Removal of 308 rear panel | FerrariChat
Discussion in '308/328' started by RAC911, Jul 20, 2020.
  1. RAC911
    RAC911 Karting
    196
    Arizona
    Ralph Cacace
  2. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,257
    Montana
    Kim
    It’s been a while but if I remember correctly there’s six 10 mm bolts that hold that bumper shroud (Diaper) in place. Two on each side and then two that were harder to access under the rear bumper lip. I Believe I used a box end wrench and possibly loosened the four bumper strut bolts to gain access. :) Away from home at the moment so I can’t pop into the garage and look.
  3. mxstav@comcast.net
    Nov 24, 2005
    200
    Green Oaks, IL
    Mark Stavropoulos
  4. mxstav@comcast.net
    Nov 24, 2005
    200
    Green Oaks, IL
    Mark Stavropoulos
    Photo annotated for clarity.
    308 milano likes this.
  5. RAC911
    RAC911 Karting
    196
    Arizona
    Ralph Cacace
    The rear bumper blocks getting to the four bolts holding the piece. As shown in the picture, the outer nuts for the bumper are accessible, but the inner bolts cannot be turned. Question: how is the rear bumper removed? Left or right rubber protection blocks access to the inner nut. If the bumper is loosened or removed the center panel will come out. Image Unavailable, Please Login
  6. mxstav@comcast.net
    Nov 24, 2005
    200
    Green Oaks, IL
    Mark Stavropoulos
    My car has U-type speed nuts to fasten the rear cover, not hex nuts.
    Now I understand your dilemma.
  7. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,527
    California SF bay area
    Paul
    You don’t need to remove the bumper. A 1/4 inch drive 10mm socket on a six inch extension will reach the 4 upper mounting bolts. It’s a bit of a squeeze but it will fit in there. The picture you posted is of the bumper mounts, nothing to do with the shroud.
  8. RAC911
    RAC911 Karting
    196
    Arizona
    Ralph Cacace
    i will try, but if you ever had to remove the bumper, how would you do it.
  9. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    I had mine off for repainting few months ago and don't recall any issues at all on my '79 US car.
    Doug
  10. RAC911
    RAC911 Karting
    196
    Arizona
    Ralph Cacace
    I used the 1/4 inch drive 10mm socket on a six inch extension will reach the 4 upper mounting bolts. I found out that the European do not have this large part shown earlier. Therefore, removal of the bumper is easy.
