Project-Scuderia | Page 21 | FerrariChat
Project-Scuderia
Discussion in '360/430' started by RBM, Nov 7, 2011.
  1. Flyingtopkart
    Flyingtopkart Rookie
    Jan 11, 2020
    4
    Sorry OP for going slightly off topic. Freshmeat, I noticed on your IG that your side markers and reflectors are in your Scud body color.
    Would you mind sharing how you have done it? Was it a replacement part, or a wrap over it?
    Thanks so much!
  2. ShineKen
    ShineKen F1 World Champ
    16,707
    Southern California
    Nostradamus
  3. freshmeat
    freshmeat F1 Veteran
    Aug 30, 2011
    7,257
    Bought additional oem reflectors and had them painted. One the first mods I did to the car back in 2010.
    Flyingtopkart likes this.
  4. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    There is some weight to be saved by removing the second set of markers from a new-build bumper cover [~1.5 lb for the pair], but less savings from modifying an existing bumper, as the patchwork would consume some of the savings.
    The real savings would come from a clean-sheet design bumper manufactured from carbon fiber and/or Kevlar epoxy composite, rather than traditional fiberglass.
    freshmeat likes this.
  5. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    License plate illuminators and exhaust heat shields installed on the rear bumper. The lights bolt into threaded inserts pre-installed at the manufacturer. The bumper does not come with all the threaded inserts that are required, and the required parts are not on the factory parts list. This is definitely not a bolt-on upgrade for amateurs. The heat shields attach via sheet metal screws which require pre-drilling. Care is required as the screws can strip out the fiberglass. The heat shields have to go on after the lower grill is installed, and they help hold it in place. Threaded clips have also been installed on the tabs where the lower valance attaches. One of the infamous 1-pound Titanium brake rotor hats lurking in the background....
    Flea7 likes this.
  6. freshmeat
    Aug 30, 2011
    7,257
    I’m guessing you just transferred these over from the us-spec bumper?
  7. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,651
    England
    Mark
  8. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    Nope. Riv-nuts are one and done. You need new riv-nuts, a riv-nut gun for installation, and the know-how to use the gun.
  9. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    Looking at the inside of the rear bumper, you can see the wiring harness pigtails coming off the license plate lights and the marker lights, which I moved to the rear reflector slots. The pigtails are long enough to easily reach the connectors in the main harness. You can also see two black plastic spacer blocks either side of the center pigtail. They protect the harness and help set the panel fit. The panel fit is fine-tuned by putting washers on the four studs between the exhaust ports and the marker lights.
    Flea7 and mwstewart like this.
  10. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    Close up of the inside of the rear bumper, showing how the CF upper grill attaches to the mounting points cast in the bumper reinforcement. It's the same for the CF undertray. The reinforcement has tabs extending down, with clip nuts attached. The undertray bolts up to those clips.
  11. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    mwstewart and ShineKen like this.
  12. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    I upgraded the chunky stock aluminum license plate bracket with the sheet metal screws that strip out way too easy, with a carbon fiber license plate bracket and threaded clip nuts for real machine screws.
    RANDY6005, freshmeat and mwstewart like this.
  13. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,651
    England
    Mark
    Great work. Love the bracket. Over here we have a heavy number/licence plate mount so I did away with that and the grille.
    Another part that would suit your project is the optional titanium exhaust tip set. The additional length looks great. From memory those and the grill removal saved 3lb.
    benporter likes this.
  14. flsupraguy
    flsupraguy Rookie
    Apr 27, 2014
    42
    This thread delivers. I call dibs if he ever sells his car LOL
  15. ShineKen
    16,707
    Southern California
    Nostradamus
    What I want to know is... how are you lifting the car :)?
  16. Freddan
    Freddan Formula 3
    2,175
    Vansbro (Sweden)
    Fredrik
    +1 :)
  17. freshmeat
    Aug 30, 2011
    7,257
    I want that bracket!
  18. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    Available on EBay
  19. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    Since I left my 2-post lift behind in Austin, I use two low profile floor jacks, and jack stands, in a multi-step process. There are four jack points under the car, plus a fifth on the transaxle if you remove the diffuser.
  20. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    Here's the stock rear license plate bracket. It's made of two sheets of stamped aluminum, folded and spot-welded. It's over-engineered, over-built, and excessively heavy, to have such a fatal design flaw like four holes drilled for sheet metal screws.
  21. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
  22. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    Ferrari builds lighter street cars by substituting aluminum for steel on a very large scale. On their F1 cars, they also substitute Titanium for steel where the strength of steel is needed, but the weight of aluminum is desired. So like on an F1 car, I've started replacing steel fasteners with Titanium fasteners. This set of fasteners replaces the stock fasteners on the rocker panels, the undertrays, and the E-brake calipers. The kit weighed in at 0.430 kg/0.95 lb.
    freshmeat and Penzinger like this.
  23. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,651
    England
    Mark
    RBM, out of interest how do you select the parts to be improved? I'm using a cost per kg analysis and working from the top down. It has been interesting to see that - on the weight saving side, at least - Ferrari's efforts were mostly superficial, which makes sense from a business perspective as it increases the visible differential between these and the F430.
    There are quite a few parts under the skin that could be improved, for example the heavy steel F1 pump bracket. I like what you've done with the chassis reinforcement plate and at the time you first posted I added it to my list.
  24. mwstewart
    mwstewart F1 Rookie
    Feb 5, 2014
    2,651
    England
    Mark
    Correction: visible, not superficial.
  25. RBM
    RBM Formula Junior
    Nov 22, 2009
    867
    RBM
    More Titanium (Ti) fasteners to replace the stock steel fasteners on the rear undertray and the rear diffuser. The kit weighs 0.205 kg/0.45 lb.
