Porcelain garage floor pros cons for new 7-car garage
Discussion in 'Detailing & Showroom' started by terryreid, Mar 30, 2022.
  1. terryreid
    terryreid Rookie
    Jun 7, 2017
    20
    Bloomington, IL / Fort Lauderdale, FL
    Terry R. Stahly
    We are adding an addition to and existing 3-car garage and while never a fan of the look of expoxy or speckles we have come upon porcelain since we are doing or re-doing five rooms in our home with same. It seems to be one of the most permanent solutions and as good as any so far from what little research we have done with endless color and pattern options. Does anyone have any experience or knowledge on porcelain garage floors. If so we are looking for all the information and pros and cons we can find. Money it not a factor only the end result.
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,687
    Central NJ
    Dominick
    I think a good rated porcelain tile with the proper installation is hard to beat ..only down side is maybe depending on tile is slippery.
  3. rotaryrocket7
    rotaryrocket7 Formula Junior
    Dec 7, 2011
    625
    Eden Prairie, MN
    Matt
    Above is true, also, grout lines matter, they get dirty and are hard to clean. It'll depend on what kind of traffic and work you do, snow/salt and dirty cars coming in vs. southern weather. Most car dealers have porcelain tile floors, usually look great
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,687
    Central NJ
    Dominick
    Yes .. get the smallest grout lines you can (read here almost none) and buy the grout that seals itself
  5. terryreid
    terryreid Rookie
    Jun 7, 2017
    20
    Terry R. Stahly
    They seldom install Porcelain today in high end home that is less than 48x48 inch or 30x40 inch and the edges are so square you really do not see grout lines we are using it in our home and now I believe the garage.
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,687
    Central NJ
    Dominick
    Just check rating ..strength hardness etc especially if you plan to work on car
  7. FerrfanFL
    FerrfanFL Formula 3
    2,230
    Florida
    Ara
    i would hesitate.
    by accident someone drops a hammer/large object and cracks a tile. What a dust storm and nightmare to replace.
    Will be SUPER SLIPPERY.
    I epoxied my floors, and actually grinded the entire garage to prep it. The grinding was the longest, but i added is some aggregate to the epoxy in the high traffic areas for slip resistance. Came very nice.. Kids don't slip when flying through with wet shoes from some rain, etc...
    Grout lines would make me insane. IF porcelain has to be yours, find tiles that have no grout lines. They butt up to the next tile.
  8. terryreid
    terryreid Rookie
    Jun 7, 2017
    20
    Terry R. Stahly
    Thanks I appreciate your comments but I would not choose glossy but rather a semi hones or matt finish like virtually every high end car dealership uses today. I do not work on my cars or drop heavy objets and if I did I would simply have the tile 48" x 48" replaced out of the same dye lot as I will have spares. There are no grout lines on the porcelain I am installing that is one of the main things that appeals to home owners when going with this type of porcelain.
  9. Alpintourer
    Alpintourer F1 Rookie
    Jul 20, 2013
    3,779
    The Low Country
    Dave Steven
    4' X 4' tiles are huge. If your cement floor is uneven or the tiles are not set firmly or there are gaps in the mortar bed, the weight of a tire could crack a tile. This not a job for Daryl, and his other brother Daryl.
    readplays and Face76 like this.
  10. unogib
    unogib Formula Junior
    Jun 26, 2006
    403
    Make sure PEI is 4 or 5. Also check friction coefficient for non slip. If above check out then it’s the best flooring you can have in a garage. And a dropped hammer will NOT break or chip the tile with the above. I’ve tried. Neither will it be slippery. One of the most slippery floors I’ve ever had was wet race deck. Back butter is key for installation.
  11. f4udriver
    f4udriver Formula Junior
    Feb 1, 2012
    299
    Central Illinois
    Mike G
    I installed porcelain tile in one of my garages over 15 years ago. I am in Springfield just 60 miles south of Bloomington. At the time the porcelain tile was actually the cheapest alternative. I think I paid 50 cents per foot and the labor wasn't very expensive since it was going on concrete.
    My other garage has a professionally done epoxy floor with speckles. This is for everyday cars.
    My thoughts
    When you work on a car with speckles you have to keep a magnet to find any small parts when they fall. You can not see them through the speckles.
    The porcelain tile has held up very well and still looks like new. Only the grout lines are a little dirty in some spots.
    I used a floor jack several times on the tile and it has held up very well. Once to pull a transmission with all of the work and mess that goes with that.
    The only real negative of the tile is the critters that get in to the garage (probably because it is heated and cooled) and the mess they make. Especially the spiders.
    Never had any slipping problems at all, and the Countach tends to leak multiple fluids which are pretty easy to clean.
  12. Face76
    Face76 F1 World Champ
    13,229
    The Other Oz
    M Wilborn
    One downside to increasing grit on any floor surface is that too much grit will shred a commercial mop quick. Restaurants learn pretty quick that a kitchen floor with grit may improve safety but it makes clean-up a hassle each night. You may not be mopping a garage floor but it can be a real issue.
  13. Tifoso Ferrari
    Tifoso Ferrari Formula Junior
    Nov 7, 2005
    578
    Upper Volta
    Gianni Cagate
    Terrazzo is an excellent & beautiful alternative. Wow!
  14. SCFerrari
    SCFerrari F1 Rookie
    3,829
    South Carolina
    Rob
    In our daily driver garages we put the tile down that looks like hardwood floors - you see it in fresh markets and Whole Foods a bunch - anyways , it’s perfect and not slippery and it’s all plenty strong as long as your tile guy ‘butters’ the bottom of the tiles and squeezes out all air pockets - it then becomes as strong as your slab . We also used anti fracture - since concrete slabs crack and move around some - 4 years so far - not a single crack or issue.
    Thecadster likes this.
  15. colombo2cam
    colombo2cam Formula Junior
    Jan 31, 2019
    840
    Ted
    I have porcelain in the home garage and professionally installed epoxy in the other. I don’t do any work to speak of at the house garage and have been extremely happy with the floor. We use pig mats under the cars, we have old cars, to take care of the oil/grout issue. The epoxy floor at the other building where any work takes place is super easy to clean and durable.
  16. colombo2cam
    Jan 31, 2019
    840
    Ted
    cgt000 likes this.
