Question for the guys with a 4 post lift | FerrariChat
Discussion in 'Detailing & Showroom' started by bocaf430, Nov 8, 2015.
  1. bocaf430
    bocaf430 Formula 3
    Jun 10, 2014
    1,361
    LI, boca raton
    I am thinking of putting a 4 post lift in my garage... Is it easy to drive a low car on and off ? My f430 is lowered, and I'm just wondering if it's more of a hassle driving on and off the lift each time I take the car out... You need to attach ramps, remove ramps.. I know it's great for storing a car or working underneath the car, but do you find it bother to use in everyday use? I guess you could always just leave it up and drive underneath each time... Just wondering if after the newness wears off..would you still put the lift in your garage.
  2. Randy R
    Randy R Formula Junior
    346
    SF Bay Area
    '14 Cal 30 TDF/Tan
    At this moment, I do not need my lift for the extra storage (yet), so I park my least driven car underneath it. I'm really glad I have it: not just for my convenience, but I've had many friends come over to use it. If I had to do it over again, then I wouldn't hesitate to install one.
  3. JohnnyRay
    JohnnyRay F1 Rookie
    3,492
    Central FL/NW WI
    Randy...you did not answer the question we all have. Is it easy to drive a car with long/low overhangs on and off? What do you have to add to reduce the approach angle?
  4. Andrew D.
    Andrew D. F1 Rookie
    Jul 6, 2008
    3,979
    Goodwood Ontario
    Andrew D.
    Make sure the lift you buy has long detachable ramps. Mine are 3ft long and low cars go up with no problem. Good for storage, not great for mechanical work. For that I have a 2-post commercial ( my head is worth more than the lift)
  5. LBBP
    LBBP Formula Junior
    The approach ramps are plenty long for low clearance cars, plus if need be one can place a thin shim underneath the ramp approach lip to decrease the incline angle. Four posts work well for maintenance, but necessitate buying bridge jacks to lift the vehicle up off the lift ramps. I've never found the lift to be a hinderance to parking on it or under it, one does have to remember the long first step getting out of the car while on the lift though.
  6. 11506apollo
    11506apollo F1 Rookie
    2,656
    Tx Co Ca
    +1
    same thing here. None of my cars is lowered, but I would imagine shimming the lip would decrease the angle, thus facilitating rolling the car onto it. My ramps stay connected all the time. As far as car maintenance goes, the sturdy bridge is a low cost and must have accessory to any 4 post lifts. Once the front or rear is lifted with a jack supported by the bridge, it is easy to slide and put two jack stands resting on the main rolling surfaces. What I like on 4 post lifts is the solid sensation of the car resting on 4 columns. After lifting and listening for the safety arms click in place, I lower the lift a little and it is nice to see the lift grabbing solidly, so I have peace of mind the car is secure and I am safe to work underneath it. I am not so sure I would feel as safe under a 2 post lift. Don't own one, so I can't really provide an opinion on a 2 post lift, but I trust 4 tires resting on parallel beams better than the car resting on 4 round spots. These 4 spots are not as wide and spaced apart as the 4 tires are. I am not saying 2 post lifts are unsafe...I just prefer 4 posts. Cheers
  7. Randy R
    346
    SF Bay Area
    '14 Cal 30 TDF/Tan
    I have 3ft aluminum ramps, which are really easier to move. I have not driven my California up onto my lift, however I've driven my lowered 545i, my Superformance Cobra, and my '67 E-type onto my lift without any problems at all.
  8. LostAussie
    LostAussie Formula Junior
    Jun 13, 2013
    709
    Piemonte
    Stuart
    You may be on to something
    [ame]http://www.youtube.com/watch?v=Ad8N6yuWzk8[/ame]
  9. Face76
    Face76 F1 World Champ
    13,191
    The Other Oz
    M Wilborn
    Have had a 4 post lift for quite some time and have never had an issue with clearance. I would also agree that this could be solved with adaptation of the ramps.
    I don't do much wheel or suspension work on my cars due to the need for cross braces and jacks. I view 4 post lifts more for storage which they are very good at.
  10. godabitibi
    godabitibi F1 Veteran
    Jan 11, 2012
    6,329
    Papineauville, Quebec
    Claude Laforest
    What I like of my 4 post lift is that just drive on and off easily. No need to set extendable arms. The two ramps are large enough you can use your floor jack and jackstands as if you were on the floor and then lift the car to your desired height. There is no post in your way when you need to open the door.
  11. netman
    netman Formula 3
    Jun 17, 2008
    1,905
    OC SoCal
    I have a bendpak 4 post sitting on one inch plates that wide enough and goes up far enough to clear the doors of my Diablo parking underneath. The rams are the long aluminum ones and can be lift attached to the lift while raised or removed.
  12. 483hp
    483hp Formula 3
    Aug 17, 2005
    1,428
    www.fca.alberta.com
    A 430 should be no problem. I back my cars on my lifts and none of them have a problem. The F50 does need the nose raised beforehand and it doesn't touch.
    To test, borrow a ramp and slide it under the nose until it touches the tire. If nothing touches then you are good.
  13. Davesvt2000
    Davesvt2000 Formula 3
    May 3, 2005
    1,140
    Central Mass.
    Dave G.
    I simply put a piece of 2x10, cut about 3 feet long, under each ramp to decrease the angle.
  14. Theschneid
    Theschneid Rookie
    Sep 20, 2013
    43
    Wellington, FL
    Jeremy S
    I have a bendpak four post lift-have 48" aluminum ramps and buily additonal ramp extensions out of wood. Its all part of the process which i enjoy.
  15. Meister
    Meister F1 Veteran
    5,516
    Duluth, MN
    The Meister
    I just bought a lift with 41/2" high rails and only 2' ramps. I was concerned about needing longer ones to get the esprit and /or 348 on, but they work just fine. Very close to hitting, but they don't.
    As for everyday use, sure it takes a little more time than just driving in the garage and closing the door, but once you get used to the routine, its not a big deal.
