power steering fluid change | FerrariChat
Discussion in '456/550/575' started by stevepaa, Aug 1, 2023.
  1. stevepaa
    stevepaa Formula Junior
    Apr 5, 2006
    762
    san jose, ca
    steve
    so I drained the power steering fluid down by the box by loosening the pipe union. I then used compressed air as directed and I got 1 liter of fluid in my pan. Is that all I can get?
    Then the WSM says to tighten the pipe union up to 40 NM. Is that too high?
  2. fatbillybob
    Aug 10, 2002
    28,545
    socal
    Power steering has a circulation to it like cooling system. That is about all you get unless you drain the rack but that's huge work. I just suck out the reservoir before the fluid goes bad and just replace. I use a more frequent interval like I do with cooling system so my systems never go bad. This way I don't have to get anal on how much old fluid I get out. So I also don't drain my block when I do cooling system. Some people think otherwise. If I had a really bad system or a car I just bought and do not know history then I'll go the extra mile the 1st time then go back to my regularly scheduled program.
    For ease sometimes I'll change the fluid a 2nd time and dilute out residual fluid. IMO the key is don't let fluid get nasty in the 1st place.
    40nm is 29ft-lbs. That does not sound like too much but I never use a torque wrench except on critical fasteners, heads, con rods. I bet it took more than 29 to get it off.
  3. stevepaa
    Apr 5, 2006
    762
    san jose, ca
    steve
    thanks
    yes it was pretty tight. I should have made a note last time
    I change fluids every two years, not due for 8 months but doing it now in preparation to sell, been fun for nearly 10 years
