Redesigned Fuse Block | Page 3 | FerrariChat
Discussion in '308/328' started by TurtleFarmer, Apr 5, 2020.
  1. Tustin308
    Tustin308 Rookie
    May 20, 2019
    39
    Tustin, CA
    Arthur Trejo
    I am interested in a fuse block as well 84 QV
  2. absostone
    absostone F1 Veteran
    9,246
    Gt4 Gt4!
    CAM-79 likes this.
  3. built2grind
    built2grind Formula Junior
    410
    The Peninsula
    ANDREW
    Me too.........
  4. skipgt4
    skipgt4 Formula Junior
    Nov 3, 2003
    441
    GR Michigan
    Charles VDB
    just checking in to see how things are going.
    built2grind and absostone like this.
  5. Doogie
    Doogie Rookie
    Nov 19, 2015
    47
    Cincinnati
    Douglas Menkhaus
    I'm interested also, '78 US GTS! Great project! Doogie
  6. lm2504me
    lm2504me Formula 3
    1,086
    Nipomo, CA
    Richard
    Me too. 78 308 Gts.
  7. TurtleFarmer
    TurtleFarmer Karting
    215
    Jason S
    Thanks everyone for your patience. The assembly jigs were being mfg'd as a favor by a friend--and, well, they were prioritized accordingly. I ended up machining the jigs myself (after waiting for so long), which meant the whole process wasn't as quick as we were hoping.
    First article is complete (still need one more minor tweak on the base plate). Also still need to put together some installation notes. Below are some shots of the entire assembly.
    A quick recap on the features:
    - Uses modern mini-blade fuses (ATM)
    - Single fuse block replaces the two block solution from the OEM
    - Spare fuse holder for three extra fuses
    - No fuse splitters required; all OEM connectors should have a direct connection to the board
    - Works with all generation 308s (GT4, GTS/GTB, GTSi/GTBi, QV) and likely 512BB
    - LEDs to indicate working fuses, enabled with push-button (fuse supply-side must be powered)
    A fuse cover is still in the works, but given demands on time, it's likely at least another month before I'll have that design ready to test out. You'll note that cylinder in the center of the board (w/yellow Kapton tape on the top) is the planned mount to provide positive retention for the cover.
    I'll send out another note in the next couple days with pricing and contact info (didn't have time to put up a webstore, so we'll start off doing this 2010-style: email + paypal). In this first run, I only ordered ten boards so if demand outpaces supply, it'll be a bit before the next run.
  8. TurtleFarmer
    215
    Jason S
  9. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,534
    Cerritos, CA.
    Looks excellent Jason! Please put me down for a set for my 84 QV US version, thanks.
  10. absostone
    9,246
    Im interested for Gt4 but really want the stock covers to fit.
    tf308 likes this.
  11. built2grind
    410
    The Peninsula
    ANDREW
    I’m still in for one. 1984 US 308 GTS QV. I can wait for the fuse cover design to finalize. Thanks for such a great offering. Well tooled.
  12. Jonny Law
    Jonny Law F1 Rookie
    3,174
    Over yonder.
    IT Guy
    I completely lost track of this thread. I'll take one for a '81 GTBi. I can get a cover later.
  13. TurtleFarmer
    215
    Jason S
    Hey all,
    Finally ready to start shipping out the design to folks. As mentioned before, this will just be the fuse board itself--cover is still in development.
    Pricing is set at $325 + shipping. Working on a website, but for now please email me directly: jstinson1 at yahoo.com
    I'll need to get address, model + year and other info--will use Paypal for transaction.
    As mentioned before, this first run is only ten (well, nine, since one of them goes in my car), so if we go thru them quickly, I'll need to order more.
    Thanks,
    Jason
    mcimino likes this.
  14. TurtleFarmer
    215
    Jason S
    Oh, almost forgot. I'd wanted to perform some validation tests on the design, which I finally was able to get into the shop to perform last week. Everything passed fine, but some of the results might be of interest for those folks that still have the original fuse blocks in their vehicles.
    One of the tests was to validate the resistance of the design with an accurate milliohmeter. This is a piece of equipment that very accurately can measure the resistance of a circuit. The test setup used a lab calibrated HP 4338B milliohmeter with a 4 point test setup to do the measurements:
    • New design: average resistance was 15mohms with a variance of 2mohms across all fuse circuits on two separate boards. The fuse itself measured out to ~12mohms, so the design itself is only adding ~2mohms of add'l resistance. The design target was less than 5mohms.
    • Original Ferrari fuse blocks (my fuse blocks are still in very good shape): average resistance was 300mohms with a low of 100mohms and a high of 1.2 ohms.
    Or, put more simply, for a load such as a window motor (let's call it ~5A @ 12V):
    • The new design has approximately a 0.075V voltage drop across the circuit -- meaning your window motor (or any other load) would see near battery voltage (if it weren't for the crappy wiring harness and downstream connectors....).
    • The original design would generally have a 1.5V voltage drop across the fuse block (or even as high as 6V) -- meaning your window motor would be very sad. This also means the original design would be dissipating 7.5W (or as high as 30W) in the fuse block itself for just this particular fuse circuit (other fuse circuits will also be dissipating power), which is why these blocks tend to melt over time cuz power dissipation = heat.
    This shouldn't be news to anyone, of course, as all of the other replacement fuse block designs over the years have pointed out the weakness in the original design. But thought you'd be interested in the numbers.
    Here is the setup for the new design:
    And the setup for the original design (note this particular circuit was at 530mohms--there was a lot of variance from circuit to circuit):
    308 milano, mcimino and thorn like this.
  15. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,463
    Tulsa, OK
    John McDermott
    Wow that is a significant voltage drop over the original design.
  16. absostone
    9,246
  17. Saabguy
    Saabguy Formula 3
    1,759
    Shreveport, LA
    You know, it looks like you may know something about this, and not because you are an ME either. ;-) I have a lot of tools and measuring device but I had never heard of a milliohmeter.
    Lester
    absostone likes this.
  18. Dr Tommy Cosgrove
    35,338
    Birmingham, AL
    Tommy
    May I get on the list for my 84 ?
  19. absostone
    9,246
    When will there be a cover made
  20. 2cam
    2cam Formula Junior
    Aug 28, 2014
    743
    Austin, Texas
    MikeS
    Great work Jason! This looks fantastic! Is there any chance that you could do a board for the Mondial? ;)
    2cam
  21. TurtleFarmer
    215
    Jason S
    Catching up on responses:
    - @Saabguy : Milliohmeters are pretty standard equipment in battery design/development where internal resistance is a critical test parameter. And, yeah, I've spent a lot of time around batteries.
    - @Dr Tommy Cosgrove : Please send me an email (jstinson1 at yahoo.com) if you'd like to place an order for a fuse block. It's easier for me to track orders and handle the transactions thru email (vs. fchat)
    - @absostone : Cover is still in design; my day job has been a bit crazy last few weeks, but hoping to find some time to complete in coming weeks.
    - @2cam : Thanks for the kind words and let's see how the 308 process goes. From what I've seen on the Mondial, it's a full PDU (power distribution unit) including both the relays and the fuses as well as power routing. The existing aftermarket designs look quite well done; while it might be nice to move to mini-blade fuses, it's not clear that would be enough value to warrant yet another aftermarket design.
  22. skipgt4
    Nov 3, 2003
    441
    GR Michigan
    Charles VDB
    I received my fuse board yesterday and couldn’t be happier. Delivery was quick, packaging was great, and the board looks better in person than in the photos. Also came with a helpful “How to” document. I hope to get it installed this weekend.
  23. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,463
    Tulsa, OK
    John McDermott
    Sent PM but no response. Have they all sold?
  24. TurtleFarmer
    215
    Jason S
    @skipgt4 Thanks for the kind words, good luck this weekend and let me know if you run into any issues!
    @kiwiokie Still have a couple left. I re-responded to your PM, but the short of it is to send me an email (jstinson1 at yahoo dot com) with the request. It's much easier to track than thru fchat.
  25. Dr Tommy Cosgrove
    35,338
    Birmingham, AL
    Tommy
    Got mine.
    This is a very nice piece. Great work!
