Power Transistor Location | FerrariChat
Discussion in 'Boxers/TR/M' started by bpcurtis, Feb 10, 2020.
  1. bpcurtis
    bpcurtis Karting
    Nov 5, 2003
    79
    Dickinson, TX
    Burnell P Curtis
    My 87 TR AC and Heater blower motor works only on high. There is a strong suggestion that the power transistor is bad. On Tav. 127 number 14 there is a power transistor shown. Does anyone know where it physically is? I have searched under the dash and can not find it.
  2. Rifledriver
    33,736
    Austin TX
    I have very big hands but I still can reach it through the center dash vent once removed. If you look under the dash for the 3 wires that come out of the ducting near the A/C box and the 2 pop rivets holding it in, Thats it.
    Check also the fuse in the fan speed controller.
  3. bpcurtis
    bpcurtis Karting
    Nov 5, 2003
    79
    Dickinson, TX
    Burnell P Curtis
    I do and the fan runs on max but when switched to lower speed the fuse blows.
  4. bpcurtis
    bpcurtis Karting
    Nov 5, 2003
    79
    Dickinson, TX
    Burnell P Curtis
    Thanks, I hope my hands are small enough.
  5. Steve Magnusson
    25,035
    #5 Steve Magnusson, Feb 10, 2020
    peteficarra and turbo-joe like this.
  6. Rifledriver
    33,736
    Austin TX
    I assure you they are smaller than mine.
    brian.s likes this.
  7. Motob
    Motob Formula 3
    Nov 11, 2003
    2,238
    Frederick, Maryland
    Brian Brown
    I tap threads in the aluminum frame for the transistor, so that I can bolt it back in place instead of using pop-rivets. A good replacement for the transistor can be purchased at an electronics store at a very low price. I am sure that there are many threads on this topic.
    Brian Brown
    San Francisco Motorsports
    brian.s likes this.
  8. bpcurtis
    bpcurtis Karting
    Nov 5, 2003
    79
    Dickinson, TX
    Burnell P Curtis
    Thanks everyone. After much neck pain I found the power transistor, removed it, found it good, replaced it anyway, and now the blower still works only on high but does not blow the fuse in the switch. My guess is that I have a bad connection somewhere or one of the relays is bad. Any suggestions?
  9. Motob
    Motob Formula 3
    Nov 11, 2003
    2,238
    Frederick, Maryland
    Brian Brown
    Time to properly diagnose the system. Have you measured voltages at the base/emitter and collector of the blower speed transistor while varying the setting of the speed control? The workshop manual and the wiring diagram manual have good diagrams of how the system is wired. Ferrari made some changes over the years, using different speed controllers with slightly different wiring, so take that into account when looking at what you have.
    Brian Brown
  10. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    I had an issue where a pad lifted on the circuit board of my fan speed switch. It prevented the fan from working at any speed below max. Took two minutes to fix once I identified it as the issue
    peteficarra likes this.
  11. bpcurtis
    bpcurtis Karting
    Nov 5, 2003
    79
    Dickinson, TX
    Burnell P Curtis
    I have now found that the switch is bad. One of the pots on the board is bad. A replacement switch is $750. which I find insulting. Anyway, has anyone found a replacement for the pots or the switch itself. An electronics friend of mine says it is possible but will take time so I thought I would ask and not repeat work.
  12. bpcurtis
    bpcurtis Karting
    Nov 5, 2003
    79
    Dickinson, TX
    Burnell P Curtis
  13. bpcurtis
    bpcurtis Karting
    Nov 5, 2003
    79
    Dickinson, TX
    Burnell P Curtis
  14. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
  15. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    You'll need to measure the resistance across the pot at the various taps. If I remember correctly it wasn't a common style of pot either, but you can likely just sub it out for one good enough. I can understand why an OEM switch would be so expensive, but the reality is you don't need to replace the whole switch and can just repair them.
  16. bpcurtis
    bpcurtis Karting
    Nov 5, 2003
    79
    Dickinson, TX
    Burnell P Curtis
    The pot closest to the knob is good. The other pot is open at all points, which is strange.
  17. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    can you provide a pic?
  18. bpcurtis
    bpcurtis Karting
    Nov 5, 2003
    79
    Dickinson, TX
    Burnell P Curtis
  19. xplodee
    xplodee Formula 3
    Jan 3, 2017
    1,101
    Allentown, PA
    Tim
    Yours is different than mine. Do you have pics of the circuit board itself? Thats where the parts are likely to fail. Can the pot go back together? I wouldn’t have bothered to take it apart, maybe more harm than good there
  20. bpcurtis
    bpcurtis Karting
    Nov 5, 2003
    79
    Dickinson, TX
    Burnell P Curtis
    I could supply a picture of the printed circuit board but the second pot, the closeup one, is not working. It has no measurements(open) on the carbon trace, which is why I took the whole thing apart. I could put it back together and put it on the board but I see no reason to do that now. If someone had a similar switch and could tell me the values of the second pot, then there is a possibility that I could fix it. Otherwise, I am stuck.
