this.
  10. Newman
    Dec 26, 2001
    14,155
    Canada
    Newman
    New exhaust valves?
  11. Ludwig
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
    These were new at prior rebuild that I did not do. About 2000 mi on the engine from that "rebuild" -new pistons valves bearings and 1 liner at that time.
    The valves all looked great as were the guides. Just new seals and basic valve job.
