Power warranty F12 question | FerrariChat
Discussion in 'F12/812' started by ait_z28, Apr 6, 2020.
Tags:
  1. ait_z28
    ait_z28 Rookie
    Jul 17, 2017
    23
    Out of warranty F12 goes to the dealer, Ferrari Power Warranty is requested, car comes back with an invoice with the following items:
    - Ferrari Pwer Normal 8 cylinders Extended Warranty Program
    Cost: 5000$
    - FM-Checkup Extended Warranty Check up
    Cost: 1000$
    Should the 8 cyl line item be of concern? could this dealer dispute future fixes based on this line item?
  2. LVP488
    LVP488 F1 Rookie
    Jan 21, 2017
    4,869
    France
    I think you'd better get this corrected - at the same time you could challenge the check-up bill, if for $1000 they cannot correctly count the number of cylinders it seems overpriced :D
  3. colonels
    colonels Formula Junior
    Aug 5, 2011
    811
    definitely a clerical error. there is 1000 price difference between V8 and V12 coverage. be nice and point that out to them maybe they'll give you a discount. otherwise you'll have to pay for it later if/when you make a warranty claim.
    you could play stupid and if/when that time comes play hardball and say it was their mistake and they have to eat the 1000 cost. it would probably work since you have the work order showing the inspection. i don't see Ferrari NA denying coverage because of it. but then your relationship with the dealer has changed and for 1000 i don't think it's worth it. Ferrari just approved rear vent corrosion fix for me out of warranty, a 16k repair, because i have a good relationship with them. just an example.
  4. speedbird1000
    speedbird1000 Rookie
    Jun 29, 2008
    41
    Europe
    What? Usd 16k... repair ? What they doing respraying the whole car?
  5. vjd3
    vjd3 F1 Rookie
    2,578
    Massachusetts
    Vic
    I would check on my.ferrari.com, assuming you've registered the car there, and see if the new warranty shows up with the new expiration date, then I wouldn't worry about it. Service is not going to go back and check the invoice. If it becomes an issue, then I would pay the difference.
    I can see my active warranty on there right now.
  6. colonels
    Aug 5, 2011
    811
    Yes their factory fix for it is respray both quarter panels and roof and under the rear arch where the mesh attaches to panel.
  7. ait_z28
    ait_z28 Rookie
    Jul 17, 2017
    23
    Thank you all for your valuable input.
    That it was, thanks for the clarification. I took a "nice" approach to this and they took full responsibility for this error.
    Tried registering but it didn't allow me as this particular car is still not registered under my name.
