Hi, I'm solving a problem with the engine sound of my Mondial 3.2 (1988). This is problem with his "whistling" sound, mainly at idling engine revs (or low engine revs). Mondials from this videos have similar sound: (2.38, 2.57 etc.) Do you have any idea, what is the origin of that sound? What should my mechanic focus on? Gearbox bearings?
It sounds like a healthy engine to me IHMO. Not sure what you refer as a whistling sound. I do hear the alternator in first vid a bit. Do you have a vid with sound of your own Mondial? To get rid of some sounds you can disconnect the alternator and AC belt. This is just to see if the sound is still there or not and if not you know it is either of the 2. Keep in mind older cars just make sounds from this time era.
The cars in the vids sound healthy to my untrained ear. I agree with MvT that the whine sounds like a belt driven component.
Great looking car! Have someone stand at the engine bay while raising and lowering the speed of the motor. Maybe that would help. I also wonder if it’s the “Chirping” issue with the exhaust. I actually can’t hear anything that sounds out of sorts. Sent from my iPad using FerrariChat.com mobile app
The coupe has a bad misfire. Likely from letting the car sit for too long. I have argued against this unsuccessfully on the 308 forum lol. This car probably needs the fuel system cleaned out. I would start with that. The cab looks normal for a stock Mondial. CIS fuel injectors do make a pronounced squeal when they are working. This is from a vibrating valve that helps atomize the fuel. You can hear it more clearly when they are removed from the intake: You can also get a squeal from a bad water pump bearing. A faulty bearing will feel tight when turned.
Thank you very much for your reactions. I made 3 videos with my Mondial for your better idea. but maybe …. I'm just „hypersensitive“ and I have unnecessary worries ... that would be the better option
These videos sound fine to me. One thought is the weather. E.g. if you have sudden change to colder weather then this might cause moving parts to sound different, and you to notice it. Especially before the engine warms up. Just a thought.
Like Mark said it sounds good. What you hear is the alternator as well. It just makes this sound. You can get a (more) modern one if the sound bothers you, but IMHO it is the charm of the car. I put in new bearings and it runs more smooth, but the same sound is still there, but less. Like I said we are driving 30y old cars Have fun and drive it as much as you can! Ps. I can remember that I sent someone in Czech Republic a set of epoxy lenses. He had a red Mondial as well. Not sure if it was you. If not there is someone else having a red Mondial too in Czech Republic
Sounds normal to me also. I think he has the Ferrari fever...just thinking something is wrong its going to be $$$. Just your Rev. is to high...1 mille/min should be better and will lower strange sounds. Guido
I think you are referring to a sort of 'whoosing' sound in the first video. Hard to diagnose, make sure to check the exhaust header for any cracks. The second batch all sound fine with me
Sounds like bearing noise. Take the accessory belts off one at a time. If not that, look into the timing belt idler bearings. When was the last time they were changed ?
I bet my hourses on an extender that has burned through (9 out of 10 times this is the case). Little black pin holes you will see when you take them out. The last time was with a trip of Stekkefun where MaseratiMike had misfires all of a sudden. Quick look and we took some isolation tape wrapped it around 2 extenders for a quick fix and it ran beautifully again.
Hi guys, i guess, I have a similar problem. Belts and waterpump were replaced two years ago after a 10years storage at Ferrari in Italy. Fixed the typical clack,clack sound with a belt spray, but the electrical singing sound makes me crazy. Much louder, than it apoears on the video. Like an old washing machine.
There is an idler bearing on the water pump pully, actually two small bearings in the one pully, and are often overlooked. Not hard to access and check or replace. One of your various bearings is dry or worn, just needs a good inspection to find out which one.
It is the alternator which has to work hard after the cold start and during Idle rpm. Is normal and sound will almost disapear when the battery loads back up and there is less tension inside the alternator.
If you are taking the alternator off, i seem to recall you will need a very long 17 mm ? combination spanner ( called long series here )to let one of the bolts off from the underside
Thank you! First I will check the battery, and outcome of alternator and after it, I will take off the belt!
LOL! Reminds me of what my dad, a mechanic during his time in the military, used to tell me whenever I would ask him what to do about a strange noise in one of my cars, "Turn up the radio!"
Hi guys, my mechanican now removed the ac belt, and belts for waterpump and alternator. That wining noise is still there. Timing belts were changed two years ago but driven only 1000km since them. Do the timing belts creating a wining sound in general? Now we try to check the tension of the belts.
I remember something like 10 years ago our Mondial t developed a whistle that sounded exactly like someone quietly blowing a whistle. Not a mechanical sound and also not pulsating like exhaust. I never found the source but it seemed like it was probably a vacuum leak somewhere. However, it went away on its own before I could find the source.
