Quality Hose Clamps?
Discussion in 'Technical Q&A' started by lou staller, Jan 31, 2005.
  1. lou staller
    lou staller Formula Junior
    Dec 21, 2002
    378
    Orange County Ca
    Lou Staller
    I've replaced all the hoses on my '84 308 QV and do not want to use the crappy hose clamps that all the parts stores sell. I'm looking for clamps with rolled edges and raised catches rather then clamps with slots cut into the band. And of course being that I will need to buy about a billon clamps I don't want to refinance the house! Anyone know where I can get the better clamps? Thanks
  2. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I found the type you describe. They are a solid band with raised teeth instead of slots cut in the band. There is also a sleeve under the worm-drive area to prevent scuffing the hose. These are designed to be used with the trick silicone automotive hoses on the ricers around town.
    They are called Gator Clamps and are distributed by Competition Cams. You should be able to find them at just about any performance store.
    I had to order one size smaller for my 1/4" hose than Gator provided. The clamp was made by Gemi of Germany.
    Prices started at a buck a piece and went to 1.50 or so .
    They come in aluminum or stainless steel. Make sure they are getting you the stainless! They don't strip out as easy.
  3. lou staller
    Dec 21, 2002
    378
    Orange County Ca
    Lou Staller
    Found what I am looking for! McMaster-Carr has 430 stainless steel, nonperforated, rolled edges worm drive hose clamps. They run about 80 cents each. Cool!
  4. robertgarven
    robertgarven F1 Veteran
    Feb 24, 2002
    5,282
    Ventura, California
    Robert Garven
  5. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    Nice indeed.
  6. lou staller
    Dec 21, 2002
    378
    Orange County Ca
    Lou Staller
    My car is not worthy of the ABA clamps! They are awesome!
  7. robertgarven
    Feb 24, 2002
    5,282
    Ventura, California
    Robert Garven
    #7 robertgarven, Feb 3, 2005
    They are not technically correct but I use them where it is a fuel or coolant application cause I drive the car and dont want to catch fire or leak.
  8. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    ABA clamps only sell through McMaster-Carr, but are not listed as such under McMaster's online catalog. Supposedly, they are carried at West Marine stores (boating), but my local West Marine does not stock them. They don't want to sell direct.....good luck finding the damned things!
  9. sandersja
    sandersja Formula Junior
    Jan 16, 2003
    367
    Portland OR
    John Sanders
    These clamps are widely available through import performance outlets. Esp for turbo cars, ABA and even better types of clamps, are commonly used. Google for hose companies.
  10. 8valve
    8valve Formula 3
    Sep 3, 2003
    1,029
    Netherlands
    Mick A.
    Maritime hardware shops in Marina's often sell very nice high-quality hoseclamps.
  11. Mark 328
    Mark 328 Formula Junior
    Nov 6, 2003
    510
    Orange, Ca
    Mark Foley
    This place has lots of Ferrari/European hardware, hoses, ect. Including Norma and ABA hose clamps in Std and Stainless Steel.
    http://www.newcoproducts.com/
    Mark
  12. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    The Gator Clamps I mentioned are made by Norma with the exception of the smallest, 1/4", made by Gemi.
  13. 8valve
    8valve Formula 3
    Sep 3, 2003
    1,029
    Netherlands
    Mick A.
    I'm sure the quality of the ABA clamps is very good, but I just can't stand the blue paint on them. Makes them look very cheap I think(although I believe they also make other ones in all SS). I have used Norma clamps in the past on my first Ferrari,they look really nice and original.
  14. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    Well, call me stupid, but I just bought a box of 315 Stainless (marine grade) worm-gear clamps from Ace Hardware. They seem to tighten down well, although I'm using Gates Green Stripe in 1 5/8", so they'll need to be tight to take up the exta 0.6 MM around each pipe. I had one 'blow out' on me, the worm gear chewed the threads out of the steel band. All others appear to torque down pretty tight. I'll be filling and testing out the pipes today with a Coolant pressure tester - should I have failures, I'll probably be special-ordering the ABAs and have to re-do much of the cooling system.
  15. Dale
    Dale F1 Veteran
    Oct 7, 2003
    5,211
    uk
    Dale Juan
  16. lou staller
    Dec 21, 2002
    378
    Orange County Ca
    Lou Staller
    MJames, How did your pressure test go? Thanks everyone for your input. I bought a couple hoses from another F-Chatter and all is fine. I used Napa Auto Parts S/S clamps which seemed to work OK. No blowouts, just a nice tight fit.
  17. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    Well, I dumped 6 gallons of coolant/water into the system - she takes just UNDER six gallons, I had to bleed some off at the radiator. It sure helps to leave open a bleed screw (radiator first, then thermostat housing) so the air can escape as the coolant fills all those hoses/pipes.
    Once the system was full, I attached the coolant system tester and pumped away.....after several tries with the sealing cap, I got a good seal and pressurized the system to 16 PSI. I had leaks at the radiator bleed screw, thermostat bleed screw, a hose clamp at the water pump, and finally the thermo switch into the coolant expansion tank was loose. Once everything was tightened down, I let everything sit at 16 PSI for a few minutes and checked around. No leaks in the system, so I'm guessing that I'm done.
    Is 16 PSI enough pressure?
  18. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    Heh, checked the owners manual - it states 12,8 PSI on the filler cap.....
    What the heck is 12,8? I assume they meant 12 PSI......
  19. Steve Magnusson
    26,571
    Michael -- In most places outside of the US, the character used for the decimal point is a comma (not a period) -- so 12,8 = 12.8 in US-speak. (You should be grateful that they translated it to p.s.i. rather than leaving it as something like "0,9 bar" ;))
  20. geekstreet
    geekstreet Karting
    Feb 7, 2005
    220
    Cam
    M.James,
    Latest rad caps are uprated to 1.1 (1,1) bar = 15.96psi, say 16psi.
    When I recently went from an old 0.9 bar cap (with distorted pressure flange) to a 1.1 bar unit on a 3.2 Mondial I suffered a series of leaks & failures - expansion tank, tank->block hose & block->heater valve hose.
    Testing beforehand would have probably shown up some weaknesses, although pressurising when hot is the ultimate "test".
    BTW, any advice on replacement hoses for 3x8 engines? The cloth-reinforced OEM ones are damned exe - are generic "auto-shop" ones up to the job or is it necessary to source "special quality" ones? I'm talking the smaller gauge straight lines such as 16mm & 19mm.
  21. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    WOW....I have a 20 PSI radiator cap on mine. That sucker is coming off this weekend for good, even though its new. Since I tested everything to the 16 PSI limit, and sealed everything, I should be more than safe with a 12/13 PSI cap in place from now on...
    For the coolant hoses, I can't rave enough about Gates Green Stripe in 1 5/8" (which works out to 40.6mm internal diameter). The Ferrari pipes are 40mm, so 40.6 gives you a very comfortable installation, with a good seal from a standard worm-gear hose clamp. I used pure silicone spray to lubricate the hose, and it easily slips on to every fitting in the car. The hose comes in three-foot 'sticks' and can easly be cut to length with a handheld coping or hacksaw. Many of the lengths you'll need for a Ferrari 308 are roughly 5-6 inches each, but there are several of these all over the car.....You really should replace the hoses under the front of the car, where the send/return coolant tubes emerge from the transmission tunnel area. Mine were 20-year-old OEM rubber hoses, but are extremely hard to reach if you don't have the battery tray pan off the car. Since I also had the valence off as well, it made for easy access and replacement. If a old hose/clamp needed pursuasion during removal, use a Dremel with a thin cutting wheel to slice the hose/clamp lengthwise, and pull it apart with your fingers. There are two coolant hoses under the car, between the fuel tanks. I used the Dremel on one, and a VERY sharp shop knife on the other -space was very tight here. NEVER press too hard and nick the aluminum tube under the hose, you just want to cut the rubber.
    For air/heater hoses, I wouldn't kill yourself looking for the external black cloth braid. Unless you plan on a concourse restoration, go to your nearest Mercedes dealership and take some samples with you. They can size up replacement lines from behind the counter, or help you source quality metric-diameter lines in your area. The clear CAVIS Benz hose that extends down from the coolant expansion tank is quite rare to source, but if you need these types of OEM-style hoses, these are the folks who can hook you up:
    http://www.newcoproducts.com/index.htm
    My local Authorized Mercedes dealership hooked me up with free hose when I mentioned that they were for a Ferrari, your luck may vary. One word about the CAVIS lines - the hose walls are VERY thick, and can interfere with turning and removing the radiator cap since these hoses are often installed way past the sealing ring on the pipe fitting. I prefer the clear hose, so you can at least see the coolant color clearly in an overflow situation.
  22. geekstreet
    geekstreet Karting
    Feb 7, 2005
    220
    Cam
    #24 geekstreet, Feb 16, 2005
    Thanks a bunch for the info.
    FYI I was under the car last night & saw that the heater intake hose (that runs from the heater valve in the engine bay across the lower face of the oil cooler & connects to the al tube which runs forward to the cabin) was v. badly chafed from the oil cooler surround. The hose is part #43 in the fig below.
    It runs so close by the cooler & the cooler edges are so sharp that I can't see ANY hose not chafing! This is how it is on a Mondial - is the 308/328 similar? I am thinking of replacing it with a sleeved hose (say 19mmID hose with a length of ~30mmID hose as a sacrificial protective sleeve).
  23. Steve Magnusson
    26,571
    308 don't have that particular layout/problem, but they share the need to have "protective sleeves" added in many places -- especially on the large Aluminum coolant tubes (which shouldn't touch anything other than their "protective sleeves").
