QV spark plug wires and extenders - Black vs. Red | FerrariChat
Discussion in '308/328' started by James in Denver, Apr 18, 2016.
  1. James in Denver
    James in Denver Formula 3
    May 23, 2006
    2,136
    Centennial Colorado
    James in Denver
    It's been a while since I posted, but can someone post the differences between the Black spark plug wires and Red spark plug wires, the wires themselves?
    And a follow-up, can someone post the difference between the Black extenders (from the plug to the plug wires) and the Red extenders.
    As I recall, one of the 2 sets has higher resistance, yes?
    Also, as the final question, which does a QV need? I assume it's the same for a 308 QV versus a Mondial QV?
    James
  2. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    James, do a search on this as there are some great threads on the topic.
  3. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    Suggest you measure the resistance of the extenders you have and be sure whatever you get has similar resistance because I don't think all red or black are the same.
  4. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,761
    Cerritos, CA.
    And also check for burnt holes.
  5. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,128
    SanFrancisco BayArea
    1983 US 308 GTS QV
    My QV had 0 ohm extenders and that is what I replace them with. The purpose of resistance in the plug extenders is a bit mysterious to me.
    I just replaced much of the maintenance items in my 308 QV’s ignition system (distributor caps, rotors, ignition wires and spark plugs) (I had replaced extenders recently). I did a bit of reading particularly before purchasing new ignition wires. What I learned is that resistance has become a meaningless measure of ignition wire performance (and, I suspect, plug extender performance as well).
    Here is an explanatory article by Magnecor, who is one of the major manufacturers of ignition wire: Truth About Ignition Wire Conductors
    Our OEM Cavis brand ignition wire is that old cheap “carbon core” stuff. It needs to be replaced every couple of years. Modern “mag core” ignition wire lasts much longer and some manufacturers claim “lifetime”.
    I learned that making a wire set is pretty easy, reuse your red sheathing and boots, buy good 7mm wire, some connectors and one of these: ACCEL 7mm - 8mm Crimp Tool. Also Silicone spray is your friend during assembly: DuPont Teflon Silicone Lubricant Aerosol Spray
  6. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    I thought reading here that our ecu in the QVs fry without some resistance in the wire/extender. Can't find the thread just yet......
  7. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,128
    1983 US 308 GTS QV
    That would be bad.
  8. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
  9. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
  10. James in Denver
    May 23, 2006
    2,136
    Centennial Colorado
    James in Denver
    Thanks!
    I don't have the car yet. I used to own a 308 QV, sold it a long time ago. I'm now looking at a replacement car but the pictures of the car showed "black" plug wires. I remembered (surprisingly) that there was a difference.
    Let me check out the original thread linked above.
    THANKS FOR THE HELP!!!
    James in denver
  11. James in Denver
    May 23, 2006
    2,136
    Centennial Colorado
    James in Denver
    This is what I was trying to find, and I believe it still holds true...
    James in Denver
  12. Rifledriver
    36,745
    Cavis wire is not carbon core. It is the same construction as Magnacore spiral wound.
    It has 700 or so ohms per foot resistance.
    The connectors, black or red have no resistance.
    None of the wire is red. It is all the same but in later years they used red silicon tubing on it for cosmetic purposes.
  13. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,335
    Encino, Ca
    Carl T
    Injected cars got the red silicon tubing over the Cavis wire. I believe that only a 7mm ignition wire will pass through that tubing and most of the readily available modern day wire is 8mm.
    Dave Helms had the last of the 7mm Taylor ignition wire that he was selling, but that was awhile ago.
  14. Rifledriver
    36,745
    No, only some of the 4 valves and all of the 3.2s got the red wire covering like I posted prior.
    And it fits 8mm wire. 7mm wire is only on Alfa Romeo and Maserati of the 50's and 60's that I know of.
  15. Martin308GTB
    Martin308GTB F1 Rookie
    Jan 22, 2003
    4,252
    Black Forest Germany
    Martin N.
    #15 Martin308GTB, Apr 19, 2016
    Except on the car for the first 308 GTB sales brochure?
    Best
    Martin
  16. Rifledriver
    36,745
    #16 Rifledriver, Apr 19, 2016
    Uh, the topic was QV's. That doesn't look like a QV.
    Save that picture for the next thread on carbureted cars.
  17. Martin308GTB
    Jan 22, 2003
    4,252
    Martin N.
    Oh yes. Sorry!
    Sale brochures are on my mobile devices anyway.
    Best
    Martin
  18. Rifledriver
    36,745
    My only mobile devices run on gasoline.
  19. Martin308GTB
    Jan 22, 2003
    4,252
    Martin N.
    LOL! That's what I said too till around two years ago. I was also late in the game :)
    Best
    Martin
  20. James in Denver
    May 23, 2006
    2,136
    Centennial Colorado
    James in Denver
    So, if I read this right, the only difference is in the outside (red cover) and the manufacture of the "wire" in it.
    That means black works the same as red, other than appearance and construction.
    Correct?
    Does the Cavis/carbon have any advantage or disadvantage compared to Magnacore/spiral? I assume not, but maybe longevity?
    James
    PS Somewhere on FChat is my thread about how long it took me to change the piugs, connectors and plug wires on my QV. 5 1/2 hours... LOL!!! I'm NOT a mechanic, but I was meticulous!
  21. Rifledriver
    36,745
    There is no red, only black. The red is a cosmetic sleeve.
    There is no difference in construction. Cavis and Magnacore are both spiral wound. Magnacore is slightly larger and the red sleeves are very difficult to install otherwise it is interchangeable. Magnacore discontinued the 8mm. It may not be available at any price but it is higher quality. Cavis is available in bulk to make your own.
  22. jmaienza
    jmaienza Formula Junior
    Jan 8, 2009
    626
    Massachusetts
    Joe
  23. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    getting ready to buy their 7mm and their extenders
    the 7mm fits the red sheaths and caps
  24. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,141
    CT
    John Kreskovsky
  25. Brian A
    Brian A F1 Rookie
    Dec 21, 2012
    3,128
    1983 US 308 GTS QV
    #25 Brian A, Apr 19, 2016
    FWIW, I used 7mm Kingsborne mag wire as well. It is the same 7mm diameter as Cavis so slides back through the red silicone rubber sheating wthout much issue.
    If you call Kingsborne, they are willing to ship any length of bulk ignition cable you want; their website just offers it in 25 foot increments. Likewise, they'll ship any number of terminals.
    Interestingly, they sell two different types of Ferrari 308 extenders that they rate as 0 ohm and 2k ohm.
    http://www.kingsbornewires.com/SearchResults.asp?Search=extenders
