Red Rubbing Compound...Turtle Wax?? | FerrariChat
Discussion in 'Other Off Topic Forum' started by bmwm3, Mar 25, 2006.
  1. bmwm3
    bmwm3 Formula Junior
    Jun 6, 2005
    751
    Laguna Hills, OC!
    The webpage says Red rubbing compound is good for older cars to remove oxidation and scratches.....
    How old is old?
    I don't know what i'm looking for to see if i should use it.
    My brother and I are trying to remove some light scratches from the hood of his
    2002 Acura Rsx the car is black.
    Any help would be appreciated
    Thank you
  2. CornellCars
    CornellCars Formula 3
    Mar 24, 2005
    1,102
    South Florida
    Jason
    MHO Turtle Wax red is WAY too aggressive for light scratches and will leave some serious swirls/scuffs (as is white for that matter). Find a good, fine (1600-2000 grit) polishing compound, not a rubbing compound, and go to town. I'm actually pretty pleased with Ardex stuff, but I don't know where to buy that other than from my local Ardex truck (dealer wholesale)...that said, you should be able to find something decent at Pep-Boys or comparable, though I can't find anything worthwhile at Discount Auto or Autozone.
  3. bmwm3
    Jun 6, 2005
    751
    Laguna Hills, OC!
    so a white compound (polishing) is too much for it as well?
    hmm so what cases would a white polishing compound be use for?
    Well i guess i'll stick to the Mcguires # 1 scratch remover and paint cleaner.
  4. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    Almost all my cars are old enough to have laquer paint on them with no clear coat.
    As such a fine cut compound really works well on laquer to take out rain spots/fine scrathes etc.
    With the more modern paints that are multi staged and cleared, (obviously I'm not so familiar with) I'm not sure you'd want to use anything with a grit in it...
