Reclamping this style Hose clamp | FerrariChat
Discussion in 'Technical Q&A' started by BladeMD, Dec 9, 2016.
  1. BladeMD
    BladeMD Formula 3
    1,140
    Sarasota, FL
    Hannibal
    I had to replace my secondary air pump in my 360.... main issue I am having now is getting the hose clamps to tighten. It seems clear that a special tool is needed or my wrenching acumen is not what it should be. Can't seem to get these clamps to resnap into position. Do I just need to gets some old school screw down clamps instead?
    Any guidance would be appreciated!
  2. BladeMD
    BladeMD Formula 3
    1,140
    Sarasota, FL
    Hannibal
    #2 BladeMD, Dec 9, 2016
  3. Kevin Rev'n
    Kevin Rev'n Two Time F1 World Champ
    Nov 29, 2009
    24,324
    Honolulu
    Kevin
  4. BladeMD
    BladeMD Formula 3
    1,140
    Sarasota, FL
    Hannibal
    Kevin, you rock! Thank you so much! That is exactly it. There is a 30.1 on the side of the clamp which corresponds to the clamp on both ends of the right angle hose:
    https://www.belmetric.com/oetiker-ear-clamps-c-15_494/chpe301-oetiker-ear-clamp-p-2817.html
    I am sure I could just get some hose clamps from NAPA which would do the trick, but it would be nice to keep it close to OEM.
  5. Kevin Rev'n
    Nov 29, 2009
    24,324
    Honolulu
    Kevin
    You will have your order in 48 hrs. That company is really good at shipping! As good as Ricambi! ;-)
  6. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,384
    San Carlos, CA
    Mitchell Le
    I hate those...
  7. hessank
    hessank Formula 3
    1,867
    Canada, Florida
    Fred
    +1
    They're on the mafs too
  8. yelcab
    Nov 29, 2001
    13,384
    San Carlos, CA
    Mitchell Le
    There is no reason to keep those basterd clamps. You cannot re-use them. You cannot easily undo them. You have to cut them off with a dremmel tool. And you are unlikely going to have them in a bind on the side of a freeway. Even with a dremmel tool, you might not have the space to access them. Or you might not want to cause that much sparking in the engine bay near something that may burn.
    The only people it helps is the factory who can clamp it on in 3 seconds and move on. Everybody else after that gets shafted. I would never put another one of those clamps back on after I take the first one off.
  9. BladeMD
    BladeMD Formula 3
    1,140
    Sarasota, FL
    Hannibal
    I couldn't wait 48h. I just went to NAPA and got some standard perforated clamps. Made the job easy to finish.
    I appreciate the input from everyone else. Perhaps I'll hold off on getting the OEM style replacement. :)
  10. Chrispy300
    Chrispy300 Karting
    Jul 30, 2016
    86
    Brisbane Australia
    Chris Paterson
    I've got them all over my Audi. Horrible bastard things. Nearly impossible to get off if in a slightly difficult spot and then you have to replace them. I just went and replaced all I could with wormdrive clamps. Never looked back.
    I wouldn't bother unless you have Concours winner on your hands.
  11. Keith360
    Keith360 Formula Junior
    Feb 6, 2015
    570
    Santa Barbara County
    Keith Williams
    I prefer Vibrant Performance Pinch Clamps available at summit racing, the clamps are made of 300 series Stainless Steel. Summitracing.com "https://m.summitracing.com/search/part-type/hose-clamps?keyword=Vibrant"
    I purchased my clamp pinch tool on Amazon $20. "Ideal-Tridon 61001V Crimp Clamp Tool"
    Very satisfied with both product.
  12. Kevin Rev'n
    Nov 29, 2009
    24,324
    Honolulu
    Kevin
    Worm drive clamps are ugly! I like this style of clamp but prefer the upgraded CAD plate ones that are specific for a certain size hose, or even the dark coated ones that Ricambi has. They aren't that hard to take off you just need the tool to loosen them up. Or some good pliers or dykes to pinch with. IMHO
    575M666 likes this.
  13. ago car nut
    ago car nut F1 Veteran
    5,463
    Madison Ohio
    David A.
    Been reported that the cheap spring wire clamps work best because they keep constant pressure on the hose. They are ugly and sometimes a pain to remove.
