355 - Race Technologies: Brembo GT Big Brake kit. 4-pot/355mm all around. Now or never. | Page 10 | FerrariChat
355 Race Technologies: Brembo GT Big Brake kit. 4-pot/355mm all around. Now or never.
Discussion in '348/355' started by ShineKen, Aug 3, 2021.
  1. ShineKen
    ShineKen F1 World Champ
    19,350
    Southern California
    Nostradamus
    Alright guys. I'm back at it again. I have a possible "budget" solution, which could lead into a viable option.
    Giro Disc currently offers 2-piece rotor replacements for our fronts using the same OE calipers. However, they do not offer anything for the rears. They stated something along the lines of their current hat design not being able to accommodate the E-brake. Not enough clearance. So for now... you'll have to use OE rear rotors. IF there is enough demand, they would consider designing something for the rear.
    https://www.************/Girodisc-Front-2-Piece-Floating-Rotors-for-Ferrari-348-F355_p_5511.html
    The problem is, their 2-piece front rotors looks nothing like an OE rotor, so their is a matching issue. However, there is a way to make them look close to OE. Hats would be in silver, not blue (anodized) and they are willing to do a drilled set (without slots) to match OE drilled rotors. Hopefully, near exact replica. So from a distance, it would look very close to OE, but it will be 2-piece, thus lighter weight. OE front rotors are 300mm and weigh 19 lbs each. GD equivalent 2-piece rotor weighs 14 lbs each. 5 lbs savings per corner.
    Thoughts?
  2. ShineKen
    19,350
    Southern California
    Nostradamus
  3. ShineKen
    19,350
    Southern California
    Nostradamus
  4. ShineKen
    19,350
    Southern California
    Nostradamus
  5. ShineKen
    19,350
    Southern California
    Nostradamus
  6. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,695
    Lake Villa IL
    My thoughts are there would be even more weight savings in the rear. If they can't do an alloy hat with parking brake provision in stock dimensions bump it out to the next size and include brackets to space out the caliper. They would probably want a steel sleeve for the parking brake drum but I would prefer it was just a part of the aluminum hub. I think we can all agree to not grab the parking brake before we are stopped? :)
    I would be in on a matching front/rear set that saved weight all around.
    (otherwise I have no need in adding weight, unsprung and rotational at that, when my focus is reducing overall weight)
    ShineKen likes this.
  7. ShineKen
    19,350
    Southern California
    Nostradamus
    I spoke with Martin at GD in length just today about the setup. I too would like a front and rear match, but there are complications with the rear due to parking brake clearance. I don’t know the technicalities of the issue in detail, but I’d suggest giving Martin a call if you have suggestions. He does believe it is possible, but at a cost, which most likely needs to be amortized over several units.
    He doesn’t believe there’s a market for in 355 community. He could be right, but can’t say I didn’t try.
    On a side note, there is a guy at GD who tracks his 348. He has the 2-piece fronts. He doesn’t feel the stock 300/310 mm rotor sizes are adequate for extensive/more serious track use. It would need to be 330mm+all around.
    A 330mm Brembo Big Brake kit would be lighter all around vs standard. Lighter rotor and lighter caliper. Not significant, but the savings are there. I believe I posted the weights somewhere in this thread.
    My main issue was Race Technologies wasn’t willing to paint “Ferrari” on the 4-pot F50 calipers. I’d have to figure out how to do that properly on my own and frankly, I don’t have the time for that right now.
    I like the idea of these light-weight 2-piece OE replacements made for factory calipers for the road. They just have to look more OE.
    I’m thinking if there is enough demand for the fronts, which they already need 10 pairs of orders to do, that might incentivize them to do the rears.
  8. ShineKen
    19,350
    Southern California
    Nostradamus
    I just realized my first link to GD’s site for the 355 front replacement didn’t work. Here’s a pic of how they currently look.
  9. ShineKen
    19,350
    Southern California
    Nostradamus
    @INTMD8 keep in mind the rears are already slightly bigger than the fronts by 10mm. The next size up would be either 315 or 320mm rear, while the fronts are only 300. Could look funny.
    INTMD8 likes this.
  10. A348W
    A348W Formula 3
    Jun 28, 2017
    1,839
    North Wiltshire, UK
    your only issue with this setup is how to paint ferrari on the calliper? Seriously?
    take them down to your local paint shop and ask them to spray it in with a stencil; easy!
  11. ShineKen
    19,350
    Southern California
    Nostradamus
    If it were that easy, people wouldn’t be painting their stock 355 calipers like this … :)
  12. ShineKen
    19,350
    Southern California
    Nostradamus
    As far as I can tell, I don’t believe I’ve come across someone who successfully (properly) stenciled in “Ferrari” on their stock 355 calipers. What I mean by properly is, correct shade of white, exact font style and size, and correct positioning.
    Most repainted calipers I’ve seen use a “Ferrari” sticker and clear-coated over. My current OE calipers are the same. Painted red with a black Ferrari sticker clear coated over. Personally, I think the font size on mine is off.
    Here’s one Dave had Bradan do. You can see the Ferrari sticker protrude.
  13. ShineKen
    19,350
    Southern California
    Nostradamus
    A few things to know regarding Brembo GT brakes and painting them:
    1. The standard Brembo logo is stenciled in. I mistakenly thought it was a sticker. In short, you can’t simply stencil in “Ferrari” over the “brembo” logo. You’d have to paint the caliper first.
    2. After some discussion with Race Technologies, there are intricacies in painting calipers properly. There’s a method to the madness. Perhaps the way things are masked or what is removed, how it’s prepped/primered etc.. The little details that go into doing a proper and excellent job vs. doing them willy nilly. They explained to me, most shops don’t paint calipers properly. I don’t know these intricacies. It will take time for me to figure it out on my own. I won’t just send them to any shop either. These calipers go for about $1000 each. How do you want them done?
    3. Race Technologies charges $600 to paint and re-logo (some change to a Brembo race logo) for the set. Their service is only offered one time when you first buy the calipers from them new. You can’t go back to them months later asking them to paint. It’s a one time offering, which expires when you walk out the door with the calipers/brake kit.
    4. RT will only stencil a “Brembo” logo. They won’t do anyone else’s logo. They will paint the calipers whatever color you want as long as you provide them the color code.
    Getting Brembo GT calipers done with a “Ferrari” logo properly takes some thought and effort. That’s if you care about the result of your $4k calipers + cost to paint/stencil. I do :).
    I’d first have to find a cheap/used F50 caliper to build a stencil off. I’d want exact font/size and positioning. A close color match (white) will help with the final OE look. If black logo, much easier. There are a million shades of white.
    Here’s a brand new F50 caliper for $2500. That’s a hard pass for me. I need waaay cheaper :).
    https://www.ebay.com/itm/Ferrari-F50-RH-Front-Brake-Caliper-Brake-Pads-NEW-165880-/120239606048?mkcid=16&mkevt=1&_trksid=p2349624.m46890.l6249&mkrid=711-127632-2357-0
    It might even take a few tries to get 95% close to OE, which is what I’m after. Then it’s about finding someone who can paint the calipers properly (not ruin them with missed spots or overspray).
    So yeah… easy. Easier said than done :). It can be done, but it will take time. I’d need to find a cheap F50 caliper before putting any effort into it.
  14. ShineKen
    19,350
    Southern California
    Nostradamus
    Here’s how a “Ferrari” logo on a caliper would most likely turn out if you simply take them to the nearest shop and don’t care for accurate results.
  15. Flynt
    Flynt Rookie
    Aug 23, 2013
    45
    I can get photos, dimensions and a color code for the Ferrari logos off a gen-u-wine F50 caliper if you'd like. The car was raced, so the color may have changed a bit. Shoot, I can create and ship die-cut stencils for a couple bucks if you're interested.
    I'd bet the image above from Formula Dynamics is photoshopped and the actual caliper would look a lot better in person, although maybe not absolutely perfect.
    On the topic of a big brake kit for our cars - Just checked Vivid racing site and they have Stop Tech kits for under 3k an axle. 355x32, fits under factory wheels, bolt on and go. No affiliation, etc but that's what I'd do. Maybe I'd put the Ferrari logos on them, too..
  16. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,819
    Richmond
    Pete
    Are you going to be worried about the stencils when your brakes fade at 150mph or that the car stops? I definitely get the desire for proper looks, but not over the function of the brakes actually being up to the task - which the stockers aren't, at least not on modern tires.
  17. ShineKen
    19,350
    Southern California
    Nostradamus
    That might actually help. As long as you're confident the stencil is a 99% match, that would actually save a ton of hassle. I'd definitely pay you for those stencils. Color (white) I'm going to assume is pretty close to the one on the 355 OE caliper, so at least I'll have a sample I can try to match.
    The StopTechs to get are these. The StopTech logo is engraved. That will be a challenge to overcome.
    https://www.vividracing.com/stoptech-trophy-sport-big-brake-kit-silver-caliper-slotted-2piece-rotor-rear-ferrari-rear-p-151615685.html
  18. ShineKen
    19,350
    Southern California
    Nostradamus
    I'm one of those :). The calipers have to be right before they even go on the car. Otherwise it's just too much of a hassle to install, then later remove, clean, repaint, re-logo etc... I need time. Time I don't have because I want my car back on the road. I have my car up in the air at the moment and I need to do something that will get me by in the meantime while I figure out this Brembo GT caliper dilemma. I can always switch the setup to my other car when I upgrade to the GT's. The current logo on my repainted OE calipers (done by previous owner) is driving me nuts :).
    The ones you bought, the guy did a great job actually. Was the logo painted or is that a sticker?
    https://www.ferrarichat.com/forum/threads/brembo-f355-front-and-rear-bbk.539985/
  19. bobzdar
    bobzdar F1 Veteran
    Sep 22, 2008
    6,819
    Richmond
    Pete
    They're painted, but the finish on them is not perfect as there are a few scuffs and chips on them here and there as you can see in those pics. I will probably touch up via a paint pen vs. refinish, but I'm (obviously) not as anal as you are :). I just want the thing to stop. Car will get a full repaint before I worry about refinishing the calipers - currently building a new garage so work on the car is going slowly.
    308 GTB and ShineKen like this.
  20. ShineKen
    19,350
    Southern California
    Nostradamus
    When that time comes, you're gonna want those OE perfect Ferrari stencils ;).
  21. ShineKen
    19,350
    Southern California
    Nostradamus
    What could really help is if you can confirm the "Ferrari" logo is the exact same size/shape/spec as the one on the 355 OE caliper. If it is absolutely identical, that would make life much easier as I do have OE calipers in black I can use to build a stencil off. Once the stencil is created, it would simply be a matter of correct positioning/centering on the Brembo GT caliper.
  22. Flynt
    Flynt Rookie
    Aug 23, 2013
    45
    PM sent. Checking tonight.
  23. 308 GTB
    308 GTB F1 World Champ
    11,650
    New Jersey
    Barry Wolinsky
    Hi Pete,
    I'm in agreement. My Challenge car is nowhere near perfect after its lifetime on the track. The Challenge brakes do their job well as was intended.
    Prior to getting my F355 Challenge ten years ago, I tracked my 550 as did its previous owner. When I saw it for the first time in 2002, the whole left side was pebble-blasted as a result of an off-track excursion at the bus stop at Watkins Glen. It was repaired at Classic Coach which at the time was a Factory-authorized coach repair center. The left front caliper wasn't repainted. When I bought the car in 2007, they offered to refinish the caliper using a silk screen process for the Ferrari logo as was done at the Factory. I declined the offer. I thought the scraped and scuffed caliper was tribute to the time the car spent on the track. I tracked the 550 for 3,000 miles on top of the 8,000 track miles the previous owner put on the car. My 550 has an identity crisis. It doesn't know if it's a track car or a GT car. :D
    I think the patina looks nice...
    The stock 550 brakes were good on superspeedways like Pocono and Daytona with their short road course segments but marginal on pure road courses like Watkins Glen, Lime Rock Park and NJMP Lightning.
    Barry
    Illyria likes this.
  24. 308 GTB
    11,650
    New Jersey
    Barry Wolinsky
    Ken, it's a silk screen process that is "Factory-correct." You should get a much better result that way.
    I couldn't find a video that demonstrates silk screening a logo on a brake caliper but this fellow shows how it's done on a guitar headstock...
    Barry
  25. tres55
    tres55 F1 Rookie
    3,552
    Canada
    https://ceika-store.com/products/ceika-custom-big-brake-kit-for-ferrari-f355-94-99
    I'm not sure how accurate their configurator is, but it's allowing me to spec the following with 19" wheels:
    Front: 8 small piston caliper, stainless steel pistons, gloss painted yellow, 380mm cast iron drilled discs, black anodized rotor hats
    Rear: 6 small piston calipter, s/s pistons, yellow, 356mm cast iron drilled discs, black anodized rotor hats, oem drum in disc parking brake
    Not sure what their product quality is like however. I see some positive reviews on some other car forums online.
    To further talk out of my a$$...
    I believe the 997 GT ceramic discs are 380mm...as well as the C6 ZR1 rears. 380mm front and would need to find a 355mm rear CCB rotor...then get the hats made to work with oem parking brake and to fit the off-the-shelf rotor disc solution...and of course the calipers. That would be the dream setup. :D
