Radio on with key out of car won’t go off | FerrariChat
Discussion in 'California(Portofino)/Roma(Amalfi)' started by russellmcg, Apr 7, 2021.
  1. russellmcg
    russellmcg Formula Junior
    Aug 3, 2014
    492
    Houston
    Russell McGuire
    I have turned my car off in my garage and taken my key out, and the radio keeps coming on. Has anyone had this happen? It shuts off and about 10 seconds later turns on.
  2. Twosherpaz
    Twosherpaz Formula Junior
    Feb 25, 2014
    946
    Thermal, CA
    Private
    The Roma with keyless entry? I think it takes an extra press of the button to turn off like a BMW. In the Pista I had it in accessory mode opening the top and killed the battery as I then exited the car. Car must still be in accessory mode for the radio to be on. Also, remove key from car if it is a Roma. Auto lock would ensue.
    Also, sometimes workers are accidentally left in the vehicles and like listening to the radio. What music is he playing?
  3. russellmcg
    Aug 3, 2014
    492
    Houston
    Russell McGuire
    Sorry. This is on my California T. I should have specified that.
  4. Shark01
    Shark01 F1 Veteran
    Jun 25, 2005
    6,523
    The ghost likes his tunes?
    Hey Russell, how are you these days?
  5. tomc
    tomc Two Time F1 World Champ
    Apr 13, 2014
    26,056
    DFW, Texas
    Tom C
    I would still try the double click that @Twosherpaz suggested.
    I know this also works on my Porsche. Never tried it on the Cali though, as I never turn on the radio...T
    russellmcg likes this.
  6. SLViper1
    SLViper1 Formula Junior
    Mar 25, 2014
    768
    Nashville/Destin
    Steve
    I have a Mercedes CLK with a radio that does odd things from time to time like staying on with the car off and locked or not coming on a few times over the 10 years we have owned it. The easy fix for it is to pull the two radio fuses identified in the fuse panel guide, count to ten and put back in. Radio Re-Sets and the issue goes away for years at a time.
  7. russellmcg
    Aug 3, 2014
    492
    Houston
    Russell McGuire
    Doing good! Have not been as active on here as I should be. How’s things with you? Good I hope?
  8. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    I would do a stereo reset first and if that dont fix it do a battery reset.
    Stereo System reset: Push and hold the left stereo knob for 30 seconds then let go.
    Wait another 30 seconds then push and release the same left button/ knob.
  9. Shark01
    Shark01 F1 Veteran
    Jun 25, 2005
    6,523
    Yes, doing well.....hope to see you at an event sometime this year
  10. Florida Joe
    Florida Joe Karting
    Jul 28, 2005
    248
    South Florida
    Did this just start or has it always been like that? I had a BMW that did the same. The battery would be dead after a couple of days. After multiple trips to the dealer, they found the wrong fuse was used that allowed the radio to stay powered on without the ignition. I would replace your fuse just in case.
  11. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    I'm an electrical engineer so I am having a difficult time understanding how a wrong fuse installed can cause a stereo system to stay on instead of shutting down when the ignition is off.
    mikey k, lucasines and SVCalifornia like this.
  12. SVCalifornia
    SVCalifornia F1 Rookie
    2,584
    Silicon Valley
    Keith
    Joe, they fed you a line...
    SV
    whatheheck likes this.
  13. azlin75
    azlin75 Formula Junior
    Jul 16, 2017
    785
    Kansas
    Shawn Hicks
    Can’t speak to the Cali t unit but had issue once with the California unit once while pairing with my phone. Radio just wouldn’t turn off. I pulled the fuse like mentioned earlier and never had the issue again while I had it. Also never used the radio, navigation or phone paring feature again either.
  14. Florida Joe
    Florida Joe Karting
    Jul 28, 2005
    248
    South Florida
    Line or not. They had the car for 5 minutes, opened the fusebox, replaced something and I never had the issue again.
    Sent from my Pixel 5 using FerrariChat.com mobile app
  15. 32 Ford
    32 Ford Karting
    Jan 31, 2021
    175
    vancouver
    Mike McGowan
    Replaced the fuse , which killed the power to the radio. Which most likely cause a "reset" A fuse can't create power it is only a conductor of. Somewhere along the lines it was a misunderstanding came about. No competent mechanic would say such a thing.
  16. intrepidcva11
    intrepidcva11 F1 Rookie
    3,232
    Saratoga Springs NY
    Seth
    get your old Louisville Slugger and beat the sh-t out of its misbehaving hide. :mad:
  17. intrepidcva11
    3,232
    Saratoga Springs NY
    Seth
    Oh you tried that already? :)
  18. azlin75
    Jul 16, 2017
    785
    Kansas
    Shawn Hicks
    Well in the world of BMW you never can be sure. But seriously I’ve been fed some pretty good lines in the service department before. I have a buddy that works as the manager of the body shop of a dodge dealer. He told me the service dept. guys make bets to see how silly of a reason a car is messed up and the customer believe it. Apparently it’s just as bad in some sales departments. But I’ll bet your right was a simple reset masked as a larger problem.
  19. 32 Ford
    32 Ford Karting
    Jan 31, 2021
    175
    vancouver
    Mike McGowan
    I could see that as a "game" some mechanics would play. But a lot of it is a communication issue. Example. We service high end apartment towers. One of our Plumbers fix a hot water issue and told the tenant to run the water for a little bit to let the air out of the pipes. Tenant turns on his hot water tap full and goes to work. Floods 4 suites and over $100K damage. I guess "a little bit" means different things to different people.
    Same as mechanics explaining problems to car owners who have no knowledge of cars. Might as well be speaking Italian.
  20. 32 Ford
    32 Ford Karting
    Jan 31, 2021
    175
    vancouver
    Mike McGowan
    Sorry I digressed. Some of these electrical gremlins can be reset by a simple power disconnect. I am a licensed electrician and still can't understand why some of these things happen. One rule it likes is path of least resistance. Electricity is crazy stuff.
  21. swiftar
    swiftar Rookie
    24
    Ron
    The design on the California T is for the radio to stay on until you open the door. Once open - it should shut off.
    Some convertibles (can not confirm on Cali T) have a setting to allow you to run the radio after key is removed so you can listen outside the car while the top is down.
    Does your issue occur even after the door opens?
  22. russellmcg
    Aug 3, 2014
    492
    Houston
    Russell McGuire
    Yep. Turn the car off, open my door to get out, close the door and around 10 seconds later the radio comes on.
  23. SLViper1
    Mar 25, 2014
    768
    Nashville/Destin
    Steve
    Ran across this on a Speciale:
    #8Nov 23, 2015
    one other thought - make sure you have no bluetooth devices around/connected.
    I can't confirm, but I always wondered if the car somehow thought it had an active call going, as if it does, it will stay on until the call ends
    Well I'll be darned.. That worked! I spoke to the cheif mechanic at the dealer and a few other people and they had no suggestions other than to disconnect the battery.
    Disconnecting my Bluetooth phone worked like a charm!
    Many thanks to you!
  24. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    I suggest doing a battery reset.
    See attached.
    Dan
