Popping carb issue | FerrariChat
Popping carb issue
Discussion in 'Technical Q&A' started by Fave, Mar 5, 2011.
  1. Fave
    Fave F1 Rookie
    Aug 12, 2010
    4,157
    Tarana
    L. Ike Hunt
    Hi there,
    This is regarding a GT4 308 Weber 40DCNF
    I have searched and read a fair bit on this so I just want to see if I have all my based covered before I remove the offending carb.
    I rebuilt all my carbs including replacement of the throttle shafts and installed new sealed bearings.
    The carbs were just put back on the engine which just received new valves and the head work done. The dizzy's which are using points were setup by a pro as was the carb synch.
    The 5,6 carb is popping and the main issue is no matter what you do to the idle screws, in or out nothing changes so I'm leaning towards a blocked fuel port in the idle. could both barrels of the carb be blocked?
    I also read about the possibility of air getting in under the carb between the gaskets? Someone on here had this happen and used liquid gasket to seal all sides of the gasket and sealer.
    Also I known to check the linkages.
    Any other suggestions to look for?
  2. Peter
    Peter F1 Veteran
    Dec 21, 2000
    6,440
    B.C., Canada
    Is it occasionally popping, or constantly? Does it pop throughout the entire throttle travel (like reving up the engine) or just at idle speed?
    Take the carb cover off and check float height. Check also the needle valve to see if it's stuck or maybe something is blocking the fuel inlet.
    Are the little O-Rings in place where the idle jets screw into the carb body? If they're damamged or missing, they could be letting excess air by and leaning out the idle mixture.
  3. Fave
    Fave F1 Rookie
    Aug 12, 2010
    4,157
    Tarana
    L. Ike Hunt
    It's happening just through the idle stage.
    I will check everything you have suggested.
  4. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,784
    Marin
    Geno
    Did the carb rebuild include restaking the lead plugs?
    Can you get any change in cly 5/6 by running the mix screws in and out?
  5. Fave
    Fave F1 Rookie
    Aug 12, 2010
    4,157
    Tarana
    L. Ike Hunt
    No the lead plugs were not touched. I will check the mixing screw and get back.
  6. tomoshea
    tomoshea Formula Junior
    Dec 29, 2003
    541
    Ireland
    Tom O'Shea
    #6 tomoshea, Mar 6, 2011
    OK, I had exactly the same issue on 5/6 just after rebuild of top/ bottom end.
    It has to be either:
    1) intermittant ignition issue on 5/6 - manually rotate the crank with spark for 5 or 6 out when it fires on cylinder 5 and 6 place a mark somewhere on the harmonic balancer for each that is visible. Start the engine, put a timing gun on lead for 5 or 6 , watch the mark as the engine runs, when the spit occurs see if the mark moves back or forward, if it does then you have an ignition issue - leads dizzy or rotor sparking too early - assuming not goto 2
    1a) Make sure the idle is running at AF6 - use a timing gun on cylinder 1, if it is too advanced you could get some spit back.
    2) Inlet valve issue on 5/6 - Assuming no issue with the above, take cylinder 5/6 carb off, disconnect fuel pump (remove fuse), get someone to sit in the car, while you observe inlet valves. Spray something like WD 40 into the inlet valve port, watch to see if there are any significant bubbles/ blow back when the engine is cranked over - if yes then you have an inlet valve issue - bad seal most likely, the worst possible outcome - If this doesn't show anything, then it has to be a Carb set up issue - the best outcome....
    3) It has to be something simple like idle mix issue, crud in the idle circuit ( if both 5 and 6 spit, a real possibility), or air leaks somewhere. Possible checks.
    a. Spray carb cleaner around (not into the carb) the carb body with engine running, see if the ignition changes or engine studders, then you have an air leak somewhere.
    b. Take out idle jets and clean.
    c. Blow dry compressed air through the idle circuit.
    d. Remove idle mix needle valve - this can be the source of many issues- it is not always the case that 3.5 to 4 turns is about right, sometimes it can take 5 or 6 turns.
    e. Place the carb on a very stong white light, look into both cylinders see how much light is coming through the butterflys when fully closed, if one is signifincatly different than the other, that could be your issue - butterfly could need reseating/ positioning.
    It is most likley you are running lean. The best way to sort that out is individual sample pipe for each cylinder to get the CO at approx 3.5%, best way to ensure you are running OK.
    Let me know what you find. In my case it tuned out to be the idle mix needle valve. Colortune spark plug was misleading, thought it was tuned properly due to colour of cylinder flame, but was running lean, not enough fuel at idle and also idle speed was too low when warmed up.
    All of the above of course assumes you carbs were balanced perfectly to start off with, whcih takes time..
    3) Fuel/ air mix issue
  7. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,784
    Marin
    Geno
    swap the idles jets with another carb that is working.
  8. ladiesman217
    ladiesman217 Rookie
    Feb 20, 2009
    25
    Frenchtown, NJ
    Alex de Groot
    I've found that with today's gas the idle jets need to be 2 to 3 jet sizes big to run right. I've had this problem with a lot of DCNF and DCOE equipped cars.
  9. driver
    driver Karting
    Sep 19, 2002
    121
    Tom's 3)a suggestion should be tried. I had a similar issue and it turned out to be leakage in the manifold. Propane will also do the trick. BTW, the manifold gaskets are not easy to remove, but the engine is now very smooth.
  10. CaptOharry
    CaptOharry Formula Junior
    Jan 4, 2009
    763
    Green Cove Spgs FL
    Harry Welch
    Did those Webbers come with brass or Plastic Floats? If they are Plastic they could be saturated with gas internally,and you'll never get it adjusted.
  11. cizeta
    cizeta Rookie
    Jul 2, 2010
    7
    great white north
    Craig Zuidema
    I believe they came with 55 idle jets, increasing to 60 will get some adjustability back, since normally correct idle mix is achieved on these with about 4-5 turns as someone has already stated. ANY flow restriction in the idle passage will lean it out and cause the spit-back due to the slow lean-burn effect. Be advised messing with emission calibrations is frowned upon if you are in a smog check state. More important to get your car running right. If modifying one carb, do them all. Often, changing from the stock exhaust to an aftermarket muffler would create this condition, what do you have?
    If the distributors are set up correctly it is unlikely an engine or ignition problem just affecting the one carb.
  12. Fave
    Fave F1 Rookie
    Aug 12, 2010
    4,157
    Tarana
    L. Ike Hunt
    I'm pretty sure it's a stock muffler that has been repacked.
    The floats are brass and adjusted.
    I did do a spray test and there was a stumble. I tightened everything down and the spray test shows no stumble.
    The popping is definitely better, but it still present on the #6 piston's carb.
    Before this I pulled the plugs, nothing was running lean.
    Now the car is definitely rich.
    Someone mentioned to me going back to stock jets as my car us a series 1 GT4 with no emissions.
    What is really making me scratch my head is why the idle jet screws are not making any difference to the rpm when screwing them in or out.
  13. Sledge4.2
    Sledge4.2 F1 Rookie
    Oct 19, 2007
    4,784
    Marin
    Geno
    Re the idle mix screws don't change any behavior at idle on the #6 cyl or any of them?
  14. tomoshea
    Dec 29, 2003
    541
    Ireland
    Tom O'Shea
    One other possibility......
    Have you checked the clearence between the bucket/ shim and cam. There is a possibility the distance has tightened and you don't have enough clearence, which could cause the spit back you are finding, especially if clearence is marginal.
  15. Fave
    Fave F1 Rookie
    Aug 12, 2010
    4,157
    Tarana
    L. Ike Hunt
    I have to confirm this but 5 & 6 were like this. 6 started to raise the rpm but it was at the end of the threads and then the idle screw fell out.
    Were the early webers made differently for more fuel flow? I was wondering if the larger jetting is too much for the carb, therefore it can't properly be adjusted?
    The old setup was
    220 AC
    F24
    130 main jet
    .052 idle jet
    New setup
    190 AC
    F36 emulsion tube
    135 main jet
    .055 idle jet
  16. Fave
    Fave F1 Rookie
    Aug 12, 2010
    4,157
    Tarana
    L. Ike Hunt
    Honestly that is beyond my skill level. I trust the guys who did the head and engine work did it correct. I did bring this up to them, they assured me the cams are set correct.
  17. tomoshea
    Dec 29, 2003
    541
    Ireland
    Tom O'Shea
    valves bed in in rebuilt engines, clearences tighten, if the shims on rebuild were close to the lower limit already this could be the issue, only way to be sure is take the front cam cover off and use a feeler guage to check the clearence.
  18. Fave
    Fave F1 Rookie
    Aug 12, 2010
    4,157
    Tarana
    L. Ike Hunt
    How does the valve clearance affect weather or not the idle screw affects the rpm?
  19. tomoshea
    Dec 29, 2003
    541
    Ireland
    Tom O'Shea
    The two are not related at all,
    popping is either a carb/ fuel issue or a valve closure/ seating issue.
    You seem to have completed a lot of work to rule out the carb issue......
    Now check the other possible source.........
  20. bill308
    bill308 Formula 3
    1,224
    Windsor, CT
    Bill Sebestyen
    Fave,
    What are your float heights set at and what are the suffix numbers on the carbs (i.e. DCNF40 /45,46,47,48?
    Bill
  21. Fave
    Fave F1 Rookie
    Aug 12, 2010
    4,157
    Tarana
    L. Ike Hunt
    But it's not so much the popping that's a problem, a bit during warm up. What is a problem is not being able to adjust the idle needle as it does not affect the rpm when trying to set the carbs up.
  22. Fave
    Fave F1 Rookie
    Aug 12, 2010
    4,157
    Tarana
    L. Ike Hunt
    They are DCNF 40. There aren't other numbers on them that i know of. I set the floats 48mm closed & 58.5 open. I am going to open the 5-6 carb and make sure the float is proper, tho I was pretty careful when setting them.
  23. bill308
    bill308 Formula 3
    1,224
    Windsor, CT
    Bill Sebestyen
    Fave,
    The reason I ask is because I replaced the DCNF40 /75-78 on my 78 GTS with earlier, new DCNF40 /45-48 carbs, OEM to GT-4 USA models I believe. When checking float specs in the various 308 Owners Manuals, it turned out the /45-48 carbs had a slighly different float height specified IIRC. For instance, the 75 Euro GTB carb specification /57,58,59,60, calls for a 50 mm setting to the base, without gasket. Your carb series should be stamped into the base or exterior housing somewhere, if you still have the 5-bolt OEM carbs with the removable air horns.
    Are you saying that when you adjust the mixture screws on the 5,6 carb, even all the way in (closed), there is no effect?
    What is your idle rpm?
    One thing you might try is to increase the flow a little bit through the 5,6 carb and see if it will then respond to the mixture adjustment. It turns out that there is a minimum air flow required to set the mixture properly. Too low an air flow and the mixuture adjustment will not work. I discovered this one day when trying to set the idle mixture adjustment on one of my carbs usng a Color Tune. What the Color Tune showed was a partial white flash (at idle) on the affected cylinders, instead of a steady burn with a color. I increased the air flow rate and was then able to set the mixture.
    I hope this helps.
    Bill
  24. Fave
    Fave F1 Rookie
    Aug 12, 2010
    4,157
    Tarana
    L. Ike Hunt
    Hey Bill
    My Dcnf 40,s are the 35_38. The manual shows the float travel is 48 - 58.5 mm without a gasket. That's what I set them at but I am going to check them.
    I'm ordering some new jets as well.
    The manual calls for
    F25
    130 main
    220 AC
    Alternatively I can use
    F36
    130 main
    200 AC
    Currently its
    F36
    135 main
    190 AC
    So with that said I'm not going to get anything done for another week as I'm heading out of town and the parts need to arrive. Tho I had the car out for a good run Saturday and ran very well, albeit rich but no poping. Yesterday it was poping like mad and ran like a fat hog.
    Probably doesn't help I'm running points. Although I'm old school that way I think its time to switch over to electronic.
    Cheers
    Favian
  25. Dandy_Don
    Dandy_Don Karting
    Dec 8, 2003
    102
    The Woodlands TX
    Don McCormick
    If you are not getting any change in engine speed when you screw the idle mixture screws in or out then cylinders 5 and 6 are not firing consistently or at all when the engine is idling. Many things could be causing you to have intermittent or or complete misfiring but the most obvious and likely are spark problems (wrong timing or too weak, bad wires to those cylinders), an air leak at the affected cylinder(s) or a poor balance between that carburetor and the other carbs. While all of the causes that people have brought up are indeed possible, applying Occam's razor, the simplest and most straightforward cause is the most likely. Focus on these three things first as they are the most likely. While possible, it is unlikely that you have dirt in the idle circuit for any number of reasons- you just cleaned them, they don't get dirty easily in my experience unless you are just careless (which I highly doubt), especially as you are only getting the popping at idle.
    I would disconnect all of the linkages and let the engine run. Still get popping? How are your vacuum hoses connected? Do you have a different routing to/from carb 5/6 than the others? Replace the plug wires to cylinders 5 and 6 and see what happens.
    Hope this helps. You are right in that you have a fundamental problem if manipulating the 5/6 idle screws does not alter the engine speed. You MUST get the engine to falter when you screw in the idle screws past a certain point. If it doesn't then it ain't right and you need to keep looking.
