Purple Power Degreaser? | FerrariChat
Discussion in 'Technical Q&A' started by PT 328, Feb 2, 2011.
  1. PT 328
    PT 328 F1 Rookie
    3,999
    I am looking to degrease the 24 years of gunk on the underside of my 328. I have found a product called purple power at Autozone and am wondering if anyone here has used it to degrease their engine and if so did you dilute it and by what ratio?
    The last thing I want to do is cause damage to the aluminum.
    I did a search but found limited info on this stuff.
  2. EMI-SC
    EMI-SC Karting
    Aug 2, 2008
    113
    Chris Felber
    This works great. We use it to clean transmissions and engines.
  3. PT 328
    PT 328 F1 Rookie
    3,999
    Thanks for the input. Do you dilute it or use the industrial strength without diluting it?
  4. EMI-SC
    EMI-SC Karting
    Aug 2, 2008
    113
    Chris Felber
    Mix as needed. If it's really nasty I'll spay down the engine and follow with water.
  5. Mark 328
    Mark 328 Formula Junior
    Nov 6, 2003
    510
    Orange, Ca
    Mark Foley
    Previously, I used to spray Gunk & pressure wash my engine, but when I did the timing belts there was some very mild, but fresh corrrosion on the cams. After washing the car was driven for an hour, but probably some steam got in there.
    Also, some of those water based degreasers are hard on aluminium. Since then, my process has been to use a $5 Harbor Freight engine cleaning gun and Stodard solvent (Mineral Spirits). Put a plastic tarp down and go at it. Use some plastic lids to catch it in heavy areas. In actuality not much of the solvent is required and it is easy to wipe-up with some old rags. It does a good job.
    Mark
  6. PhilB
    PhilB Formula 3
    Feb 17, 2004
    2,303
    Southern New Jersey Shore
    Phil
    Simple Green makes an aircraft grade cleaner that is safe for aluminum. I use that mixed 50/50 with distilled water, spray it on and let it drip off, and then follow with a spray of fresh water, followed by compressed air.
    I use these sorbent pads from McMaster (#7193T83) and lay them under the car to catch the run off.
  7. ago car nut
    ago car nut F1 Veteran
    5,462
    Madison Ohio
    David A.
    I think Purple power has a mild acid in it. I used on my British motorcycle and it etched the polished aluminum. I also used it in my bathroom and it etched the mirror. On cast aluminum it probably will be fine. I think simple green is milder.
    Ago
  8. jm3
    jm3 F1 Rookie
    Oct 3, 2002
    4,364
    United States
    JM3
    Simple Green and Purple Power will each strip anodized aluminum, including clear anodized aluminum so be careful
  9. cmt6891
    cmt6891 Formula 3
    Feb 25, 2008
    1,335
    Encino, Ca
    Carl T
    +1 This is the correct way to insure no damage to the aluminum.
  10. PT 328
    PT 328 F1 Rookie
    3,999
    Thanks for the thoughts. I think I will look into the simple green aviation formula to be safe.
