questions about 330 GT 2+2 fuel system | FerrariChat
Discussion in 'Vintage (thru 365 GTC4)' started by StevenD57, Jul 30, 2013.
  1. StevenD57
    StevenD57 Rookie
    Feb 15, 2009
    15
    #1 StevenD57, Jul 30, 2013
    I am helping a friend resurrect some cars in his collection that have been in long term storage. One of these cars is a four headlight 330 GT 2+2 with a five speed transmission rather than the four speed with electric overdrive.
    As I found the car and got it running I was puzzled by the layout of the fuel system. I spoke with Kevin in the parts department at Algar Ferrari and described the as found condition. He sent me some pages from the parts book for the 330 GT and the 365 GT cars. After looking at these I thought what I had was someone's bad attempt at duplicating the fuel system layout of the 365 GT cars. They had eliminated the mechanical pump on the front of the motor from the system. The mechanical pump on the front of the motor is still in place but it is not connected to any part of the fuel system at all. Instead someone installed what look like the duel factory pumps from the 365 GT.
    I have made three diagrams of the fuel system. First is the as found condition. Next is the layout as I understand from looking at the 365 GT parts manual page. Last is the layout as I think it should be to function correctly.
    Right now I have redid the fuel lines to match the second diagram for what I believe the fuel layout for the 365 GT cars but I really feel like I want to change to match the layout of the last diagram that makes sense to me from working on other exotic cars. The reason is I feel the current layout as I think the 365 GT parts manual is showing ends up with the fuel rail to the carbs running at atmospheric pressure as it exists at the top of the tank where the fuel is returned.
    Can someone confirm I am understanding the fuel system layout as shown in the 365 GT parts manual (i.e. if I am correctly interpreting the picture there)? Also comments on my sense that that layout results in the fuel rail running at atmospheric pressure or not. And finally comments on my redesign that would make sense to me but I have not implemented yet.
  2. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,026
    None of the diagrams are correct.
    1.Line from tank to main filter.
    2. After filter, line splits with one going to the electric pump (should be only one electric pump), and one line going to the mechanical pump.
    3. Line from mechanical pump to glass bowl filter and then to front end of fuel rail at carbs.
    4. Line from elctric pump to rear end of fuel rail at carbs.
    5. NO fuel return line.
  3. John Vardanian
    John Vardanian F1 Rookie
    Jul 1, 2004
    3,076
    San Francisco Area
    John Vardanian
    Hello Dyke, so both pumps are essentially a one-way check valve then?
    john
  4. StevenD57
    StevenD57 Rookie
    Feb 15, 2009
    15
    OK, with this setup is there any regulation of the actual fuel pressure anywhere in the system? Assuming the mechanical pump is working by itself.
    The mechanical pump in this car has been eliminated from the fuel system. It is still in place on the front of the engine but it is not connected to any part of the fuel system.
  5. coryh
    coryh Karting
    Nov 26, 2011
    104
    The fuel pressure is adjusted by a straight slot screw on top of the regulators, or glass bowl filters.
  6. Van de Merghel
    Aug 18, 2006
    39
    Anaheim, CA
    That's the flow I have on my 330GT early series I.
    At 4. above, fuel goes through another glass bowl/pressure regulator before fuel enters to the rear of the fuel rail at carb. #3. The glass bowl/regulator is hidden by the windshield washer bag.
  7. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,026
    John: Correct both pumps have one-way valves in them, however dirt can get under the flat valves in the electric pump and cause the fuel to be just pumped around in a circle with very little getting to the engine.
    Starting with 330 GTC's, Ferrari added a calibrated fuel return line to the tank to fight the tendency for the fuel to percolate in the lines with the boiling pressure causing the needles to pop off their seats and dribble fuel down the carbs on hot soak conditions.
  8. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,026
    On a factory system with only a glass bowl filter/regulator after the mechanical pump, only the mechanical pump output is regulated. The electric pump pumps at only about 3 psi, so it does not need an additional regulator.
  9. John Vardanian
    Jul 1, 2004
    3,076
    San Francisco Area
    John Vardanian
    Thanks Dyke, good to know re the electric pump. Seems like it should come out from time to time for a cleaning.
    john
  10. 330gt
    330gt Formula 3
    Nov 12, 2004
    2,076
    Seattle, WA
    Kerry Chesbro
    Late 330 GTs (after ~8250) also had the small fuel return line.
  11. StevenD57
    StevenD57 Rookie
    Feb 15, 2009
    15
    #11 StevenD57, Jul 31, 2013
    Yes, the late two headlight 330 GT car I have here sitting beside the four headlight 330 GT car I was asking about has the small extra fuel return line.
    So if I am understanding all of this the factory original fuel system for the non-late 330 GT cars is shown in the attached diagram. If I missed something please correct this with details and I will repost a new diagram.
  12. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,026
    This is correct. Good job.
  13. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,634
    NJ
    Peter
    It looks like the mechanical pump path is filtered twice. Great thread - I always thought the electric pump was a feeder for the mechanical pump, so it is helpful to know how it actually works. Given this, I can't help but wonder why they need the mechanical pump at all - it seems like just the electric pump would be sufficient.
  14. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,026
    Peter: Actually, it is the other way around. The cars were designed for the main pump to be the mechaincal unit. The electric pump was there to fill the carb bowls for cold starting and to add extra fuel on long high speed runs, or to help when the mechaincal pump vapor locked during a long period of hot idle condition. When everyting is working correctly, the electric pump is never needed when you are driving the car in normal conditions.
  15. peterp
    peterp F1 Veteran
    Aug 31, 2002
    6,634
    NJ
    Peter
    Thanks Dyke. I do recognize that the electric pump is just a helper for starting and I use it as such, but with so many other cars that have only an electric pump I wonder why Ferrari used both. Of the two pumps, the electric seems more necessary because it is needed for initial starting, so then why have the mechanical pump? I guess for one thing, the mechanical pump doesn't make the clicking sound. Could it be there is some benefit to the mechanical pump output varying based on RPM or are both pumps there just to add redundancy for reliability?
  16. StevenD57
    StevenD57 Rookie
    Feb 15, 2009
    15
    Can someone describe in more detail what the tiny additional line (third line) leading back to the firewall area from the back of the fuel rail on later cars actually does and how it is routed? I know the single headlight car here and the 330GTC both have that but not the late four headlight car I am currently working on.
    Thanks for all of the info so far.
  17. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,026
    Steven: The tiny line from the rear of the fuel log is a "return" line to the fuel tank. It has a restrictor in the end of the fuel log that only allows a small volume of fuel to flow back to the tank, thus keeping adequate pressure and volume to the carbs. The purpose of this is the relieve the build up of pressure in the fuel system when the car is shut off and "heat soaks" the engine. Many times, this heat soak will cause the fuel in the lines to boil and the resulting pressure will force the carb needlles off their seats and let unwanted fuel overfill the carbs and flood the engine. When the engine is hot, this system also allows some constant flow of cool fuel to the log, even when the engine is not needing very much (idleing).
  18. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,026
    Peter: You will notice that the cars using electric pumps only, use Bendix (Facet) pumps. It is my guess that even Ferrari knew the Fispa electric units were not totally reliable, so they did not ask them to run all the time, but used them as secondary supply sources for fuel. The Ferrari and Maserati race cars of the era used FIMAC rotary mechaincal pumps assisted by one or more Fispa electrics, but never only Fispa electrics.
  19. Van de Merghel
    Aug 18, 2006
    39
    Anaheim, CA
    That's interesting, why did the early 330 GT had 2 in-line fuel/filter regulators (glass bowl type)?
    330 GT Parts book TAV. 8 does show #13 as FISPA 3064-02 "Filtro regolatore benzina' Quantity 2.
    Was there a problem on the early 330 GT fuel system that the factory had not yet quite solved by production time?
  20. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,026
    I agree that there are some 2+2's with two glass bowl filters. I have no idea what the reasoning was for using two filters, and the factory quickly switched back to just the one unit after the mechanical pump.
  21. Van de Merghel
    Aug 18, 2006
    39
    Anaheim, CA
    As you are saying above, in your post #17; that's probably the reason why after engine shut-off when "heat soak" sets in, the fuel percolates in the carbs and flows down the throats until fuel pressure is eventually relieved. The rear glass bowl filter/regulator prevents the fuel from returning to the tank and quite possible maintaining pressure. That's the reason why when I park my 330 in the garage with a hot engine, I leave the hood open to let the heat and the gasoline fumes out, turn the garage fans to air out the place and cool down the engine.
  22. DWR46
    DWR46 Formula 3
    Honorary
    Jun 19, 2012
    2,026
    Van: I do the same thing when we come home after a drive.
  23. Van de Merghel
    Aug 18, 2006
    39
    Anaheim, CA
    Ahhhh, the things we do to keep on driving/enjoying these machines!!!!!!!!!!!!
  24. StevenD57
    StevenD57 Rookie
    Feb 15, 2009
    15
    #24 StevenD57, Aug 6, 2013
    I ended up having to remove the twin Bendix fuel pumps that were on the four headlight 330 GT and replacing both of them with a modern single pump from AirTex that had a Carter brand stamped on the actual pump case. I used a T to plumb both outlets from the factory pre-pump fuel filter (under car back by gas tank) into the inlet for the new pump. The outlet of the pump goes up to the original glass filter bowl up on the front fenderwell and then into the front of the fuel rail. I also fitted a return style pressure regulator to the line coming from the back of the fuel rail that leads to the back of the car. This is set at 2.5 PSI and returns to the tank.
    Fitting this single pump let me get the fuel pump mounted much further up into the underside of the car. Previously the twin bendix pumps hung down VERY close to the top side of the muffler on that side of the car. Some previous hack job had installed the twin bendix pumps and then fitted a make-shift heat shield between the bottom of the pumps and the top side of the muffler.
    I first fitted the Mallory fuel pressure regulator to the system with the Bendix pumps in place but they still would not reliably hold fuel pressure for more that a few minutes of driving around in a parking lot at slow speeds.
    Once I competed all of these changes the car seemed to run much better. The only major things left to complete is to finalize the timing and fix a broken cable on the window lift system for the driver's window.
