430 - Regular F1 vs Scud F1 | FerrariChat
430 Regular F1 vs Scud F1
Discussion in '360/430' started by c6vette, Aug 25, 2019.
  1. c6vette
    c6vette Karting
    Jun 4, 2009
    118
    St. Petersburg
    Forgive me if this has been asked before but I tried searching and didn't find anything. What are the mechanical/electrical differences between the regular F430 F1 and the Scud F1 trans? I know the Scud shifts much faster but my question is why? I really enjoy my F430 but can't help but think how much better it would be with a faster trans.
  2. f355spider
    f355spider F1 World Champ
    18,027
    Simple google search turns up this...
    From the Ferrari website: https://auto.ferrari.com/en_US/sports-cars-models/past-models/430-scuderia/
    F1-SuperFast2 is the latest development in the F1 Gear used on all Ferrari models. Reducing the time needed to change gears, expressed and calculated as an interruption to acceleration (not merely as the time required to select a new gear) is based on the “parallelization” concept of the times necessary for the various operations:
    - cutting torque and disengaging the clutch;
    - disengaging, selecting and engaging the gear;
    - engaging the clutch and returning torque.
    These operations are usually performed sequentially. With the F1-SuperFast2, a fully integrated and totally innovative software management system for the engine and gear-shift system allows the gears to be disengaged/engaged at the same time as the clutch is opened and closed. The result is that the 430 Scuderia benefits from a further-reduced gear-change time which can be as low as 60 ms.
    This figure, the shortest in the Ferrari range, guarantees maximum sports-car feel, but without penalising the comfort of the driver or passenger. The 430 Scuderia transmission maintains the rear, longitudinal 6-speed architecture (plus reverse), all equipped with multiconal synchronizers, which assure excellent performance when changing gears. The gears and bevel type final drive have been modified both in speed ratio and geometry in order to optimize the application of the torque delivered by the engine which guarantees faster acceleration.
    Flea7 likes this.
  3. c6vette
    c6vette Karting
    Jun 4, 2009
    118
    St. Petersburg
    I was looking for more info on what parts or software is different. Not a vague description of why it’s better
  4. f355spider
    18,027
    You may be happier with the information in the thread here https://www.ferrarichat.com/forum/threads/430-does-not-shift-fast-enough-for-me-can-i-get-a-challenge-430-tcu.311702/
    Bottom line, you cannot "upgrade", as each change in the software on the 430 included technical changes to the transaxle that (apparently) require them to be done at the same time, and would also include changing engine ECUs, and F1 wiring loom according to Mstewart. 2008 and 2009 F430 have slightly faster shifting in Sport and Race mode at greater than 40% throttle input. 120ms versus 150ms. As of course the 16M and Scuderia a claimed 60ms at greater than 40% throttle input in Sport and Race
  5. c6vette
    c6vette Karting
    Jun 4, 2009
    118
    St. Petersburg
    Thanks f355spider that is an interesting thread!
  6. ShineKen
    ShineKen F1 World Champ
    19,343
    Southern California
    Nostradamus
    Gears are also different between the 2 trans.
    Having driven both, the F430 feels like a GT shift. The Scud feels like a race shift. The 60ms difference is next level.
  7. 24000rpm
    24000rpm F1 Rookie
    I've been doing research on the transformation from 430 f1 to superfast II.
    I've 1 thing not too sure .
    If I did a part-to-part swap from a f430 coupe to a scud EXCEPT the the cat back exhaust, am I going to run into a problem?
  8. RichardCH
    RichardCH F1 Rookie
    4,661
    The key point is that the superfast is fabulous but its most certainly not worth 100k
  9. RichardCH
    RichardCH F1 Rookie
    4,661
    hence SCUDs are overpriced vs F430s
  10. ihavearedferrari
    ihavearedferrari F1 Rookie
    Nov 23, 2007
    3,316
    Adam
    Out of general interest is the 599 F1 the same as F430 F1? or does the 599 have superfast2?
  11. ShineKen
    19,343
    Southern California
    Nostradamus
    It's probably more like $50-75k difference in the U.S
    You still have:
    1. Cooler looking front & rear bumpers, sideskirts, carbon mirrors, carbon rear diffuser, front lip, headlights in some cases.
    2. Carbon race seats
    3. Carbon & alcantara trim
    4. Carbon engine bay
    5. More powerful and responsive engine
    6. less cats, less header issues, less CEL issues to work around
    7. Better looking wheels
    8. Better brakes
    9. Stripes
    10. Carbon door cards
    That's gotta be worth at least $50k.
    Flea7, Shark01 and I'm 360 Canuck like this.
  12. f355spider
    18,027
    Don't forget the suspension upgrades
    ShineKen likes this.
  13. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,751
    England
    Mark
    The Scud is under priced IMO. The list of changes is huge and the driving experience still offers a lot more character and fun than the later (more capable) stuff.
    ShineKen, Shark01 and I'm 360 Canuck like this.
  14. tazandjan
    39,007
    599s have Superfast I, with min shift times of 100 ms or 85 ms (HGTE). GTOs had Superfast II with min shifts of 60 ms.
    Scuds are definitely not overpriced vs the F430. You get what you pay for in this case.
  15. Shark01
    Shark01 F1 Veteran
    Jun 25, 2005
    6,351
    LOL.....thumbs up for consistency,big entertainment factor.
    Need to get you and Scuderia09 into a cage fight.
    freshmeat, LightGuy and f355spider like this.
  16. MaranelloDave
    MaranelloDave Formula 3
    Apr 27, 2010
    2,203
    LA
    Dave
    Two men enter, no man leaves
    freshmeat likes this.
  17. freshmeat
    freshmeat F1 Veteran
    Aug 30, 2011
    7,271
    lololol good one Dave.
