proper resistor to use for rear window defogger | FerrariChat
Discussion in 'Technical Q&A' started by dhs-9, Aug 31, 2004.
  1. dhs-9
    dhs-9 Formula Junior
    Feb 6, 2004
    292
    My rear window defogger grid lines from age started to peel away so I removed them with a razor leaving the silk screen lines intact. I then got a grid line kit and put on brand new gird lines. The new grid lines are slightly wider and thicker than the original lines so when I plugged it in teh 12 volt supply caused the lines to get very hot (maybe hot enough to break the glass). Resistance with original lines at 3.4ohms new lines .8ohms.
    So I tried putting in a resistor to reduce the voltage. At 220 ohms the voltage before the resistor was 12v and after the resistor it was 47ma. I was surprised to see such a reduction I would have expected at 220 ohms the voltage drop to be minimal.
    My question is how can I find out what resistor to use and what wattage it needs to be. I figure somthing around 3 volts will reduce the wire temp to the right amount. I think if I could get the right trim pot I could turn it until I get the heat I want and then measure the reistance and put on a solid resistor, but I dont even know how many ohms the trim pot should be.
    Thanks for any help
  2. Verell
    Verell F1 Veteran
    May 5, 2001
    7,020
    Groton, MA
    Verell Boaen
    Uh,OH, Houston, we have a problem...
    Ohm's law: Voltage across resistor =Amperage thru it x Resistance in Ohms
    It can be rewritten the usual ways: V=A x R or A=V/R or R=V/A
    Power in Watts = V x A or A^2 x R or V^2/R
    12V/220 Ohms = 0.054 A pretty close to your 0.047 A.
    Old grid:
    12V/3.5Ohms = 0.8A
    12V x 0.8A = 9.6 W ~= 10W
    Your new grid:
    12V/0.8 Ohms = 15A
    15A x 12V = 180 Watts, Yup, that's gonna get very hot!
    To get about 10W out of that 0.8 Ohms you'll need:
    A = SQRT(W/R) = SQRT(10/0.8) ~= 3.5A
    Total resistance = 12V/3.5A = 3.4 Ohms
    Resistor = 3.4 Ohms total - 0.8 Ohms grid = 2.6 Ohms
    However, while the grid will now be dissipating 10 W, the resistor will also be dissipating 3.5^2 x 2.6 = 31.5 Watts!
    You'll need a metal cased 100W power resistor to keep it's temperature down, and it'll need to be bolted to something that can absorb & dissipate the heat!
    You can make it work.
    IMHO, That grid line kit is a very poor match to this application. Whoever sold it to you did you a real disservice.
  3. dhs-9
    Feb 6, 2004
    292
    My local electronics store has a 2.7 ohm 25 watt resistor. Do you think I can use it. I dont care if the grid gets hotter than the stock grid I only wnat to keep the temp down so the glass does not break.
  4. Steve Magnusson
    26,507
    You might want to be careful assuming that the steady-state "on" resistance (at high current/high temperature) would be equal to the resistance you measure at room temperature with a multimeter (at very low current/low temperature). Maybe not as large a change as a filament bulb sees, but I'd bet that the resistance increase at high temp is noticeable (10~15%).
    It's actually even worse than Verell's calculations indicated (the 12V/3.5 Ohm in the "Old grid" should be = 3.4 A and the resulting power is ~42W) so any added external resistance solution is going to be wasting an unacceptable boatload of power (136W) in the external resistor.
    Any possiblity/option to rewire a few of the resistive elements in a more series configuration rather than parallel?
  5. dhs-9
    Feb 6, 2004
    292
    I could rewire so that from the 12v terminal to the ground terminal would be one long wire. If I did this what would be the result and what value resistor and wattage would I need then. If I left it in parellel would 2.7ohm 25 watt resistor work. Thanks
  6. Steve Magnusson
    26,507
    "If I left it in parellel would 2.7ohm 25 watt resistor work" = No. Per Verell's calculation method (which I think is the right way to look at it -- you want near-equal power dissipation in the heating element), you would need at least a 150W-rated 2.7 Ohm resistor to put in series with your 0.8 Ohm grid. (And this would be crazy so don't look for one!)
    "I could rewire so that from the 12v terminal to the ground terminal would be one long wire" -- how many individual "lines" do you have and what is the resistance of an individual "line"? Do you have a jpeg (or sketch) of the "grid" in the configuration where you measure the 0.8 Ohms?
  7. dhs-9
    Feb 6, 2004
    292
    The 328 has 4 lines in parellel each about 3 feet long. I measured the resistance of one line individually at .8 ohms and measured one individual line on the original grid before I scraped it off at 3.4ohms. When I measured the original line I isolated it from the other lines before I measured its resistance.
    Each line as it is now goes from one buss bar on the 12v side to the other buss bar on the ground side each line parellel to the other. So the .8 ohms is for one line. I would think since all the line are connected and have continuity that the .8 would not change when three more lines are added in parellel
  8. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    I would "rewire" the pattern so that each line goes into the next as a series circuit in a "zig zag" pattern. Start at the top and send the current through the first line, then down to the next line and back across the window, down to the next line and across, etc. This places all 4 of the .8 ohm lines in series, giving you 3.2 ohms total. You'll have a cool "zig zag" defroster pattern, no wasteful resistor getting hot, no broken glass and no excess wear on your alternator.
    |-----------| <---What you have now
    ,---------------' <-----series connection
    If that's not hot enough, run two pairs of series connected lines in parallel. If the original wires had 3.4 ohms each and they were in parallel, then you had about .85 ohms total load for the whole circuit. Putting a pair of these new .8 ohm lines in series gives you 1.6 ohms, and putting two of these series pairs in parallel gives you .8 ohms for the entire window, which is the same as stock.
    Birdman
  9. Verell
    Verell F1 Veteran
    May 5, 2001
    7,020
    Groton, MA
    Verell Boaen
    OOPs! Good eye 91tr,
    I really blew my arithmetic! That throws all subsequent calculations off!
    Here's the corrected version:
    Old grid:
    12V/3.5 Ohms = 3.4A
    12V x 3.4 A = 40.8W
    Your new grid:
    12V/0.8 Ohms = 15A
    To get about 40W out of that 0.8 Ohms you'll need:
    A = SQRT(W/R) = SQRT(40/0.8) ~= 7A
    Total resistance = 12V/7A = 1.7 Ohms
    Resistor = 1.7 Ohms total - 0.8 Ohms grid = 0.9 Ohms ~= 1 Ohm
    However, while the grid line will now be dissipating ~40 W, the resistor will also be dissipating 7^2 x 1 = 49 Watts!
    You'd need a metal cased 100W power resistor to keep it's temperature down, and it'll need to be bolted to something that can absorb & dissipate the heat!
    BETTER SOLUTION:
    However, now that you've fully described what you've done, a much better solution may be possible: You have 4 lines, each at about 0.8 Ohms, and you want them to dissipate about 40W each.
    THIS SHOULD WORK:
    If you just put two of the lines in series, the resistances add which puts you at 1.6 Ohms. And 12^2/1.6 = 90 Watts for the pair. That's only ~10% higher power/line, and doesn't require an external resistor.
    This could then be repeated for the 2nd pair of lines, with the same effect for that pair.
    BTW, the formula for resistors in parallel is: Rtotal = 1(1/Ra + 1/Rb +1/Rc...)
    Thus the total resistance of this combination of 2 pairs of 2 lines in series would be 0.8 Ohms.
    THIS CIRCUIT ALSO HAS 45W/LINE BUT MIGHT BE EASIER TO CREATE:
    since you've already got all 4 lines bussed together, I suspect it would be simpler to do the following:
    On one side, break the connection joining the upper pair of lines to the lower pair of lines. Then connect power and ground to the upper and lower sections on that end. You end up with something like this:
    +12V<=================|
    GND <=================|
    The wo 0.8 lines in parallel will have a combined resistance of 0.4 ohms., then two more in series with bring the resistance up to 0.8 Ohms again.
    POWER SEEMS TOO HIGH:
    The above circuits produce 180 Watts (4 lines at 45W/line)!!! That's a lot of power for one small section of glass. I'm comfortable with 40 or 50 W for the total circuit, that's enough so that the glass is going to be fairly warm, but this is ~4x that!
    What size is the fuse for the window heater? The above circuits are going to draw 14Amps. I would expect a 30A fuse, or at least a 20A fuse. Since this is a 308, the largest fuse is going to be 16A, implying more like a 7A load.
    IMHO: 4 LINES S/B IN SERIES:
    If all 4 lines were in series you'd have 3.2 Ohms, and 45W total power.
  10. Verell
    Verell F1 Veteran
    May 5, 2001
    7,020
    Groton, MA
    Verell Boaen
    I see that Birdman & I must have been typing at the same time. We also reached the same conclusion.
  11. dhs-9
    Feb 6, 2004
    292
    If I make one long zig zag out of the 4 wires from 12v to ground are you saying that no resistor at all is needed and it will not get too hot as it does when in parellel.
    Also if I find it does not get hot enough are you saying to make 4 S shaped zig zags from 12v to ground and each seperate from one another.
    I would like to keep the window looking as original as possible. I would rather not add all these extra lines. The 4 that are now there are placed right on top of the grid lines silkscreened on the window
    Thanks for everyones help
  12. ham308
    ham308 Formula Junior
    Nov 3, 2003
    358
    NE Switzerland
    Richard Ham
    getting a bit late for school-boy physics here so maybe this is rubbish but, -
    old window is 4 strips at 3.4 ohm gives 0.85 ohms for the window (1/R=1/r+1/r....) and a power of 169 watts (V*V/R)
    new window was 4 strips at .8 ohm gives 0.2 ohm for the window and a power of 720 watts (mmmmm hot)
    don't know how they expect you to wire that stuff up, but you need the old resistance of 0.8 ohms. Strangely enough if you wire it up with two lots of two wires in parallel combined in series if you see what i mean (told it was late) then you'll get 0.8 ohms and bingo no problems.
    join the right hand ends together, can't get this to look right
    so resistance would be 1/(1/.8+1/.8)+1/(1/.8+1/.8) =.8
    might be an idea to check the sums though, you might blow the window out the back of the car :)
    best of luck...........
  13. Steve Magnusson
    26,507
    (Edit: Obviously, the other's previously posted the same thing, but thought I'd post the figures anyway)
    I think Verell and I both misunderstood your resistance values of 0.8 and 3.4 as being for the whole network with all lines in parallel rather than for an individual line. It doesn't change the conclusion that adding an external resistance (in order to keep the four 0.8 lines in parallel) is not going to work well, but it does mean that the rear defroster must be drawing a lot more current (unless the resistance changes more when hot) so if a 328 Owner with a working rear defroster could please:
    1. Unplug one side and measure the DC resistance of the combined 4-wire rear defroster grid (should be fairly low like 0.85 Ohms if I'm understanding the previous description correctly), and, the bonus question,
    2. Put an ammeter in series with the rear defroster and measure the total current when it's "on" (is it really 10~15A?).
    If you can do kind of a combination series + parallel wiring arrangement for the four 0.8 Ohm lines as shown below ("proposed") I believe it would have a very similar total current draw and power dissipation (does require moving both connections to one side).
  14. ham308
    Nov 3, 2003
    358
    NE Switzerland
    Richard Ham
    Think we've all been typing at the same time having reached the same solution
    I'm off to bed.. :)
  15. dhs-9
    Feb 6, 2004
    292
    I starting to see what you guys are doing but before I start cutting the grid lines I need to clarify what you are trying to diagram. On this car a 328 the right buss bar when looking from inside the car is connected to the 12v the left to ground. Im not sure If you guys want me to cut a buss bar in the middle to seperate the two pairs. And I'm not sure which buss bar to cut one or both and then after it is cut how it is wired from there.
    Thanks again
  16. Verell
    Verell F1 Veteran
    May 5, 2001
    7,020
    Groton, MA
    Verell Boaen
    180W (45W/line) ALTERNATIVE:
    The 45W/line alternative is to cut 1 buss bar in the middle creating 2 buss bars with 2 lines each on that side. All 4 lines remain bussed together on the other side of the glass. 12V & ground end up on one side of the window: 12V is connected to one of the newly created 2-line buss bars, and ground to the other 2-line buss bar.
    45W ALTERNATIVE:
    All 4 lines are connected end to end into one long serpentine line. as shown by Jonathan's 'series connection'. It too can be created by only cutting bus bars. Again,12V & ground end up on one side of the window.
    This is the alternative I'm most comfortable with. If it isn't warm enough, the 180W alternative can be created by re-connecting some buss bar sections & splitting others.
  17. axtman
    axtman Rookie
    Dec 10, 2003
    34
    Lincoln,CA
    Douglas Axt
    All you need to do is ask the people on FerrariChat.com and you get some great answers.
    Good luck David
    Doug Axt
  18. enjoythemusic
    enjoythemusic F1 World Champ
    Apr 20, 2002
    10,676
    Worldwide
    Steven
    Wow! Not only are you guys REALLY good, you ALL help at the same time.
    Thanks Fchat!
  19. dhs-9
    Feb 6, 2004
    292
    You guys are great.
    I will try the 45 watt surpentine route by taking a razor and cutting the foil on the right buss bar (12v side) just above the lowest grid line, then I will cut the left buss bar just above the second from the bottom grid line then I will cut the right buss bar just above the third from the bottom grid line and the remaining top portion of the right buss bar I will attatch it to a ground. This should give a surpentine route. Please let me know if I have interpreted your instructions correctly.
  20. dhs-9
    Feb 6, 2004
    292
    Before I start cutting please confirm I have it right as I described in above post
    Thanks very much for all the help
  21. Steve Magnusson
    26,507
    No, that would put all 4 lines in series -- please wait, and I will post a sketch...
  22. Verell
    Verell F1 Veteran
    May 5, 2001
    7,020
    Groton, MA
    Verell Boaen
    All 4 in series is what I recommended. 4 lines in series will provide about 45 Watts of heat. That should be more than enough to demist/defrost the window. With 45W, the entire rear glass is likely to be warm to the touch after a few minuites.
    Still wish we had current meas'ts from an actual 3x8 defroster circuit.
  23. KurtK328
    KurtK328 Formula Junior
    Mar 6, 2001
    347
    Villeneuve-Loubet, France
    Kurt Kjelgaard
    Would anybody consider making a powersupply (switchmode?) reducing the 12V to a level where the desired wattage (10W?) is dissipated?
  24. Steve Magnusson
    26,507
    (Even if we're overestimating the true power dissipation in each case) I can't say that I follow your logic that if the stock unit puts out "X" total watts then a "0.25X" total watts configuration is therefore OK too? I actually like best what you said in your first post: "That grid line kit is a very poor match to this application", and wonder if cutting/rewiring is worth it...
    Anyway, here are some possible configurations for the 180W total configuration:
  25. dhs-9
    Feb 6, 2004
    292
    Help which is it 180 or 45?
    Verell's 180 version seemed less complicated than 91tr (using jumpers) If I read Verell right On the 180w I would just cut the right buss bar in the middle leaving the bottom 12v and attaching the top of the right buss bar to ground. This would then give me two lines in parallel which would make a "C" shaped route from 12v to ground
