Radio without sound in my FF | FerrariChat
Discussion in 'FF/Lusso' started by Pinarello, Jun 15, 2015.
  1. Pinarello
    Pinarello Karting
    Sep 20, 2013
    191
    Visalia
    Roberto Gugig
    Today after working fine during the morning, no sound, but panel normal, no change with on Off, of radio and or car
    Anybody have any ideas?
    Has this happened to you?
    Anything else I should try?
  2. ttforcefed
    ttforcefed F1 World Champ
    19,216
    just hit the alarm and let the car sit
    next time you go drive it it will be fine
    forstephan likes this.
  3. FFMAC
    FFMAC Formula Junior
    Jul 20, 2012
    397
    Mac
    +1. It will fix itself! :)
  4. Pinarello
    Pinarello Karting
    Sep 20, 2013
    191
    Visalia
    Roberto Gugig
    Has not fixed itself:-(
    Any other ideas or trip to dealer?
  5. SVCalifornia
    SVCalifornia F1 Rookie
    2,549
    Silicon Valley
    Keith
    Does the voice interface work? SAT radio or iPod/iPhone interfaces work? Any audio thru these at all?
    SV
  6. ttforcefed
    19,216
    weird
    disconnect the battery and reconnect maybe?
  7. PhilNotHill
    PhilNotHill Two Time F1 World Champ
    Jul 3, 2006
    27,855
    Aspen CO 81611
    FelipeNotMassa
    Are you getting power? My Porsche had a loose fuse...removed and reinserted and the radio was fine.
  8. Pinarello
    Pinarello Karting
    Sep 20, 2013
    191
    Visalia
    Roberto Gugig
    It has power as light screen is on and you can press buttons and change stations, between SAT, AM, PM etc but no sound
  9. FFMAC
    Jul 20, 2012
    397
    Mac
    Definitely worth trying a battery reset as ttforcefed has suggested. Only the clock will need resetting after.
  10. 991tt
    991tt Rookie
    Dec 2, 2013
    2
    My 2014 FF does the same thing, it usually involves me selecting my phone in AUX for Bluetooth audio. Sometimes when Bluetooth audio is not working, I switch over to sat radio, then am, then fm and no sound on any option. Then other times I can switch to sat radio, toggle the volume up and down, then switch back to Bluetooth and the sound will work then. The audio system is lousy any way you look at it.
  11. ttforcefed
    19,216
    mine hasn't done it in a cple years - I bet theres an ecu update that gets flashed during one of the annuals
  12. MARMIST
    MARMIST Formula 3
    Jul 1, 2014
    1,338
    updates ? went to dealer or fixed itself ?
  13. Pinarello
    Pinarello Karting
    Sep 20, 2013
    191
    Visalia
    Roberto Gugig
    I am out of town for the next week, will give you update upon my return, if not fixed by the. Will take to dealer
  14. golden1911
    golden1911 Karting
    Apr 28, 2014
    150
    Toronto
    i've had this happen twice. trip to the dealership both times!
  15. Twosherpaz
    Twosherpaz Formula Junior
    Feb 25, 2014
    928
    Thermal, CA
    Private
    I had it happen twice today. Pleasant. Not.
  16. Pinarello
    Pinarello Karting
    Sep 20, 2013
    191
    Visalia
    Roberto Gugig
    It was battery, changed at dealer now working fine!
  17. Devonboy
    Devonboy Rookie
    Jun 7, 2014
    28
    Stephen Ford
    I read this thread and tutted - never happened on my 2012 FF.....until this morning!! I just happened to be going Joe Macari dealership for a visit and they explained this is a common fault - the amplifier gets stuck. Solution was to disconnect battery, disconnect amplifier in the boot, have a cup of coffee, reconnect amp, reconnect battery, ignition on for 60 secs, then start up and idle 5mins, and off - ALL DONE and fixed.
    Many thanks to Archie at Joe Macari for dealing with this on the spot for gratis and boy what a show room these guys have
    Devonboy
  18. RickLederman
    RickLederman F1 Rookie
    2,836
    Swanton Ohio
    Rick Lederman
    Two weeks ago my FF radio quit responding to any buttons, even on/off, after a few minutes it shut down, a minute later the passenger display shut down. Another minute and it all came back on but with the buttons still locked, and it continued to restart. It took a shut down overnight for it to come back and has not happened since.
  19. colamclean
    colamclean Formula Junior
    Nov 5, 2013
    306
    McLean, VA
    Patrick Transue
    I had the same condition as the original poster yesterday with my FF - infotainment/nav system and buttons all appeared to be working normally, but no sound at all to the speakers. Tried it again this morning - no change. Called Ferrari of Washington and although told that in 90% of the cases disconnecting the battery will resolve electrical gremlins, it can also cause other problems and a host of error messages... I took the car to FoW and they did what was called a ‘proxy alignment’ - basically getting the various computer modules in the car back in sync and communicating properly. This was done after disconnecting the battery. Once completed the speaker issue was resolved and an intermittent issue I had with the tailgate of the FF now seems to be resolved too - it would sometimes open a small bit and then re-closed when the tailgate button next to the seat was pressed. James at FoW took care of my issues in less than 30 minutes and sent me on my way.
  20. papou
    papou Formula 3
    1,712
    plantation Fla
    daniel ross
    I’ve just had my windshield replaced at my dealership Ferrari FtLauderdale, Now for some reason Radio has no
    reception just a crackle sound on FM and AM all other head unit functions work.
  21. Bamsefar
    Bamsefar Formula Junior
    Nov 26, 2012
    524
    I might be wrong, but I think the radio antenna on the FF is in the front windshield - so it could be that the radio is not connected (or the windshield does not have the antenna in it?)?
    Caeruleus11 likes this.
  22. papou
    papou Formula 3
    1,712
    plantation Fla
    daniel ross
    I know the GPS is on the roof, radio I’m not sure.
  23. papou
    papou Formula 3
    1,712
    plantation Fla
    daniel ross
    Car has been with dealership now 7 days they reinstalled the windscreen and the issue is still there ,
    They have no answers it must be in the installation process, but I’ve taken the car home will
    Invest in satellite radio.
  24. D19Racing
    D19Racing Rookie
    Oct 9, 2018
    11
    Nog
    Had similar issue, Radio on but No sound. Took it my Dealer and they just unplugged the Battery let it sit for 1 minute and plugged it back in and it started working fine again. Only caveat is you have to set the time and date again. Thanks.
  25. Elferink
    Elferink Karting
    May 16, 2018
    66
    the Netherlands
    Mark Elferink
    A few years ago I had this regularly, but in recent years I have not had any problems with it.
    By the way, if you know that this can happen, it is no problem to disconnect the car from the power yourself and reset the system.
