Recommendations for good at-home garage car lift? | FerrariChat
Discussion in 'Ferrari Discussion (not model specific)' started by FerrariIcona, Oct 2, 2022.
  1. FerrariIcona
    FerrariIcona Karting
    243
    Yingli Cheng
    For the folks that have lifts at home, was wondering which models they had and if they would recommend them, and the pros and cons of their lift they've experienced. Taking into account functionality, price, ease of installation, etc. Thanks!
  2. Dave Bertrand
    Dave Bertrand Formula Junior
    823
    Castle Rock, CO
    Talking about a 4-post storage lift, or 2-post service lift?
  3. FerrariIcona
    243
    Yingli Cheng
    Want to be able to do service in a home environment. Otherwise open to anything device that lifts the vehicle.
  4. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,938
    I use a twin-post, 9000-lb Bend Pack and am very happy with it. Make sure to get the asymmetric arms
    020147, FerrariIcona and tbakowsky like this.
  5. tbakowsky
    tbakowsky F1 World Champ
    Sep 18, 2002
    19,826
    The Cold North
    Tom
    2 post for service is the only way. 4 post for storage..
    JAM1, AD211, rob lay and 2 others like this.
  6. rwk360
    rwk360 Formula Junior
    Aug 26, 2005
    394
    Pebble Beach, CA
    R W Kenton
    Also, ideally get a 220V unit if your garage is wired for such; 110V lifts are nauseatingly slow.
    plastique999 and FerrariIcona like this.
  7. sinistermist
    sinistermist Karting
    Mar 23, 2016
    104
    Picked up a champion auto lift yesterday. 4 post.
    Install is mostly done. The post itself is good quality. The instructions are a poor joke. Was a 6 hour road trip and then 4 house to set it up yesterday. Too worn out today to finish adjusting.
    I got this for storage. For that it will be great. For in home servicing get a two post.
    FerrariIcona likes this.
  8. SirTony76
    SirTony76 Formula Junior
    Jan 18, 2004
    301
    MN
  9. campbell360
    campbell360 Formula Junior
    341
    Michiana
    Doug
  10. bernieb
    bernieb Karting
    Apr 16, 2007
    212
    Alberta Canada
    Bernard J Bonertz
    Hard to remove undertrays on a 2 post lift. Not to mention crawling on your belly to locate and hit lift points. I have a 9,000 2-post Bend Pack which I would happily swap for a good 4-poster with bridge jacks.
  11. vincep99
    vincep99 Formula 3
    Jun 8, 2009
    1,938
    bernieb is correct that it's hard to remove the undertrays on a 2-post lift. I have to raise the car, loosen the tray, and set the wheels down on 12"-high blocks to be able to get the undertray off.
  12. jjtjr
    jjtjr Formula Junior
    Aug 29, 2016
    744
    Vermont
    john truskowski
    I bought a 2 post Rotary 220V with the top bridge (keeping floor area open between posts) The only complaint I have is it doesn't go low enough. In order to set up my 355, I have to drive onto 2X10's to fit the lift arms under it. But that is probably true of most 2 post asymmetrical lifts.
  13. Ngcanada
    Ngcanada Formula Junior
    May 16, 2016
    741
    Ottawa Canada
  14. AandSC
    AandSC Formula Junior
    916
    Jax, FL
    Allen
    HH11 likes this.
  15. rob lay
    rob lay Administrator
    Staff Member Admin Miami 2018 Owner Social Subscribed
    Dec 1, 2000
    63,269
    Southlake, TX
    Rob Lay
    I agree, but would say many situations the single post is best for storage. That's what I went with because of limited room. It has same capacity, but a little more expensive.
  16. rob lay
    Dec 1, 2000
    63,269
    Southlake, TX
    Rob Lay
    I like that! Best of both.
    AandSC likes this.
  17. EastMemphis
    EastMemphis Formula 3
    May 25, 2019
    1,822
    Memphis, TN
    #17 EastMemphis, Oct 5, 2022
    I have a Mohawk 10k 2 post lift that I installed myself. It's an incredibly rugged unit and as far as I know, the only hydraulic unit that fits under a 10' ceiling. The unit is extremely heavy and since it's hydraulic, the lines can run under the floor (hard) or over the ceiling (easy) with only a 1/2" loss in lift height. The pads go down to 3-1/2" so it fits under my 360 Spider easily. With the 10' ceiling and the low height of the Spider (46" from the floor), I can raise my car high enough so that it has a clear 6' underneath. No bending over.
    The big negative with the Mohawk is the availability. They are made to order so when you order one, you get in a long line that for me lasted three months. That was right after the Covid mess started so maybe they have shorter lead time now. If I had to do this again I would opt to space the towers a little farther apart. The 360 is a pretty wide car and the Mohawk factory specs make it tight fit. Spacing the towers just six inches further apart would have made it simpler.
    The Mohawk is the cat's meow of lifts. It's probably twice as heavy, if not more, then the Bendpak units and is made of girder beams. The hydraulics need only the typical hydraulic service and should go 20 years without changing anything. The cables that the Mohawk uses are strictly safety devices in case of failure and are easy to handle and short in length. They just dangle and have no tension on them. The Bendpak is cable driven and those cables will fray and eventually fail. I hate cables myself so that's why I went with the three times more expensive Mohawk. All in, the Mohawk cost about $10k. 220v required. Mohawk is made in the USA. Weight is about 1800 lbs.
  18. rob lay
    Dec 1, 2000
    63,269
    Southlake, TX
    Rob Lay
    Mine is American Custom Lifts. Currently one like mine is $20-25k.
  19. RedTaxi
    RedTaxi F1 Rookie
    3,307
    New Zealand
    Glen
    I have a 2-post clear floor chinese no brand. Was under $US2k 10 years ago. Been perfect. Needs 4m stud but they come shorter with cables and hydraulic lines covered on the floor.
  20. FerrariCognoscenti
    FerrariCognoscenti Formula 3
    Jan 19, 2021
    2,429
    East Coast
    O you have a photo? Where did you get it, Amazon?
  21. Akg200
    Akg200 Karting
    Mar 10, 2022
    52
    The States
    This should work perfectly.
  22. Aerosurfer
    Aerosurfer Formula 3
    1,788
    Indianapolis
    Nick
    I also have an ACL M1 6.5 single post lift. The product is fantastic! But if the price has gone up that much, you really have to want it! I paid under 10k for mine less than 2 years ago (12.5k all in with garage door mod and install)
    They are fantastic pieces. My garage is tall, but not very deep so it was the only one that made the most convenient sense. I have reached my limits as to the amount of work you can do on your cars with them. No center bridge jack available. The cantilever setup limits what kind of weight shift and hard wrenching i would feel safe doing. Changing motor mounts in my old S-class with a screw jack pushing up the motor was as far as i would go. I have put the 456 on jackstands on the lift, to do rear axle work, but that was still done on the ground, i jusy wanted to put the car up away overnight.
    I have 79" of clearence and nothing to worry about hitting when its up.
    plastique999 and DefunctNeurons like this.
  23. rob lay
    Dec 1, 2000
    63,269
    Southlake, TX
    Rob Lay
    yep, I didn’t pay more than $12k 3 years ago and customized the height plus options like the diamond plate.
  24. RedTaxi
    RedTaxi F1 Rookie
    3,307
    New Zealand
    Glen
    Our version of E-bay called Trademe. Have a look. Still pretty cheap at $nz4k which is $us2.3k. (Listing number 3802604900)
  25. Drewcati
    Drewcati Karting
    Jul 9, 2014
    60
    Texas
    How much was the installation? I’m seriously considering one of these. Thanks!
    Jack-the-lad likes this.
