Remove Door Pull Passenger side | FerrariChat
Discussion in '360/430' started by Sean F., Nov 16, 2019.
  1. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,060
    Kansas
    Sean F
    Do you have to remove the entire door panel to get the handle off the passenger side? I'm refering to the actusl pull handle that is only on the lassenger side.
    This is on a 2002 360
    Sent from my SM-P580 using FerrariChat.com mobile app
  2. mello
    mello F1 Veteran
    5,040
    CA Bay Area
    Steve
    Yes, you have to remove the door card to disconnect a linkage rod. Here's a picture of the door handle, driver side on a 2003 360 Spider.
    tifosi101 likes this.
  3. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,060
    Kansas
    Sean F
  4. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,060
    Kansas
    Sean F
    For anyone who is following along, you do have to remove the door panel. There is a single bolt on the back side that has to be removed.
