488 - Radar Detector Mount (Escort Max360c) | FerrariChat
488 Radar Detector Mount (Escort Max360c)
Discussion in '458 Italia/488/F8' started by Soft, Feb 15, 2020.
  1. Soft
    Soft Rookie
    Aug 30, 2019
    5
    Art
    I’m looking for a good permanent mount for my F488. I have a Blendmount on my Porsche and it’s been amazing but unfortunately they do not have a mount for the 488 with Homelink mirrors.
    It’s to hold the Escort Max 360c.
    What do you guys use? I want to avoid the suction cups and find a neat permanent solution.
  2. scott61
    scott61 F1 Rookie
    Feb 11, 2004
    2,606
    North of Boston
    I just hardwired my 360Max and while I don't mind suction cup mirror mount sounds interesting. I don't have a homelink mirror so would that mount work for me?
    Caeruleus11 likes this.
  3. Gh21631
    Gh21631 F1 Veteran
    8,957
    East
    What's it hardwired to for power?
  4. scott61
    scott61 F1 Rookie
    Feb 11, 2004
    2,606
    North of Boston
    The fuse panel on the driver side dashboard
    Gh21631 likes this.
  5. Soft
    Soft Rookie
    Aug 30, 2019
    5
    Art
    I think it might work but you should double check with their customer support first. If indeed they support the “standard” rear mirror then you’re golden and you will love Blendmount.
    scott61 likes this.
  6. Rory breaker
    Rory breaker Formula Junior
    Apr 17, 2017
    270
    Have a Bel/Blinder setup, shop that installed it built a custom mount around the steering column for the display, and mounted the controller underneath the center console. Looks 100% OEM, highly recommended.
  7. RaceMX-M3
    RaceMX-M3 Formula Junior
    Dec 15, 2010
    540
    Frisco, TX
    Scott
    hirohawa, Caeruleus11 and Thecadster like this.
  8. scott61
    scott61 F1 Rookie
    Feb 11, 2004
    2,606
    North of Boston
    Thanks, will look into it. Only thing I'm not sure of is it sitting lower blocking view? With the suction cup it's higher up and not that noticeable. Also these new suction mounts they use are much than the older ones and I never have any issues with it falling. Here is how it was on my huracan and in my Lotus
  9. Brambleworth
    Brambleworth Formula Junior
    388
    NY
    Ted
  10. FPFaeth
    FPFaeth Formula Junior
    Dec 3, 2009
    663
    NY
    Frank Faeth
    Did you have AI Design in Tuckahoe, NY, install your system? I ask because they have a 3D printer mirror design just like that. It's a spectacular solution. (If not, who was your installer? Thanks.)
  11. Brambleworth
    388
    NY
    Ted
    Yes it is from AI Design
  12. FPFaeth
    Dec 3, 2009
    663
    NY
    Frank Faeth
    Thank you.
