QuickJack BL 5000 SLX from Cosco | FerrariChat
Discussion in '308/328' started by Freddie328, Jan 12, 2020.
  1. Freddie328
    Freddie328 Formula Junior
    Jul 29, 2013
    294
    Herts, UK
    Richard
    Morning All
    Does anyone use this jack with a 3X8?
    If so, does the cars possible jacking points suit this lift, and if so how easy is it to use?
    Many thanks in advance for any comments.
  2. jcurry
    21,572
    In the past
    Jim
    here are 8 pgs of discussion on the Quick Jack, including on 3x8
    https://www.ferrarichat.com/forum/threads/quick-jack-lift.575737/
    I have the 5000EXT, which is almost too long for the 308 but it does work and it also works on all my other vehicles. The standard 5000 would have been too short on some of them.
    Freddie328 likes this.
  3. Jonny Law
    Jonny Law F1 Rookie
    3,174
    Over yonder.
    IT Guy
    I have the BL-3500 and it works fine for me.
    Andreas Engesvik and Freddie328 like this.
  4. thorn
    thorn F1 Rookie
    3,322
    Tallahassee, FL
    Never used one... but will point out that the idea of those things scares the hell out of me.
  5. Jonny Law
    Jonny Law F1 Rookie
    3,174
    Over yonder.
    IT Guy
    I can tell you my car has been on a Quickjack for three years with no issues. Sadly, it been a Quickjack for three years. My biggest concern is there will be an earth quake before I finish the projects.
  6. Nuno Andrade
    Nuno Andrade Karting
    Aug 24, 2019
    154
    Houston
    Nuno Andrade
    I’m on the process of buying one. A big friend of mine and also 308 owner told me that the 5000 alone didn’t feel safe and decided to exchange for the EXT. He said that the EXT is perfect
  7. mixedgas
    mixedgas Karting
    Apr 23, 2019
    99
    Ramona, CA
    Interested in getting one for my 328. Is the 5000EXT the quickjack to get? Any lifting pucks etc you fine folks would recommended?
    Thank you
  8. Nuno Andrade
    Aug 24, 2019
    154
    Houston
    Nuno Andrade
    Mine is arriving today...according to a 308 owner, we should go with the EXT....more stable/safe
    mixedgas likes this.
  9. Freddie328
    Jul 29, 2013
    294
    Herts, UK
    Richard
    I bought the SLX. It’s fine, but use it so it pushes the car slightly forward when raising. That way the centre of gravity is more in the centre of the Jack. This procedure would probably be reversed for front engined cars. No need for extra mounting blocks - the ones supplied work fine with a 3x8.
    Andreas Engesvik and mixedgas like this.
  10. Nuno Andrade
    Aug 24, 2019
    154
    Houston
    Nuno Andrade
    What lifting points do you use? Any of the diagram below? The normal lifting points will not allow the jacks to be parallel Image Unavailable, Please Login
  11. kcabpilot
    kcabpilot Formula 3
    Apr 17, 2014
    1,527
    California SF bay area
    Paul
    I can't see how there would be an issue with either of these if they are rated for the load. Once it's locked it's certainly as safe as jack stands. Personally I went with the MaxJax which is a mid range two post lift that will work in a standard garage. It will give you 56 inches of lift which is enough to sit in an office chair and roll under the vehicle but I'll be honest and tell you that a post lift is not ideal for all situations because it interferes with the doors and getting in and out of the car or accessing the interior. A QuickJack or even a scissor lift of some sort works well on a 308 because there is really nothing in the center section of the chassis that you need to get to. I mean really, there's nothing there.
    So bottom line is - you need both.
    Typical Ferrari - two of everything...
  12. Sigmacars
    Sigmacars Formula Junior
    948
    Toronto
  13. Freddie328
    Jul 29, 2013
    294
    Herts, UK
    Richard
    Andreas Engesvik likes this.
