Questions from those that have owned both a F430 and 360 | FerrariChat
Discussion in '360/430' started by Rowan, Oct 19, 2017.
  1. Rowan
    Rowan Rookie
    Nov 12, 2003
    20
    I am on the fence with regard to buying a 360 or an F430. I would greatly appreciate feedback from those that have experienced both cars.
    I typically hold on to my cars for 10+ years and would expect to drive it @ 3,000 miles a year.
    The lure of the the 360 is:
    - can easily find a gated car
    - less expensive
    - I like the lines a bit better
    With regard to the F430
    - no belt issues
    - more of a performance car
    - more modern
    - already have a manual transmission Porsche which which gives me variety
    My assumptions:
    - prorated over time, the maintenance costs average about the same or close
    - The F1 will not get boring
    - should get at least 10K miles out of an F1clutch
    - build quality is better in the F430
    With regard to maintenance and service - I can do the majority of it (I would need to bring it to an indy to set the PIN for the clutch or if there was a problem that required software for diagnosis).
  2. Eric C
    Eric C F1 World Champ
    11,136
    St. Louis, MO
    Eric
    The F1 clutch will last ALOT longer than 10,000 miles if you know how to drive it.
    I love my F430.
    2bf360, Formula1r and Skidkid like this.
  3. cfensty
    cfensty Formula 3
    1,109
    South Carolina
    I’ve owned both and your comments and assumptions are pretty accurate. The only thing I would add is to really track down service records so you know the car was maintained properly and confirm clutch life. Clutch measurements are an issue with both cars. When I bought my 430 they were all over the map between the seller, the local dealer and the PPI because the software can be manipulated for clutch life and there are different versions of TCUs depending on the year.
  4. Skidkid
    Skidkid F1 Veteran
    9,650
    Campbell, CA
    John Zornes
    Yep, belts or chains makes little difference in overall maintenance costs.
    Over time you will come to love the F1. It is very fun to drive.
    Eric is right about the clutch, think more like 40-50K is pretty easy.
    Build quality is about the same between the cars.
    I went with the lines I like the best. The 360 is a little more engaged to drive than the 430 as well.
    cavlino and Formula1r like this.
  5. kiryu
    kiryu Formula Junior
    Mar 28, 2016
    409
    Los Angeles
    I have the original clutch worn about 25% at 12k miles.... depends how u drive it it will last a lot longer than 10k
  6. 3POINT8
    3POINT8 F1 Veteran
    5,473
    I'm at 13k miles on F430 and have worn about 20%
  7. blkdiablo33
    blkdiablo33 F1 Rookie
    Jul 12, 2004
    4,497
    if you can spend more $ get the f430 ,ive owned both and 430 is the best choice imo eitheir way your gonna get a ferrari win win
  8. robertpel9
    robertpel9 Formula Junior
    492
    Orange County CA
    Robert
    I got the 360 simply because i like the lines MUCH better. Maintenance is the same, who cares about a 1800 belt service every three years, thats just noise in the big picture. If you learn how to drive the F1 and have a mechanic who will adjust the PIS every 6 months or so for you for free then there is no reason to not get at least 30-40k out of the clutch
    To me it's jsut a matter of what looks better to you. Unless you are tracking it either is more than adequate for the street
    Formula1r likes this.
  9. TheCook
    TheCook Formula Junior
    Oct 16, 2015
    304
    Buckinghamshire
    Ian
    I've not driven a 360 but I have an F1 430 and a manual 911 and the combination is great. Manual 911 is just brilliant on tight country lanes, F1 430 in another league on track and more open roads. You may find the 911 and 360 too similar in power whereas the 430 is a significant step up and thus keeps things interesting.
  10. Bob in Texas
    Bob in Texas F1 Rookie
    Apr 23, 2012
    2,751
    Just East of Weird
    Bob
    I’ve owned both. Had aN 02.360 and now own an 08 430. While I liked the lines of the 360 better, the 430 is a more modern car with much nicer interior and more HP. Both cars were F1. Find some local examples and drive them both. You’ll know what you want.
    Sent from my iPad using Tapatalk Pro
    whatheheck likes this.
  11. Dewinator
    Dewinator F1 Veteran
    7,783
    WA
    I’ve had a 911 with a PDK system that blows away the 360/430 F1 system for a few years, and if you’re into the fully engaging driving experience, no auto will ever make you happy. Gated or bust.
  12. whatheheck
    whatheheck F1 Rookie
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
    I had a 2003 360 Spider. Sold it and now own a 2006 F430 Spider. Both cars are outstanding but I like the F430 better.
    Your posted inputs are spot on.
    The F430 F1 transmission ECU in my opinion is much better than the 360.
    There is definitely much less clutch slippage compared to the 360 so I too expect to get better clutch life on my F430.
    Before I sold my 360 I had to replace the clutch. At 21,000 miles it had 78% clutch wear and the transmission started popping out of gear.
    Removed and replaced clutch and all is good again. That was $8,600.00. Ouch!
    The usual when buying a car - find one that is very well maintained with service records in hand, clutch newly replaced, low mileage, excellent condition.
    I am 1000% happy with my F430.
    Dan
    cavlino likes this.
  13. dwe8922
    dwe8922 Formula Junior
    Feb 27, 2004
    403
    FL
    David
    I sold my gated 360 to get my scud, so not a fair comparison, but from my limited time in a regular 430 I would choose the 430. It's a more developed model, since the two cars share so much in common. Think of the 430 as a 360.2. I tracked my 360 some early on, and the oil temps were always higher than I was comfortable. I took a student for some hot laps in his 430, and the oil temps were so much more stable. The 430 has better build quality, more power, and less maintenance. The only downsides to it is it feels a little heavier (because it is), and there are more parts to go wrong with the F1 setup. Both are great cars though.
    David
  14. whatheheck
    Mar 27, 2006
    4,148
    Seattle, Wa
    Dan L.
  15. ttforcefed
    ttforcefed F1 World Champ
    19,285
    unless you care about pure HP id go 360 with a stick. if you care about max hp etc then u have to go 430.
    I'm 360 Canuck likes this.
  16. ar4me
    ar4me F1 Rookie
    Apr 4, 2010
    3,114
    Southern California
    Jes
    I have a 360 3-pedal car and a 430 Scuderia (Scuderias are all F1), and if I could only keep one, then I would likely keep the 360 3- pedal car. If your heart is leaning towards a 3-pedal car, then I would go with the 360 3-pedal car. No e-diff to worry about, no F1 to worry about, ... a more basic car.
  17. I'm 360 Canuck
    I'm 360 Canuck Formula 3
    Nov 21, 2015
    1,911
    Ontario, The Real One in Canada
    Lars!
    For me, i actually liked the f430 lines better than my 360....I kind of "settled for it" as I could get a great price on a 3 pedal. BUT, once I saw my 360 side by side with a 430 at a show, I actually appreciated the 360's lines better....although there still some details about the 430 I like better (interior, headlights, tail lights, motor). Until a 430 price is on par with my 360, it isnt a hard choice for me, or one I regret. I don't expect that to happen.
  18. RossoCorsaItaly
    RossoCorsaItaly F1 Rookie
    4,685
    LA & OKC
    Kevin
    gated 360 is cheaper up front and will be worth more than F430 in 10 years, plus looks better & sounds better.
    f430 more modern, but who cares, it's not a daily.
  19. bball16
    bball16 F1 Rookie
    4,162
    NY LI FtL
    I had a 360 Spider that I absolutely loved. I traded it for a 430 Spider when the 360 needed belts and the defroster vents warped. When I realized I was looking at a $10k bill it made more sense to trade the 360 for a 430 that had only 4K miles on it. As much as I loved the 360 I've never regretted the move.
  20. Rosso328
    Rosso328 F1 Veteran
    7,362
    Central FL
    Paul
    Mine is. And I will say it is a very easy car to live with daily.
    Also I prefer the 430 looks to the 360. Just that but more aggressive and less 'melted jelly bean' without going full on Lambo.
    bball16 likes this.
  21. G. Pepper
    G. Pepper Three Time F1 World Champ
    38,771
    Texas/Colorado
    George Pepper
    I would not trade my stick 360 even for an F1 430. The 360 is the most beautiful mid-V8 Ferrari has ever made, to my taste - and I have a 308 - and nothing beats or even meets a stick for us old guys. Sure, the 430 es mas macho, and it is objectively a superior automobile, but I don't buy Ferraris objectively; I either fall in love with them, or I don't. I love the stick 360. I'd take an F1 430 if you gave it to me. A 430 stick is another matter altogether.
    Stick 360's are never going to be more affordable than they are now, IMO. The late 430 F1's will probably drop some more.
    Don't think I hate the F1 either, because I'd rather have an F1/a 612 for a touring car than a stick (But the stick is an investment grade car), because the auto mode in town/traffic is a huge advantage. Still the F1 is fun out on the back roads, and that's where the sport part of sport touring happens.
    I actually understand if some of you younger guys prefer the F1.
    KBR54 likes this.
  22. 2bf360
    2bf360 Karting
    Dec 18, 2014
    62
    WA
    Heng
    I don’t have to think twice if I can afford it, the latest model is always better. Before I bought my 2008 F430 spider, I was looking for f360. Since the price a bit more, so I bought the F430 instead.
  23. aleary360
    aleary360 Karting
    Nov 23, 2015
    172
    Westlake Village, CA
    Al Leary
    I have a 360 Spider now. F430 Spider arriving next week.
    I'll let you know
  24. JustinNY
    JustinNY Rookie
    Nov 28, 2015
    31
    Rowan, I’ve been debating this topic for a few months now and it can go on forever. $100K or so will easily buy you a nice example of both, 360 MT or 430 F1. 360 MT I don’t think will lose any more value, the 430 F1 will. Drive both, stare at both, go with the one that gets you more excited. You can always sell and change up...
    Mickster and cavlino like this.
  25. RedTaxi
    RedTaxi F1 Rookie
    3,365
    New Zealand
    Glen
    The main difference for me was the 430's bigger engine and better performance. The 360 was fast but the 430 is another level up. As for looks I liked them both but I think I like my 430 more now. The only real reason I changed up was to get a manual trans. Surprisingly no 360 manuals for sale here while I was looking or in the 4 years I owned it. In that time 2 manual 430's came up and I pounced on one when a friend wanted my 360.
