355 - Portable Lift | FerrariChat
355 Portable Lift
Discussion in '348/355' started by PaulK, May 21, 2020.
  1. PaulK
    PaulK F1 Rookie
    4,616
    Michigan
    Paul
    Hello Brothers and Sisters of The Revolution,
    I was wondering about these portable lifts like Max Jack and some others I can't remember off the top of my head. Do any of them lift the car high enough to pull the engine out the right way and not have to tilt the car? Assume a low profile engine stand. Will anything work? Thank you.
  2. Ferrarium
    Ferrarium F1 Veteran
    5,631
    Central NJ
    Eric
    Bendpak makes a low rise for trucks that raises high enough if I recall. The one for cars does not. Other than that you'll need a midrise lift. Lots of them out there.
    Sent using FerrariChat.com mobile app
  3. PaulK
    PaulK F1 Rookie
    4,616
    Michigan
    Paul
    Gotcha, thank you for your help. I think outside of a proper two-post, a mid-rise is the way to go.
  4. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    12,661
    San Carlos, CA
    Mitchell Le
    I have done many engine drops off Porsches, Ferrari 355 / 348 using a four post lift.
    I think the mid-rise Max Jax is high enough to drop the engine especially if you remove the bumper.
  5. Ferrarium
    5,631
    Central NJ
    Eric
  6. vjlax18
    vjlax18 Formula Junior
    680
    Nottingham, MD
    I have a MaxJax and used it for my last engine out and it worked great. (Probably wouldn't have bought the 348 if I didn't have the MaxJax)
  7. fboutlaw
    fboutlaw Karting
    Dec 3, 2014
    237
    Woodside, CA
    GTUnit, WATSON and Manda racing like this.
  8. chopsui
    chopsui Karting
    119
    Austin, Tx
  9. PaulK
    PaulK F1 Rookie
    4,616
    Michigan
    Paul
    Thanks everyone. Sadly I can't do the two post option, I don't have the room and I can't drill into the concrete.
    The Bendpak MD-6XP looks like a good one that will work but I am worried the arms wont be long enough. Does anyone use one of those?
    That's pretty cool- what engine stand are you using?
  10. Ferrarium
    5,631
    Central NJ
    Eric
  11. fboutlaw
    fboutlaw Karting
    Dec 3, 2014
    237
    Woodside, CA
    Harbor Freight hydraulic table cart. Remove the pins and you get the bar out of the way. It's not quality, but was the right tool for the job. Then you take the engine cradle and put it on jackstands for stability when working on it.
    PaulK likes this.
  12. Manda racing
    Manda racing Formula 3
    Feb 25, 2015
    1,247
    Bakersfield, Ca
    Mark
    I dislike my mid- rise until the car is in the air. F’n PITA.
    fwiw
    my remarks are the ones with the arms you have to reach under car to pry up with your finger tips and position.
    not the MRK6 style. With flat bottom
  13. WATSON
    21,711
    WI
    #13 WATSON, May 22, 2020
    I own this same lift.
    It works great and gets out of the way when not in use.
    The flow divider sucks, especially on lightweight cars (ie without engine)
    Also, double check the safety stop arms as I needed to clean up some welds and burs to make sure they moved smoothly in to place.
    As mentioned, make sure to get the M6 as it has safety stops along the way.
    Danmar did recently go bankrupt and Bendpak bought the assets so that might be a good thing.
    I also bought one of these: https://www.northerntool.com/shop/tools/product_200696310_200696310
    I have not done the 355 yet, but this is working perfectly on another car I am doing an engine rebuild on.
  14. PaulK
    PaulK F1 Rookie
    4,616
    Michigan
    Paul
    It looks like the Bendpak MD-6XP to be a good practical lift. Aren't they made in China now? I really would prefer to buy American if I can.
    With that kind of lift I do worry about the car balancing- both with the engine in and the engine out. Also I'd like the arms to be able to reach as far back to where the a-arms meet on the frame, ala Dave Lelonek's (Sticky RX) excellent lifting and jacking guide. But I think none of them will be able to do that...
  15. Ferrarium
    5,631
    Central NJ
    Eric
    Tha'ts easy, get a 4 post then.
  16. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,965
    Indio Ca/ Alberta
    Grant
    Nice
    What kind of cart do you have under the engine now
  17. fboutlaw
    fboutlaw Karting
    Dec 3, 2014
    237
    Woodside, CA
    Only the classiest. Jackstands on the subframe. With them spread wide enough the hydraulic cart could fit under the center for moving it around. I should probably post an engine rebuild photo thread at some point as the rebuild portion of the job was completed 6 months ago.
  18. phrogs
    phrogs F1 Veteran
    7,127
    Michigan
    I have a Max Jack and it worked perfect for engine out.
  19. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    5,965
    Indio Ca/ Alberta
    Grant
    The brand of hydraulic cart was what I was wondering
  20. lanab
    lanab Formula Junior
    Feb 21, 2016
    449
    Stockholm, Sweden
    The engine is only 168kg
  21. Ferrarium
    5,631
    Central NJ
    Eric
    Is that accurate, did you weight it I have seen sites that list that number? I ask as I thought the engine, subframe, axles and gearbox was closer to 325kg?
  22. PaulK
    PaulK F1 Rookie
    4,616
    Michigan
    Paul
    Ok so I have been doing some research on this Bendpak MD-6XP scissor lift but then I saw the weight is something around 800lbs. I know that is taking into consideration the pump and various ancillaries but where do you store these things? I was hoping to lean it up against a wall. Sadly with weight like that I wont be able to lift it, even if the actual lift is slightly less than that.
  23. Ferrarium
    5,631
    Central NJ
    Eric
  24. lanab
    Feb 21, 2016
    449
    Stockholm, Sweden
    Without gearbox probably.
