Positive and Negative posts for battery jump starts | FerrariChat
Discussion in 'Mondial' started by John Hasty, Oct 15, 2019.
  1. John Hasty
    John Hasty Rookie
    Jul 16, 2019
    37
    John H. Hasty
    Where would the posts for use in a battery jump start located in the 1989 Mondail t ?
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,828
    Isle of man- uk
    Not sure i understand the question , just put the jump leads onto the battery terminals- where else would you put them ?
  3. Drewbdo
    Drewbdo Karting
    Apr 8, 2016
    189
    Atlanta, Georgia
    #3 Drewbdo, Oct 16, 2019
    Depends on what you're into... o_O:p:D
    Seriously though, the OP may not know where the battery is.
    In the "Mondials for sale" thread, I describe visiting a Copart lot to view a Mondial T listed as a "no start" condition. The guys who work there didn't know anything about the car, but said I was welcome to use their jump box to try to start the car.
    Unfortunately, at the time, I didn't know where the battery was located (front trunk), or even where the manual release handle for the front trunk was.
    Total Mondial newbie here... it is the only Mondi I have ever seen in person. :rolleyes: lol
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,828
    Isle of man- uk
    You stick to the kinky stuff with the jump leads and i will be a bit more conventional.
    Drewbdo likes this.
  5. Drewbdo
    Drewbdo Karting
    Apr 8, 2016
    189
    Atlanta, Georgia
    :D lol
    If you are looking for the battery itself, it's in the front trunk. If you need the manual release to get into the trunk, here is an image posted by Wade.
    I didn't know where it was located before, so I wasn't able to open the front trunk to check the battery on an auction car. Hope that helps :)
  6. John Hasty
    John Hasty Rookie
    Jul 16, 2019
    37
    John H. Hasty
  7. John Hasty
    John Hasty Rookie
    Jul 16, 2019
    37
    John H. Hasty
    I know where the battery is and it is not easy to get to without taking the right front wheel off...the question is whether there is a positive post somewhere else in the car like all my Mercedes have??
  8. Steve Magnusson
    25,038
  9. moysiuan
    moysiuan F1 Rookie
    3,628
    Canada
    The terminals are often under the metal body area and jumper cables can be tough to fit in there, or worse one could hit the metal while attaching to the positive. So jumping a Mondial is not like in more typical cars. The negative cable goes to the battery disconnect switch, and would be the right terminal looking down at the battery from the front of the car. Some people put a replacement battery in where the terminals are centered on the battery and not under the metal body, and therefore easier to access. The OEM battery and terminal location was designed to keep water off the battery, but does compromise terminal access.
  10. gsfent
    gsfent Formula 3
    Nov 16, 2009
    1,096
    PB County, Florida
    Jerry
    Most batteries are hard to get to with jumper cables.
    A previous owner ran a cable from the positive to a space on the "wall" of the front trunk near the battery and put in a bolt. Other than making it black (universal power for 12V is red), it works great. Just ground on any metal bolt.
    I have added a battery maintainer cable so I can just plug that in to make sure the battery is topped off.
    Regards,
    Jerry
    Drewbdo likes this.
