Radiator foam strip | Page 2 | FerrariChat
Radiator foam strip
Discussion in '308/328' started by jersey308gtb, Feb 18, 2017.
  1. vaccarella
    vaccarella Formula 3
    Apr 16, 2011
    2,291
    Paul
    I thought it'd be for sound proofing more than anything. Is it really for airflow to the rad? Does it have markings on it when new??
  2. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    3,838
    Norfolk - UK
    Tony
    Yes....No
  3. piezo
    piezo Formula 3
    May 27, 2011
    1,533
    Hong Kong
    Steven
    I got mine when I got my car cover a few months ago when MCP out of stock for the pieces around the radiator already. I must be lucky to get the last bits from Eurospares if MCP was their supplier.
    Had a discount at the time but still hefty amount and they are not exact sizes and needed trimming. Suits me lazy bones and I thought it should be done together with the replacing of the FIM radiator with the correct Puma type.
    I think you can still get the hood cover pieces still but not those 3 pieces around the radiator from MCP.
  4. malh001
    malh001 Rookie
    Jun 10, 2007
    35
    I'm looking to replace mine and have found a company that will supply a 1000mm x 30mm x30mm strip for £2.10! Is the foam very firm, firm or soft, etc? Mine is none existent.
  5. jersey308gtb
    jersey308gtb Formula Junior
    Feb 18, 2015
    383
    Alex Heynes
    Great good work! I had a look today (while I was supposed to be working) and couldn't find anyone that could do 30mm thick.
    The foam should be heat tolerant, open cell (so it mobile well around things).
    Can you share the details of the supplier?
  6. Martin308GTB
    Martin308GTB F1 Rookie
    4,230
    Black Forest Germany
    Martin N.
    I vote 'soft' Thickness of 30mm should be o.k., but width of 30mm might be too narrow.
    Best
    Martin
  7. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    16,190
    Gold Coast, Aust.
    Patrick
    Get 50x50mm, soft
  8. jersey308gtb
    Feb 18, 2015
    383
    Alex Heynes
  9. malh001
    malh001 Rookie
    Jun 10, 2007
    35
  10. robo330
    robo330 Formula Junior
    Apr 15, 2014
    608
    Michigan USA
    Karl Robertson
    Have you tried anyone in the Upholstery business? There are a number of Foam Suppliers there... Everyone uses different types of Foam for Seat Padding, comfort foam layers, and even in the Domestic Furniture sector. Hard to believe that 1 meter of foam costs 10 quid and the wrong thickness to boot...?
  11. Crafter
    Crafter Rookie
    Jul 8, 2020
    1
    Alex Craft
    I've used this place before they do cut to size foam.
  12. 308Dadoo
    308Dadoo Formula Junior
    851
    Aliso Viejo CA
    David
    Eric at GTO Engineering Los Angeles was selling the precut foam pieces at a LA Carmeet several years ago. Don't know if he's still there or not.
  13. BigTex
    79,218
    Houston, Texas
    Bubba
    Those of you using the OEM open cell foam are replacing a problem: It can hold and retain water.
    I keep Armaflex around all the time, a closed cell, skinned sheeting that comes in a variety of thicknesses and easily cut with a bread knife.
    The 308 radiator should have bottom, side, and the top seal against the hood, and there are even some oddly shaped "Corner Blocks" at each top corner.
    Having all of that in place deos indeed route air firmly thru the radiator, increasing it's performance.
    But I would not pay big money for any of those open cell pieces.
    Go to an HVAC Supply and find what I am using.
    They insulated Chillers and other thermal equipment in it....
  14. jferazzi
    jferazzi Karting
    Sep 12, 2009
    89
    Indianapolis
    I'm replacing the foam on either side of my radiator. I bought this at Lowe's:
    When others have mentioned foam they bought at Lowe's, Home Depot, etc. is this what they're talking about? Will this stand up to the heat next to the radiator? As for the foam under the bonnet, I bought the really expensive stuff through Ferrari Parts UK (I know, stupid expensive but oh well...).
    waymar likes this.
  15. waymar
    waymar Formula 3
    Sep 2, 2008
    1,324
    Northeast, PA - USA
    Wayne Martin
    Used the Home Depot stuff. Works great and held up for 3 years now - I put 15k miles on the lady this year...... did make an improvement.
    miketuason, jferazzi and thorn like this.
  16. jferazzi
    jferazzi Karting
    Sep 12, 2009
    89
    Indianapolis
    Is the stuff you used the same as what I bought?
  17. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    I'm pretty certain that's exactly the foam I bought and used. It has worked great.
    jferazzi likes this.
  18. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,541
    Cerritos, CA.
    I also have the Foam from Home Depot, it has been eight or nine years now and still holding strong.
    waymar likes this.
  19. waymar
    waymar Formula 3
    Sep 2, 2008
    1,324
    Northeast, PA - USA
    Wayne Martin
    Yes/ I glued two strips side by side worked and fit great. Also put thinner strips on side of radiator when I pulled it to recore it.
  20. jsumnertx
    jsumnertx Karting
    Dec 9, 2004
    144
    Austin
    miketuason and jferazzi like this.
  21. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Along the Verde , AZ
    Doug
    FWIW, GT parts has correctly shaped and color foam strips. I prefer things to be as original looking as possible, but thats just me.
    Doug
  22. waymar
    waymar Formula 3
    Sep 2, 2008
    1,324
    Northeast, PA - USA
    Wayne Martin
  23. AZDoug
    AZDoug Formula 3
    Jun 17, 2009
    1,606
    Doug
    The radiator seal doesn't have the correct shape, the original was trapezoid shape. Does it matter for function? Not all all, what you have will work fine.
    Doug
    waymar likes this.
  24. jferazzi
    jferazzi Karting
    Sep 12, 2009
    89
    Indianapolis
    I picked up the cheap A/C insulation foam at Lowe’s and ordered the expensive stuff from Maranello Parts (mainly just the two pieces that are most visible under the bonnet). It arrived today and, yep, it’s just foam, lol! Not that I expected anything different... I think I was just more curious than anything. But at least it’s already cut to size. And the piece that will press up against the top of the radiator already has an adhesive on the one side. So I got that going for me...
  25. Banzairacer
    Banzairacer Formula Junior
    482
    San Diego, CA
    Sanjeev Thohan
