Rear fender liner removal? | FerrariChat
Discussion in '360/430' started by netsec, Aug 27, 2022.
  1. netsec
    netsec Karting
    May 5, 2022
    101
    Henderson, NV
    Hello everyone,
    Hope to find any tips/tricks to removing the rear fender liner (driver side). All fasteners are removed, damned thing just won’t budge.
    Side note, incredible how much gravel collected inside the rear bumper…have it off for an exhaust installation.
  2. colorfull
    colorfull Formula 3
    2,280
    Franklin Park, New Jersey
    John Napoli
    Did you get the screws above the wheel just inside the fender?
    Once I had all the screws out, came right out
    Maybe go around the edge where you can with a plastic scraper?
    netsec likes this.
  3. Tackleberry
    Tackleberry Formula Junior
    371
    United Kingdom
    It's not immediately obvious but the Intake Ducts are secured to the Liner - at the top - by a single small bolt.
    You will of course need to remove the Engine Bay Panels - all four - to gain access.
    RANDY6005 and netsec like this.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,913
    Isle of man- uk
    Is this 360 or 430 ? If 430 you have to remove the long side cover in the engine bay to access a screw from that side, it is at the top of the liner curve. It screws into an AVK threaded insert which has a habit of turning with the screw
    netsec likes this.
  5. colorfull
    colorfull Formula 3
    2,280
    John Napoli
    netsec and LorenzoR like this.
  6. netsec
    netsec Karting
    May 5, 2022
    101
    Henderson, NV
    Appreciate the responses. This is a 360, I’ll double check the screws…will remove the bay covers as well.
  7. netsec
    netsec Karting
    May 5, 2022
    101
    Henderson, NV
    You guys nailed it!
    Once I got the engine bay panel off, it exposed the nut/washer at the top. Once removed, the liner dropped right out. Most appreciated!
    RedTaxi and colorfull like this.
