Problems with 2005 F430?
Discussion in '360/430' started by foreverferrari, Feb 23, 2011.
  1. foreverferrari
    Feb 6, 2010
    18
    Hello! I'm thinking of buying a 2005 model F430. What are the problems of this model that I should be aware of? I've heard so much about 430s having a tendency to catch fire. What is the cause of this? Any other problems with this model? Appreciate your comments. Thanks.
  2. hifipj
    hifipj Formula Junior
    Sep 26, 2009
    402
    Search function is your friend. Also a good idea to subscribe to this very helpful site.
  3. HH11
    HH11 F1 Rookie
    3,338
    #3 HH11, Feb 23, 2011
    You will find more than enough info regarding the 05 model year in previous threads. There were some factory recalls, make sure the one you look at has had this done. The fire catching is pretty rare unless something is wrong with the car. Get a good PPI and enjoy.
    heres a short thread
    http://www.ferrarichat.com/forum/showthread.php?t=314089
  4. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,293
    Colorado
    Dave
    I've had an 05 from new. There were a number of TSBs, NO RECALLS. Any dealer can run the VIN and tell you if there are any TSBs not performed yet. Problems are few. The exhaust manifolds will fail but are replaced with a new design under warranty. Mine failed at about 12K miles. Fires are extremely rare. It is a stout beast.
    Dave
  5. Russell996
    Russell996 Formula 3
    Sep 24, 2010
    2,263
    New Forest UK
    Russell
    458's had a rare problem with fires which was fixed by a recall, don't think 430's had any similar issues.
  6. fasthound
    fasthound Formula Junior
    667
    Maryland
    Kevin
    Mine has been basically trouble free and I use it as DD in nice weather and definitely push it hard at the track. Only issue for me was cracked manifolds taken care of under emissions warranty. Basically bullet-proof. And no belts to change...chains run the cams vs the belts on 355 and 360's. Very easy to own. Plan on $1500 a year for maintenance unless you want to change all fluids yourself (easy if you want to with exception of F1 hydraulics). Do a fluids refresh each year and you should have no issues. I upgraded the brakes to Brembo GT's since I track the car. I use Ferodo race pads...brilliant brakes.
    As Ferris Bueller said...."If you have the means, I highly recommend picking one up."
