power window buttons "loose" | FerrariChat
Discussion in '360/430' started by mjz, Feb 16, 2017.
  1. mjz
    mjz Karting
    Aug 3, 2007
    173
    Houston, Texas
    Michael
    The power window buttons on my 430 no longer "spring" back to the center position after I press it. Both of them seem to have lost their click action. The button still works, but I have to press more firmly than before.
    Anyone experience this? - is there is simple fix?
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    It's possible that the buttons have come out of the housing tabs (partially). Can you post a photo?
    PS - there are no springs inside - the lever clicks micro switches that has minimal spring return
  3. Tally Ho
    Tally Ho Formula Junior
    Jul 4, 2007
    720
    Niceville, FL
    Bill
    I had this happen to me as well. I replaced both switches.
  4. Red 27
    Red 27 Formula 3
    Feb 2, 2008
    1,002
    San Diego, Ca
    Dave
    I had to replace the passenger switch.
  5. mjz
    mjz Karting
    Aug 3, 2007
    173
    Houston, Texas
    Michael
    The dealer quoted me $500 to replace both switches ....
    I hardly ever used them.
  6. LorenzoR
    LorenzoR F1 Rookie
    Michael, i know these buttons well. Maserati Gransports have the same problem. This could be your problem.>>Each side of the button is a TIT that sits in a slot. This is how the button rocks. Most likely one of the TITS has broken off and this makes it so the button is not sitting in its housing properly thus you have to press harder to make it work. If yoyur button feels alittle bit sloppy then thats a good indication. If this isnt it then the little micro that helps it bounce back is bad
  7. dapper
    dapper Formula Junior
    Nov 10, 2003
    711
    Bristol, UK
    Dave
    I'm pleasantly surprised that you got away with using the Tit word on a forum without it being starred out! Perhaps the world is starting to see some sensibility?
    KC360 FL likes this.
  8. LorenzoR
    LorenzoR F1 Rookie
    Yea me to but I didn't know how else to describe it so if everybody keeps their minds out of the gutter they should get the picture haha...
  9. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    If that is broken, and still present, a little super glue and it will be like new :)
    We've repair those many times. It helps to have precision tweezers to hold the tiny tab...
  10. dapper
    Nov 10, 2003
    711
    Bristol, UK
    Dave
    $500 bucks to supply and change out a pair of rocker switches, wowser. Mine have just a start of stickiness so I'm going to have to do something when it gets warmer over here in blighty.
  11. mjz
    mjz Karting
    Aug 3, 2007
    173
    Houston, Texas
    Michael
    Any idea on how these rocker button switches come out? I'm willing to give it a go (superglue).
  12. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    #12 Dave rocks, Feb 19, 2017
  13. mjz
    mjz Karting
    Aug 3, 2007
    173
    Houston, Texas
    Michael
    Thanks!
    I believe I need a special tool to remove the radio. Once I get that done, replacing the power window switches looks easy. The part cost $100 at Ricambi for both switches. Worthwhile doing.
  14. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Are you sure? Also - be sure they are available and be prepared - many new parts are sticky in the box...
  15. LorenzoR
    LorenzoR F1 Rookie
    I have fixed many of those. Just glue it, reinforce it from the back and it will last a long time.
  16. MKTViper
    MKTViper Karting
    212
    Swan Point MD
    +1. I used superglue and a thin piece of plastic as reinforcement.
    Also cleaned out all the gunk. Both my switches look, feel and operate like new.
